Recommendations - Model Train Controller
Results 1 to 40 of 102
    Wink a small last trail ???
    Yeah that's what i thought too, hence why i buy few different model.
    Well, yes i hear some little noise which is more or less louder depending of the model... but there's always some noise when you play around the minimum low-voltage threshold.
    I tried higher PWM frequencies and it may cure some part of the problem on some voltage range and on some motor model. but it's certainly not perfect on ALL motor i have here.
    To me, in this specific case, a better choice could be to use some kind of linear regulation. Something around the following.
    <img src="http://www.picbasic.co.uk/forum/attachment.php?attachmentid=1396&stc=1&d=117175510 5">
    it have some good point and some bad ones. But do you really a 0-100% regulation? mmm
    Malc, don't worry... it's an interesting and funny thread.
    An idea... we could skip the PWM and use some I2C DAC...
    Hi, Steve
    Your design is to try with a low input RC constant in order to produce some kind of trapezoidal wave ... instead of the beautiful square wave.
    the problem lays in the slew-rate ... remember lentz's law ... the motor windings oppose an "electrical inertia" proportionnal to the slew-rate ...
    that will create some dissipation in the ballast ... but make less noise and heat.
    may be some "Mid freq" rectified sinus, used in burst mode could also do the job with minimal issues ( seen on the motor side ... LOL !!! )
    My motor theory is far far away... and never felt the need to understand it in the past
    interesting... thanks.
    Few interesting points in the followings ...
    http://homepages.which.net/~paul.hil...llersBody.html ok ok it's talking about a starter but anyways..
    http://ww1.microchip.com/downloads/e...tes/00770b.pdf
    malc-c's Avatar
    malc-c Guest
    Default Update
    Guys,
    Just thought you might want to see the prototype controler (only two channels)
    The 10K pot and reversing switch is connected via the 6-pin header infront of the power transistors. I've also left room for a small heatsink, but in tests so far these don't get hot enough to warrant one !
    The only problem is I'm still waiting on some 16F676's as I fried the only one i had in the breadboard... (got distracted by a phone call and connected the +12v to the PIC rather than the +5v !!! - it was glowing and had to cut short the call to pull the plug !!) - Tested the output stage and it works fine so can't see any reason for it not to work when the PIC's arrive.
    Looks good! Keep us posted!
  1. Microstepper controller
    By aratti in forum Schematics
    Last Post: - 3rd January 2015, 16:52
  2. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 20:33
  3. Replies: 2
    Last Post: - 14th July 2008, 22:11
  4. Model Train controller - revisited
    Last Post: - 8th May 2007, 09:40
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
