Voltage monitor for car battery
Results 1 to 40 of 51
    Jul 2007
    Grass Valley CA
    Quote Originally Posted by malc-c View Post
    I don't think that would work. The regulator will simply give you a 5v supply from the 12v battery, it will never fall below 5v because the car battery would never get this low. The simple way is to use a voltage divider made by connecting two resistors accross the 12v line and then connect the pic to the junction between the two.
    If you used a 58K and 41K with a 12v supply you would get 5v, however the state of a car battery is such that it's voltage will vary under charge and drain, so you would need to make allowances for that. You might find that under charge the voltage could be around 13.8v, falling to 10v under load.
    The OA didn't say use the regulator for the sensed voltage, but for the supply voltage. He also recommended a 3:1 voltage divider for the sense. Personally, I'd use a 4:1 because the car battery can get up into the mid-14 volt range with some charging systems.
    I have no idea where you get 58k and 41k resistors; these aren't standard RETMA values. I'd use a 100k and a 22k-10k variable in series to set the voltage accurately, or do some other tricks in software for calibration.
    Jim
    passion1, Use a 10.2K 1% and a 2.55k 1% for the voltage divider. This gives you 25.00 volts full scale or a 20% division. I often use these values when not being concerned about the 1mA. current draw @ 12 volts.
    Dave Purola
    I will but in here
    I use a 3 to 1 divider to monitor my solar battery bank. Two 10Ks in series from (+) and one 10K from (-). if peak voltage is 15 you get 5. Voltage drops to 10, you get 3.3.
    This works for me.
    May 2007
    Hi All
    Thank you very much for the advice!
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by weirdjim View Post
    Sorry, mis-read the post
    Whislt not standard a quick google will show that they do exist, or simple enough to make up the value.
    Mar 2004
    UK-Midlands
    Don't forget to suppress the voltage spikes! A cars electrical system can generate spikes easily above 50v. Try to take the measurement points as close to the battery as possible. Also damp the takeoff point from the resistor divider with a small capacitor (10uF). I would also use some inductors in the supply line to protect the regulator and PIC.
    Bob
    May 2007
    Quote Originally Posted by BobP View Post
    Bob
    Bob
    Thanks for the advice! Could you be specific with regard to where the capacitor must be placed as well as the inductors. If possible, inductance values would be appreciated. (I'm rather new to electronics!)
    THANKS!
    Passion1
    here is web link with values and op-amp
    http://www.winpicprog.co.uk/pic_tuto...ogue_board.htm
    Has for the zener diode you just put the block end to say PORTA.0 and the ohter to ground.
    hope this helps,
    chuck
    Mar 2004
    UK-Midlands
    As per your request please find attached a quick and basic suggestion for values I would use.
    As you have 10k resistors I used these.
    Bob
    May 2007
    Bob , Chuck and other
    Thank you all for the advice. I really appreciate it!
  1. Battery pack cell reader
    By steiner in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 07:41
  2. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 21:32
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  4. Measuring Battery voltage
    Last Post: - 4th December 2006, 00:07
  5. Help with setting adcon1 for 16f877
    Last Post: - 16th August 2005, 12:13
