Free Project - 245 LED Display
Results 1 to 40 of 222
    May 2007
    Look, I feel for you, believe me I do. I know how trying things can be when you're first starting out, I was once a beginner too! If you're that determine to do this project, then my best advice to you is to get some "real-World" help from someone. Or, alternatively, read a book on electronics and PICs. Put the project aside until you've got some considerable more knowledge under your belt. As I've said before, this isn't a simple straight forward project, unless you've got a PCB for it.
    ok, i understand , now i have to make the pcb, connect the rez, cap, crystal, transiztors, then the pics (4017, 74hc08, eeprom), and then program the PIC and see if work...
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Why don't you put it off for a while - I'm actually planning on doing a KIT for a similar project to this. (Much, much better circuit that does more than just scroll a message) Plus, everything will mount on one large double sided through hole plated board w/silk screen printing on both sides. It will use 8 LED modules rather than the individual LEDs. Today I found a good source for low-cost PCBs. Basically, at the moment, Im in the "planing phase" of things with it, it'll be at least a year away, I need to save up some funds.
    May 2007
    today i`m making the pcb in orcad layout... and tomorow i will finish this pcb... then i see if it work or not...best regards...
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 06:14
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  3. Replies: 2
    Last Post: - 14th July 2008, 22:11
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 00:07
  5. LCD will not start
