Voltage monitor for car battery
Results 1 to 40 of 51
    use an op-amp set up has a devider you can then put upto 20v in and get 0-5v out and for safety tie a 5V zener diode to prevent damage to the pic or just a resistor devider
    I personal use op-amp has i can measure up to 60V
    Hello. I've been using the attached circuit and the following code to measure the battery condition on a 12V sealed rechargable gell cell. The code goes like this:
    batterycondition var byte
    adcin 1, batterycondition
    if batterycondition < 192 then beep
    Perhaps tweaking the adcin value would work for lead acid. It may have a different discharge curve.
    May 2007
    Quote Originally Posted by chuck View Post
    Chuck / Jerry
    Thanks for the advice! Could you be specific with regard to where the 5V zenere diode must be placed. (I'm rather new to electronics!)
    THANKS!
  1. Battery pack cell reader
    By steiner in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 07:41
  2. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 21:32
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 21:35
  4. Measuring Battery voltage
    Last Post: - 4th December 2006, 00:07
  5. Help with setting adcon1 for 16f877
    Last Post: - 16th August 2005, 12:13
