Quick n dirty HPWM out of phase
Results 1 to 15 of 15
    Jul 2006
    Default Quick n dirty HPWM out of phase
    Assuming a PIC with at least 2 PWM channels, can someone suggest a quick way to output two PWMs exactly 180 degrees out of phase with each other?
    I can do it by turning alternating pins on and off but there's no CPU left to do anything else without messing up the waveform.
    Trying not to recreate the wheel...or maybe it's so obvious I can't see the answer.
    Quote Originally Posted by ChrisHelvey View Post
    Hardware ways, flip flop, inverter, transistor . . . since you do not want to burden PIC.
    Use a PIC with an ECCP (ENHANCED CAPTURE/COMPARE/PWM MODULE)
    16F690 is one.
    Put it in Enhanced Half-Bridge mode.
    Outputs will be on P1A and P1B pins.
    Feb 2003
    How about a PIC with a Comparator. Feed the PWM into comparator and use the comparator output to give your out of phase signal.
    Advantages...
    No external components
    no software overhead other than setting up comparator
    Disadvantages...
    You lose one comparator and a few pins on your PIC
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Thumbs up
    oooo, I Like it Keith.
    Feb 2003
    Sadly I cant take the credit.
    The idea was originally suggested by Melanie but it stuck in my mind because I have an device that uses the HPWM to generate an IR carrier which I then gate with a transistor. Too late to change my existing design but I will use the comparator to do the gating in a later revision of the board.
    Not only does it save a transistor and a couple of resistors but has a better voltage swing as well!
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Darn Melanie. She's just too smart for her own "Britches".
    Which is why I tend to envision her without them.
    Oh wait, I'd have done that anyways.
    At least you applied it to the right problem.
    Jul 2006
    That is a very elegant solution - just what I was looking for.
    Thanks, I will look in to this. The link to Melanie's post is very helpful. Since 0 Volts is "low voltage" it should work exactly the same - when the pulse goes low, the comparator output goes high.
    Brilliance is always in the simplicity...
  1. 3 phase supply detector challenge
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 08:54
  2. VFD and HPWM
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 12th January 2009, 03:12
  3. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
  4. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
