SOUND command and variable array
Results 1 to 13 of 13
    SWITZERLAND (french speaking)
    Default SOUND command and variable array
    Hello,
    I'm (trying) playing sounds within an array.
    Unfortunately, I don't get it working.
    This is an extract of my (simplyfied) code.
    Vsnd var byte [4]
    Vsnd.0 = 121
    Vsnd.1 = 120
    Vsnd.2 = 119
    Vsnd.3 = 116
    FOR A = 0 to 3
       SOUND Speaker,[Vsnd.A,10]
    NEXT
    Any idea what I'm doing wrong?
    Roger
    Oct 2003
    holland
    try:
    FOR A = 0 to 3
    SOUND Speaker,[Vsnd(A),10]
    NEXT
    Tried this one already.
    Doesn't work either.
    This one doesn't work aswel:
    FOR A = 0 to 3
        SOUND Speaker,[Vsnd.0(A),100]
    NEXT
    Roger
    Oct 2003
    holland
    That is not what I typed.
    Did you give "speaker" a portnumber?
    Hi, Flotul
    What about Vsnd[A] instead ( Vsnd(A) or Vsnd.A ) ???
    Did you also check the tones are compatible with your speaker bandwidth ???
    just a thought ... for High audio frequencies.
    mat janssen,
    Don't worry: I copied/pasted your example "as it is" and it didn't work. I then posted another try I made. Sorry for the confusion.
    I tried with both brakets or parenthesis; never works....
    Yes, the sounds can be made correctly when not in this kind of referencing loop.
    Still searching.
    Roger
