can someone help me with RCTIME
Results 1 to 26 of 26
    Yeah - I guess few people drive Ferraris as their first car, BS2 has its place. As far as the swap goes, I have never personally owned a BS2. I'd be more than happy to adopt some more 16f84's though. One of my old College teachers was mad into BS2. Come to think of it, he was a bit mad himself actually.
    So, are you are backing out of the swap!!! ?
    A man is only as good as his word.
    And now that we know you have never used a BS2, I guess your comments are based on ...
    May 2007
    Default the stamps place
    Well despite the fact that I have moved on to bigger and better things. The truth is without the BS2 I can pretty much say for sure I would have just given up before I got this far. I feel that for an initial look on microcontrollers it is a good initial investment. but I have moved on. ^^
    Apr 2006
    New Hampshire USA
    Default PIC16f785
    in case you're using a LDR (or high impedance analog source), i see some advantage of RCTime.. unless, i really don't. A simple transistor+few resistor + PIC adc, would be my solution if i need accuracy.
    Level detector? ---> PIC Comparator
    OR, PIC16F785 i've ordered a thousand of them yesterday, sOOOO much nice stuff on-board... built-in OP-AMP, 2 phase PWM + asynchronous feedback as a teaser...
    NEW TOY, NEW TOY
    PIC16F785 What do you like best about them? The op-amps? What type of projects will you use them for? Should we all get a bunch just to keep up?
    -Adam-
    Opamp is a REALLLY nice feature, i wasn't aware it was existing in one PIC.. but only voltage comparator & ADCs. Sure you could hack the voltage comparator with some feedback resistor, but my tests never give any good results... well not even close of what you should have with a op-amp.
    The Asynchronous PWM feedback (and 2 phase PWM) could be nice for some DC-DC converter, Motor control and for sure, some others.
    2 full independant analog comparator.. is a nice feature as well. There's also the REFCON and VRCON register which seems to add some nice stufff...
    There's also something i want to test.. the built-in voltage regulator..
    Don't worry, i did'nt read the whole thing really carefully
    Down side.. no USART, no MSSP... Oups!
    For analog stuff and power management, i think it's a really nice PIC.
    Time will tell...
  1. PULSIN & RCTIME resolution calculation
    Last Post: - 5th January 2010, 15:34
  2. POT and RCTIME instructions
    Last Post: - 14th November 2007, 16:47
  3. RCtime timeout
    By chriroz in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2007, 16:45
  4. RC - connection using RCTime produces strange results
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 17:16
  5. PULSIN and RCTIME
    By Dwayne in forum mel PIC BASIC Pro
    Last Post: - 4th November 2004, 15:45
