Definately Squarewave. This is about a third of the way on the POT.
Well, before you change pics. Can you give this program a quick try.
It's just a single channel, no interrupts. It runs at about 3.8khz
It should give an indication whether the higher frequencies of hardware PWM will help or not.
@ __CONFIG _HS_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_OFF
DEFINE OSC 20
CLEAR
ANSEL=%00110001
CMCON=7
TRISA=%11111111        'set PORTA as all input
TRISC=%00000001        'set PORTC as all output apart from RC0
PWM1       VAR PORTC.2
DutyCycle1 VAR WORD
GoDone     VAR ADCON0.1
ADCON1 = %00110000
ADCON0 = %00000011
while GoDone : wend
  if ADRESH > 1 then
    high PWM1
    DutyCycle1 = ADRESH
    GoDone = 1
    pauseUS DutyCycle1
    low  PWM1
    pauseUS 255 - DutyCycle1
    while GoDone : wend
    low  PWM1
    GoDone = 1
    while GoDone : wend
goto Main
