Free Project - 245 LED Display
Results 1 to 40 of 222
    Apr 2007
    Exclamation
    So Trent, you say the circuit works just fine for you, but the schematic posted was wrong... did you mistake on purpose? Were we suposed to guess the error in it? I also build the circuit and it runs for me until the LED flashing part, now i can see it all so clearly why ...
    Italy
    I don't think so. The PDF file with the schematic is probably just
    a version made for the publication in a magazine so this is probably
    not the original schematic use by Trent to make his prototype PCB.
    @ skimask: Less arrogance, more humility!
    Best regards,
    Luciano
    May 2007
    next step luciano?
    T.Jackson's Avatar
    T.Jackson Guest
    Smile Luciano is correct again!
    That's right. I normally start off with something roughly hand drawn, sometimes nothing on paper at all - working directly off the top of my head, build a prototype then proceed to document it.
    Italy
    Hi Magu,
    For now use the seven 180 ohm resistors while testing.
    You will replace these resistors with the original 18 ohm
    resistors when the system works.
    While testing with the 180 ohm resistors:
    Once the LEDs are driven by the PIC it might be that, in order
    to see the LEDs, you will have to reduce the light in the room
    where you are testing. This will not be necessary once you replace
    the 180 ohm resistors with the original 18 ohm resistors.
    Modify your PCB, connect the pin 15 of IC3 to the
    pin 10 of IC7 via the 100k series resistor which is already
    present on the schematic.
    Place a 100nF capacitor close to each IC present on the circuit.
    This capacitor is connected to the pins VDD and GND of the IC.
    This capacitor must be close to the ICs. (Max. 10mm).
    Program the microcontroller with the HEX file posted by Trent in
    the first post of this thread.
    Plug all the ICs in their sockets. Follow the instructions posted
    by Trent. Power on the board and the circuit should work.
    Best regards,
    Luciano
    May 2007
    Quote Originally Posted by Luciano View Post
    Hi Magu,
    Best regards,
    Luciano
    it dosen`t work. i program the pic with ICPROG (plug the programer in serial port, open hex file, -> PRogram all)
    . these is a picture of the board with all the components included the caps. http://www.zamfirelu.org/led/board.jpg
    Italy
    Hi Magu,
    Remove the jumper "program". Do not use a jumper, use a push button.
    Best regards,
    Luciano
    May 2007
    Hi Magu,
    Best regards,
    Luciano
    i remove the jumper i i use a push button but doesen`t work. when i push the button the led light but doesen`t remain lighting.
    Apr 2007
    How about re-doing the scheme and posting it again, in the first post, if that is possible... , so that anyone trying to build it doesn't face the same problem; maybe they don't read the whole 3 pages of posts to see that there is a problem with it!
    Apr 2007
    Default True...
    But you can see clearly that the pdf is a print from OrCad or something that the circuit was made, so it has to be the one that the pcb was made of!
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  3. Replies: 2
    Last Post: - 14th July 2008, 23:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 01:07
  5. LCD will not start
