This is the last post about the LEds test.
TEST 7
T7/Step 1:
All the ICs must be removed from the sockets, with the exception of
the 5V voltage regulator. The seven 18 ohm resistors must be replaced
with 180 ohm resistors.
In TEST 7 will will test all the LEDs driven by ROW6.
Connect P1 to the socket IC1/PIN8 (ROW6).
T7/Step2: Connect P2 to the socket IC7/PIN7 (COL35),verify the LED.
T7/Step3: Connect P2 to the socket IC7/PIN4 (COL34),verify the LED.
T7/Step4: Connect P2 to the socket IC7/PIN2 (COL33),verify the LED.
T7/Step 5: Connect P2 to the socket IC6/PIN9 (COL32),verify the LED.
T7/Step 6: Connect P2 to the socket IC6/PIN6 (COL31),verify the LED.
T7/Step 7: Connect P2 to the socket IC6/PIN5 (COL30),verify the LED.
T7/Step 8: Connect P2 to the socket IC6/PIN1 (COL29),verify the LED.
T7/Step 9: Connect P2 to the socket IC6/PIN10 (COL28),verify the LED.
T7/Step 10: Connect P2 to the socket IC6/PIN7 (COL27),verify the LED.
T7/Step 11: Connect P2 to the socket IC6/PIN4 (COL26),verify the LED.
T7/Step 12: Connect P2 to the socket IC6/PIN2 (COL25),verify the LED.
T7/Step 13: Connect P2 to the socket IC5/PIN9 (COL24),verify the LED.
T7/Step 14: Connect P2 to the socket IC5/PIN6 (COL23),verify the LED.
T7/Step 15: Connect P2 to the socket IC5/PIN5 (COL22),verify the LED.
T7/Step 16: Connect P2 to the socket IC5/PIN1 (COL21),verify the LED.
T7/Step 17: Connect P2 to the socket IC5/PIN10 (COL20),verify the LED.
T7/Step 18: Connect P2 to the socket IC5/PIN7 (COL19),verify the LED.
T7/Step 19: Connect P2 to the socket IC5/PIN4 (COL18),verify the LED.
T7/Step 20: Connect P2 to the socket IC5/PIN2 (COL17),verify the LED.
T7/Step 21: Connect P2 to the socket IC4/PIN9 (COL16),verify the LED.
T7/Step 22: Connect P2 to the socket IC4/PIN6 (COL15),verify the LED.
T7/Step 23: Connect P2 to the socket IC4/PIN5 (COL14),verify the LED.
T7/Step 24: Connect P2 to the socket IC4/PIN1 (COL13),verify the LED.
T7/Step 25: Connect P2 to the socket IC4/PIN10 (COL12),verify the LED.
T7/Step 26: Connect P2 to the socket IC4/PIN7 (COL11),verify the LED.
T7/Step 27: Connect P2 to the socket IC4/PIN4 (COL10),verify the LED.
T7/Step 28: Connect P2 to the socket IC4/PIN2 (COL9),verify the LED.
T7/Step 29: Connect P2 to the socket IC3/PIN9 (COL8),verify the LED.
T7/Step 30: Connect P2 to the socket IC3/PIN6 (COL7),verify the LED.
T7/Step 31: Connect P2 to the socket IC3/PIN5 (COL6),verify the LED.
T7/Step 32: Connect P2 to the socket IC3/PIN1 (COL5),verify the LED.
T7/Step 33: Connect P2 to the socket IC3/PIN10 (COL4),verify the LED.
T7/Step 34: Connect P2 to the socket IC3/PIN7 (COL3),verify the LED.
T7/Step 35: Connect P2 to the socket IC3/PIN4 (COL2),verify the LED.
T7/Step 36: Connect P2 to the socket IC3/PIN2 (COL1),verify the LED.
TEST 8
T8/Step 1:
In TEST 8 will will test all the LEDs driven by ROW7.
Connect P1 to the socket IC1/PIN7 (ROW7).
T8/Step2: Connect P2 to the socket IC7/PIN7 (COL35),verify the LED.
T8/Step3: Connect P2 to the socket IC7/PIN4 (COL34),verify the LED.
T8/Step4: Connect P2 to the socket IC7/PIN2 (COL33),verify the LED.
T8/Step 5: Connect P2 to the socket IC6/PIN9 (COL32),verify the LED.
T8/Step 6: Connect P2 to the socket IC6/PIN6 (COL31),verify the LED.
T8/Step 7: Connect P2 to the socket IC6/PIN5 (COL30),verify the LED.
T8/Step 8: Connect P2 to the socket IC6/PIN1 (COL29),verify the LED.
T8/Step 9: Connect P2 to the socket IC6/PIN10 (COL28),verify the LED.
T8/Step 10: Connect P2 to the socket IC6/PIN7 (COL27),verify the LED.
T8/Step 11: Connect P2 to the socket IC6/PIN4 (COL26),verify the LED.
T8/Step 12: Connect P2 to the socket IC6/PIN2 (COL25),verify the LED.
T8/Step 13: Connect P2 to the socket IC5/PIN9 (COL24),verify the LED.
T8/Step 14: Connect P2 to the socket IC5/PIN6 (COL23),verify the LED.
T8/Step 15: Connect P2 to the socket IC5/PIN5 (COL22),verify the LED.
T8/Step 16: Connect P2 to the socket IC5/PIN1 (COL21),verify the LED.
T8/Step 17: Connect P2 to the socket IC5/PIN10 (COL20),verify the LED.
T8/Step 18: Connect P2 to the socket IC5/PIN7 (COL19),verify the LED.
T8/Step 19: Connect P2 to the socket IC5/PIN4 (COL18),verify the LED.
T8/Step 20: Connect P2 to the socket IC5/PIN2 (COL17),verify the LED.
T8/Step 21: Connect P2 to the socket IC4/PIN9 (COL16),verify the LED.
T8/Step 22: Connect P2 to the socket IC4/PIN6 (COL15),verify the LED.
T8/Step 23: Connect P2 to the socket IC4/PIN5 (COL14),verify the LED.
T8/Step 24: Connect P2 to the socket IC4/PIN1 (COL13),verify the LED.
T8/Step 25: Connect P2 to the socket IC4/PIN10 (COL12),verify the LED.
T8/Step 26: Connect P2 to the socket IC4/PIN7 (COL11),verify the LED.
T8/Step 27: Connect P2 to the socket IC4/PIN4 (COL10),verify the LED.
T8/Step 28: Connect P2 to the socket IC4/PIN2 (COL9),verify the LED.
T8/Step 29: Connect P2 to the socket IC3/PIN9 (COL8),verify the LED.
T8/Step 30: Connect P2 to the socket IC3/PIN6 (COL7),verify the LED.
T8/Step 31: Connect P2 to the socket IC3/PIN5 (COL6),verify the LED.
T8/Step 32: Connect P2 to the socket IC3/PIN1 (COL5),verify the LED.
T8/Step 33: Connect P2 to the socket IC3/PIN10 (COL4),verify the LED.
T8/Step 34: Connect P2 to the socket IC3/PIN7 (COL3),verify the LED.
T8/Step 35: Connect P2 to the socket IC3/PIN4 (COL2),verify the LED.
T8/Step 36: Connect P2 to the socket IC3/PIN2 (COL1),verify the LED.
Once you have tested the 245 LEDs, post the results.
Best regards,
Luciano
