Tried Brackets Here also ???
Vsnd.0 = 121
Vsnd.1 = 120
Vsnd.2 = 119
Vsnd.3 = 116
Vsnd.0 is bit 0 of Byte Vsnd ( which is also different from Vsnd[A] !!! ) ... can't work properly here !!!
Vsnd.0 = 121
Vsnd.1 = 120
Vsnd.2 = 119
Vsnd.3 = 116
Acetronics,
I'm not sure to understand your remark.
I tried this:
SOUND Speaker,[Vsnd(A),10]
and
SOUND Speaker,[Vsnd.0(A),10]
and
SOUND Speaker,(Vsnd[A],10)
and
SOUND Speaker,(Vsnd.0[A],10)
In fact, I get a sound but it is a much lower frequency than compared to when I play the sound like SOUND Speaker,[121,10].
Roger
Tried THIS ???
Vsnd var byte [4]
Vsnd[0] = 121
Vsnd[1] = 120
Vsnd[2] = 119
Vsnd[3] = 116
FOR A = 0 to 3
SOUND Speaker,[Vsnd[A],10]
NEXT A
Do you have a cap on the output like the manual suggests? What kind of speaker are you driving? What's you OSC? Which PIC are you using?
speaker var portb.1:a var byte:for a=0 to 255:sound speaker,[a,50]:next a
or maybe:
vsnd var byte[3]:vsnd[0]=10:vsnd[1]=30:vsnd[2]=75:vsnd[3]=120
a var byte:for a=0 to 3:sound speaker,[vsnd[a],50]:next a
Thank you ACETRONICS,
You gave me the correct syntax.
Just to make sure, I tried this that works too:I personally would have appreciate to see this kind of example in the Compiler's manual instead of bothering you... I read it a few times, but without any clear example, it stayed unclear to me.Code:Vsnd var byte [4] Vsnd(0) = 121 Vsnd(1) = 120 Vsnd(2) = 119 Vsnd(3) = 116 FOR A = 0 to 3 SOUND Speaker,[Vsnd(A),10] NEXT A
Thanks a lot for your help.
Roger
Hi, Flotul
Just remember the same things must have EXACTLY the same name ...
I do not know if brackets and parenthesis (?) really work the same manner ... but manual says "Brackets" !!! ... so let's write Brackets !!!
no bad surprises involved ...
Thank you for pointing this out.
Manual shows "brackets" and this is maybe why I wanted to try with parenthesis too
Again, there is almost anything needed in the manual - same as in the data-sheets.
Unfortunately, it is not always comprehensible for beginners like me.
Roger
