Using a MAX7219 (LED digit multiplexer) with a 16F88
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default Niet...
    Hi Darrel,
    No, I use "1" since I do not include any variables definiton file.
    If I'm not wrong, I read that "1" stands for MSBFirst in the PBP compiler manual.
    I also took big care to make short wiring and good power feed (caps) as stated in the MAX7219's datasheet.
    Btw, I clock my PIC at 4Mhz.
    Roger
    Hi Darrel,
    Do ya got the code handy for us to see, maybe a schematic we can look at?
    At 4mhz, the fastest you could shiftout (using the hardware) is 1mhz (if I remember right). So, assuming everything else is ok, you could run the PIC all the way up to 40mhz and be alright.
    I have to wonder why you aren't using a PIC to handle this job instead of the MAX7219 (besides having to develop a 2nd PIC application in addition to the one you're working on in the 1st place)?
    I can think of a couple of reasons, 1. learn something new, 2. possible free sample
    I like the 2. the best.
    Default You're absolutely right...
    I already thought about using my PIC to pilot the display. Isn't the MAX7219 a kind of µc itself, after all?
    But, due to my poor knowledge, I have problems to understand how I would do the MAX job's directly myself since I don't clearly understand how it exactly does the job; I just assume how it works.
    I have drawn the LED display matrix and then I noticed that I would have to adress each Digit (not segment) one by one and then display it for a very short period of time (maybe ns) and then adress the next Digit and so on.
    If this is correct, yes, I should do it with my PIC ("don't let others do what you can do yourself if you can do it at least as good as the other one"). This means, I'm ready to do all with my PIC if somebody can confirm my assumings.
    And NO, I paid CHF 16,25 (around $13.-) for my MAX7219. Sometimes people do silly things; I do often... Sorry.
    Roger
    Jan 2007
    Toronto
    Hi:
    I can provide some help with the MAX7219 if this thread is still active.
    I have used this chip in most of my 7 segment project since it is quite flexible.
    Let me know
    TimV
    Default any example welcome
    Hello TimV,
    I have made my project without the use of the MAX7219.
    But if you have any code example involving this chip, it would be nice.
    I still want to make my MAX7219 work...
    Thanks in advance.
    Roger
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. MAX7219 Helping Hand Please
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 14th February 2014, 16:07
  3. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  4. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  5. LCD will not start
