Timeout function
Results 1 to 14 of 14
    Quote Originally Posted by sayzer View Post
    So the question is, does johnmiller want to have an independent counter running int the background? the sample code above seems to say "No".
    If we follow the sample code above, then the same code logic would also work with PAUSE 1000 or Pause 1 with 1000 counts as Skimask said.
    Tomato or Potaito.
    or was it tomato or tomaito
    That's what I'm thinking...and since the O/P said it doesn't have to be too accurate, that's why I suggested the Pause 1 w/ 1000 counts. He'll get 1000 1ms pauses, and the extra cycles used will bring it up to over a second, but well short of 2 seconds. He can trim the 1000 counts value later easily if needed.
    May 2007
    well I don't need it to be accurate in that time frame (0.9-2sec) but I can't pause it in the while. So my best guess it a timer, but I can't seem to be able to do it that way
    Quote Originally Posted by johnmiller View Post
    How long can you actually pause?
    Instead of a 1,000 count Pause, you could use a 1,000,000 PauseUs. Surely that would be fast enough to do what you want to do within 5-10us, which we still don't know what that is...
  1. Serin2 Timeout
    By tazntex in forum Serial
    Last Post: - 15th August 2008, 16:40
  2. Need help with timeout
    Last Post: - 10th June 2006, 16:38
  3. 16F628A Serin timeout and Timer1
    Last Post: - 27th March 2006, 00:20
  4. Serialin timeout
    By Nick in forum mel PIC BASIC Pro
    Last Post: - 18th April 2005, 16:21
  5. Random function - How to limit it ??
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 30th November 2004, 15:05
