SOUND command and variable array
Results 1 to 13 of 13
    SWITZERLAND (french speaking)
    Acetronics,
    I'm not sure to understand your remark.
    I tried this:
    SOUND Speaker,[Vsnd(A),10]
    and
    SOUND Speaker,[Vsnd.0(A),10]
    and
    SOUND Speaker,(Vsnd[A],10)
    and
    SOUND Speaker,(Vsnd.0[A],10)
    In fact, I get a sound but it is a much lower frequency than compared to when I play the sound like SOUND Speaker,[121,10].
    Roger
    Default ... no comment.
    Tried THIS ???
    Vsnd var byte [4]
    Vsnd[0] = 121
    Vsnd[1] = 120
    Vsnd[2] = 119
    Vsnd[3] = 116
    FOR A = 0 to 3
    SOUND Speaker,[Vsnd[A],10]
    NEXT A
    Acetronics,
    I tried this:
    and
    and
    and
    Do you have a cap on the output like the manual suggests? What kind of speaker are you driving? What's you OSC? Which PIC are you using?
    speaker var portb.1:a var byte:for a=0 to 255:sound speaker,[a,50]:next a
    or maybe:
    vsnd var byte[3]:vsnd[0]=10:vsnd[1]=30:vsnd[2]=75:vsnd[3]=120
    a var byte:for a=0 to 3:sound speaker,[vsnd[a],50]:next a
    Wink It works!!!
    Thank you ACETRONICS,
    You gave me the correct syntax.
    Just to make sure, I tried this that works too:
    Vsnd var byte [4]
    Vsnd(0) = 121
    Vsnd(1) = 120
    Vsnd(2) = 119
    Vsnd(3) = 116
    FOR A = 0 to 3
    NEXT A
    I personally would have appreciate to see this kind of example in the Compiler's manual instead of bothering you... I read it a few times, but without any clear example, it stayed unclear to me.
    Thanks a lot for your help.
    Roger
    Wink
    Hi, Flotul
    Just remember the same things must have EXACTLY the same name ...
    I do not know if brackets and parenthesis (?) really work the same manner ... but manual says "Brackets" !!! ... so let's write Brackets !!!
    no bad surprises involved ...
    Default Right!
    Thank you for pointing this out.
    Manual shows "brackets" and this is maybe why I wanted to try with parenthesis too
    Again, there is almost anything needed in the manual - same as in the data-sheets.
    Unfortunately, it is not always comprehensible for beginners like me.
    Roger
