Timeout function
Results 1 to 14 of 14
    Jan 2006
    Istanbul
    Once In_STB = 0 then you might have had half a second passed not a full second.
    Or, if a full second is passed and you are in DataDone, then you might still have had In_STB = 1; then you come back immediately (possibly).
    Or, having a timer module running inside a WHILE statement will keep you and your Timer module locked in that WHILE statement. Thus, having a "PAUSE 1000" will do the same job for you cause the statement is locked anyway.
    T.Jackson's Avatar
    T.Jackson Guest
    Default Synchronous
    PAUSE is synchronous - meaning nothing else can be processed during its execution. At least not PBP code. Asynchronous on the other hand - (which is what you want in this case) - typically something that runs in the background, usually hardware-based interrupts, timers and so forth.
    <br/>
    May 2007
    can you please supply me with a example for my code using the timer.
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Take a look at this thread: http://www.picbasic.co.uk/forum/showthread.php?t=2129
    RTC has some primary TMR0 fundamentals that might help point you in the right direction.
    Jan 2006
    Istanbul
    <br/>
    This is what I said in a different way.
    Quote Originally Posted by sayzer View Post
    You could check 'Pause 1' for 1000 counts...that'll only lock up the program for 1 ms at a time, and end up giving a timeout of a bit over 1 second.
    Jan 2006
    Istanbul
    So the question is, does johnmiller want to have an independent counter running int the background? the sample code above seems to say "No".
    If we follow the sample code above, then the same code logic would also work with PAUSE 1000 or Pause 1 with 1000 counts as Skimask said.
    Tomato or Potaito.
    or was it tomato or tomaito
    Tomato or Potaito.
    That's what I'm thinking...and since the O/P said it doesn't have to be too accurate, that's why I suggested the Pause 1 w/ 1000 counts. He'll get 1000 1ms pauses, and the extra cycles used will bring it up to over a second, but well short of 2 seconds. He can trim the 1000 counts value later easily if needed.
    May 2007
    well I don't need it to be accurate in that time frame (0.9-2sec) but I can't pause it in the while. So my best guess it a timer, but I can't seem to be able to do it that way
    Quote Originally Posted by johnmiller View Post
    How long can you actually pause?
    Instead of a 1,000 count Pause, you could use a 1,000,000 PauseUs. Surely that would be fast enough to do what you want to do within 5-10us, which we still don't know what that is...
  1. Serin2 Timeout
    By tazntex in forum Serial
    Last Post: - 15th August 2008, 16:40
  2. Need help with timeout
    Last Post: - 10th June 2006, 16:38
  3. 16F628A Serin timeout and Timer1
    Last Post: - 27th March 2006, 00:20
  4. Serialin timeout
    By Nick in forum mel PIC BASIC Pro
    Last Post: - 18th April 2005, 16:21
  5. Random function - How to limit it ??
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 30th November 2004, 15:05
