Voltage monitor for car battery
Results 1 to 40 of 51
    For D1 a 1N54xx should work. It is rated at 3 amps.
    http://www.onsemi.com/pub_link/Collateral/1N5400-D.PDF
    Or if you do have to go with a 5 amp circuit then a MR75x at 6 amp rating.
    http://www.onsemi.com/pub_link/Collateral/MR750-D.PDF
    For the zener... That is to protect the regulator from a higher voltage than it is designed to handle on the input. If you regulator can handle say 35 volts then a 22 volt zener would work, but what are the chances of the voltage going over 35 in a car? Z1 may not be needed. IMO
    Dave, I took the vocational progam through high school so yeah (switched to computers in college), I agree my '92 Jimmy will not generate 35 V, under normal circumstances. But that's the problem, car parts have been known to fail and cause the most unusual effects.
    If I can decipher all the sensor signals as planned, I will be spending a lot of time and energy on this project. I've already invested time and money as it is. If a potential problem only has a 0.01% chance of happening and it DOES occur, I'm gonna be one very ******ed off person if I skimped on a $2 safety component. I can afford a zener, it's not like I'm trying to survive on a student budget living in the boondocks (although that doesn't seem that far in the past ).
    I also have ZNRs and a few other types of surge/clamping devices on hand that I've ordered for other projects, I'm just not sure what rating I should use. But since the voltage regulator is supposed to handle up to a maximum of 30V, I assume it would be wise to use something that would start clamping at 15-20V. That way I'd stay away from pushing the voltage regulator to the extreme rating.
    Here is what you need.
    http://www.picbasic.co.uk/forum/show...14&postcount=7
    Bullet proof.
    TVS and/or Transorb are often use indeed. I suspect the TVS to be more "accurate" for this application.
    I've kept on tweaking the circuit, using only values I need as opposed to going-all-out.
    <IMG SRC="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=2537&d=1208975010">
    - SR503 schottkey, limits surges to 30V 5A to protect voltage regulator.
    - 1N5250 zener, limits surges further to 20V, well below LM1084 30V abs max and over 12-15V normal operating condition.
    - 1N5246 zener, limits surges to 16V, voltage divider is designed with a 16V max.
    I read about condensation in automotive applications. The circuits in my instrument cluster are covered in a clear product, but what about the in-circuit fuses and those in the fusebox? Those aren't covered and yet they don't pop a gasket when I have to scrape the INSIDE of my windshield. Are 5V logic circuits that much more sensitive as opposed to 12V automotive circuits?
    Side question: can I use ordinary water-based lacquer spray to protect the assembled circuit? Or do we really have to use the specialized products?
    Think about condensation. Warm moist air on one side of a barrier, something causing a cooling effect on the other. It matters where the device is placed. Take the radio for example. Placed in the dash. The air around the radio for the most part will be the same temperature as the air inside the radio. The case having "holes" in it to allow for air flow. If the radio was placed against the window or an uninsulated metal panel then you would have a problem.
    As long as it is dry before you power it up it should be fine. Anything non corrosive that will seal the board will work.
  1. Battery pack cell reader
    By steiner in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 06:41
  2. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 20:32
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  4. Measuring Battery voltage
    Last Post: - 3rd December 2006, 23:07
  5. Help with setting adcon1 for 16f877
    Last Post: - 16th August 2005, 11:13
