well, now I have a new difficulty, trying to understand the calculator
Running OSC at 4mhz and PWM at 1khz I get:
And I found a post where Mister_e explains how to use it:
If I understand correctly what you posted, I can start the HPWM before the main loop by using for example: HPMW 0,0,1000 and then within the loop adjust just the dutycycle.Code:' ' 38KHz PWM @ 4MHZ using a PIC16F877 ' ---------------------------------- @ __CONFIG _XT_OSC & _LVP_OFF ' ' TRISC = 0 Duty var byte ' ' PWM SETUP ' ========= ' PicMultiCalc says.. ' Duty value for 50%=52 ' PR2 = 25 ' PRESCALLER 1:1 ' ' duty = 52 ' duty value for 50% duty cycle PR2 = 25 ' T2CON = %00000100 ' timer2 on, prescale 1:1 CCPR1L = duty>>2 ' MSB of duty cycle value CCP1CON=%00001100 | (dUTY<<5) ' set PWM mode and store the ' 2 LSB of duty SpinInRound: goto spininround
Now what I dont understand is how I change the duty cycle, by using the calc I get 1000 values, but the duty variable is defined as BYTE
I could use some help/hint
Thanks!
