877a and SPI
Results 1 to 13 of 13
Thread: 877a and SPI
    Dec 2006
    Cool
    I understand that the DosOnChip will handle Uart and SPI with I2c comming soon,
    As I stated previously I am already using the serial port for data to the PC, I would like to add SPI for datalogging.
    I am using a 16f877a and It only has one TX pin RC.6 I believe, looking at the other pins available and with the specs for th DosOnChip I have the ability for SPI, that is why I chose this part.
    Unless I am missing something and I can use another pin to TX serial data, this is my only option for now.
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by tico View Post
    This is exactly what you can do with the software serial comm. See the SERIN/SEROUT AND SERIN2/SEROUT2 sections of the manual. Also, do a search of the forum for these and you will have more info that you can use.
    SteveB
    Use HSERIN/OUT for the hardware serial pins, and SerIn/Out or SerIn2/Out2 and use seperate pins driven by software. Or forget about HSerIn/Out and use the software serial commands to handle it. If your code is sound and efficient enough, the software commands will handle it just fine. If it's sloppy, then you'll be fighting missed characters, getting out of sync, etc. But the DOSonChip has CTS/RTS pins and so does your PC...so you can use those to your advantage.
    Dec 2006
    Wink
    I am assuming that I need to use inverted mode for communication between the pic and DosOnChip module, can I also us the same method with resistors for rts/cts or should I use a max232.
    Dec 2006
    any regard to my questions, I would like to know that I am starting out right.
  1. Use the PIC 16f877 or 877A instead of shift registers.
    By tsanders in forum mel PIC BASIC Pro
    Last Post: - 27th October 2006, 18:23
