Quick n dirty HPWM out of phase
Results 1 to 15 of 15
    Thumbs up
    oooo, I Like it Keith.
    Feb 2003
    Sadly I cant take the credit.
    The idea was originally suggested by Melanie but it stuck in my mind because I have an device that uses the HPWM to generate an IR carrier which I then gate with a transistor. Too late to change my existing design but I will use the comparator to do the gating in a later revision of the board.
    Not only does it save a transistor and a couple of resistors but has a better voltage swing as well!
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Darn Melanie. She's just too smart for her own "Britches".
    Which is why I tend to envision her without them.
    Oh wait, I'd have done that anyways.
    At least you applied it to the right problem.
    Jul 2006
    That is a very elegant solution - just what I was looking for.
    Thanks, I will look in to this. The link to Melanie's post is very helpful. Since 0 Volts is "low voltage" it should work exactly the same - when the pulse goes low, the comparator output goes high.
    Brilliance is always in the simplicity...
    Jul 2006
    Thumbs up
    Just for the record. I followed through on this and the above idea (using the comparator) works great on a 16f877A with a 20Mhz crystal.
    I just tied the output of the HPWM pin to the Comparator input. I struggled with setting the registers properly because that part is still a bit greek to me (read - I had to experiment until I got what I wanted and then look at the data sheet to figure out WHY it did what it did.)
    The wave form is very sturdy and quite square all the way up to 15Khz. I even managed to figure out how to use one of the two ADC inputs the comparator shares on PortA.
    I'm learning. As an old dog, SLOWLY, but I'm learning....
    Thanks everyone,
    Chris Helvey
    Feb 2003
    Quote Originally Posted by ChrisHelvey View Post
    Glad you got it working.
    Tip! - Download the English version of the Datasheet
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Darrel really! In exchange for a really big bag of negotiable money all in nicely used notes etc etc (pics, noddy currency and vapourware doesn't count), I'll send you a signed naughty photo... *smiles*
  1. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 08:54
  2. VFD and HPWM
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 12th January 2009, 03:12
  3. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
