Updating HPWM frequently, safe?
Results 1 to 40 of 79
    Quote Originally Posted by Darrel Taylor
    Seems to work pretty good here, but I've only had a day to play with it.
    One day to do all that? Wow, some 'over a month TicTacToe brain challenged programmer' will be impressed
    Feb 2005
    I just tested it using this code:
    '       Pic Configuration
    @ device pic12f683,INTRC_OSC_NOCLKOUT , wdt_on, mclr_off, protect_off
    '       Hardware configuration
    '       I/Os
    TRISIO = %00010010      ' pin1 is ADC , pin4 is the calibration button
    '       ADC's
    ANSEL = %00000010
    DEFINE ADC_BITS 10      ' ADCIN resolution  (Bits)
    DEFINE ADC_CLOCK 1      ' ADC clock source  (Fosc/8)
    DEFINE ADC_SAMPLEUS 11  ' ADC sampling time (uSec)
    ADCON0.7 = 1            ' Right justified results
    '       Comparator
    'CMCON0 = %00000111     ' Disable comparator
    'VRCON  = %00000000     ' disable
    cmcon0 = %00001110      ' Multiplexed Input with Internal Reference CIS=1
    vrcon  = %10001010      ' set vref=2.25v (from 4v input)
    include "HPWM10.pbp"
    ' definitions
    pote 		var word
    Frequency   var word  ' edited after original post per Darrel suggestion
    calibraled  var gpio.5
    gpio=0
    frequency=1000
    pause 50    ' coffee break
    for pote=1 to 1023
    @ HPWM10  1, _pote, _Frequency
    pause 10
    'gosub flashled
    next pote
    flashled:
    high calibraled     ' I use this to visually count each loop step
    pause 50
    low calibraled      ' by using it I saw that my switcher starts to
    pause 50            ' work at hpwm=4, less than that is too low
    high calibraled
    pause 50
    low calibraled
    pause 50
    high calibraled
    pause 50
    low calibraled
    pause 700
    Comments:
    I used the flashing led routine to know when my switcher started to work, it started at hpwm=4 which is great, the power led is very dim at this value.
    then I removed the flashing routine and something was too fast, because my switcher was off. So I added a little pause in there and it was solved, tried 1, 5 and settled in 10ms where it started to work again.
    This is great!, now I will test it with adcin
    pablo
    Both DutyCycle and Frquency MUST be WORD variables.
    I put it in the comments, but I should have mentioned it in the post too.
    That... Frequency con 1000 will cause problems.
    Feb 2005
    I just finished testing it with this code:
    '       Pic Configuration
    '       I/Os
    '       ADC's
    ANSEL = %00000010
    '       Comparator
    'cmcon0 = %00001110      ' Multiplexed Input with Internal Reference CIS=1
    'vrcon  = %10001010      ' set vref=2.25v (from 4v input)
    ' definitions
    pote 		var word
    Frequency   var word
    calibrapin  var gpio.4
    gpio=0
    frequency=1000
    loop:
    if calibrapin=0 then
        adcin 1, pote
        if pote>1000 then pote=1000
    pause 10
    goto loop
    The output is not steady when I use ADCIN, if I enable the calibrapin then it goes to steady mode.
    To generate the adcin values I used a 10k pot instead of the sensor Im using for simplicity sakes.
    Am I doing something wrong?
    Thanks!
    Pablo
    Can't tell ya! But as far i remind, the datasheet suggest a maximum impedance of 2.xxx Kohm.
    I tested my code on a EASYPIC 4 board with 10K trim pot... seems to work.
    Post your schematic but make sure your PSU is well filtered and is strong enough for your need first.
    Weird, weird, weird.
    Oh Great!
    Thanks for trying it Steve.
    It helps to know not all is lost.
    I think I've got a 683 around here somewhere.
    Maybe there's something I missed for the little guys.
    Feb 2005
    Im using this schematic:
    Im using a recently charged Li-Ion (3.635v measured under load using a good multimeter) all is mounted in a protoboard
    Using my last posted code the LED flickers, if I press the button it goes steady
    Thanks!
    mmm, yeah it works.. but a scope attach to show few glitches... mine too.
    Deeper analysis show that flicker go away if i don't turn off the PWM off before updating the duty cycle. So maybe i have those latest silicon version.. and why the datasheet no longer suggest to turn off the PWM module...
    aarrrggghh
    T.Jackson's Avatar
    T.Jackson Guest
    Post
    Yes, Mister_e, very impressive indeed.
  1. need help on hpwm
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 28th August 2007, 16:49
  2. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 16:05
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  4. HPWM and A to D interaction question 18F252
    By tcbcats in forum mel PIC BASIC Pro
    Last Post: - 10th May 2006, 04:50
  5. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
