Using a MAX7219 (LED digit multiplexer) with a 16F88
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default Using a MAX7219 (LED digit multiplexer) with a 16F88
    Hello,
    I have some trouble making a 5 digit LED display working.
    The display is driven by a MAX7219 multiplexer. My PIC16F88 pilots (well, it should...) the MAX7219.
    The actual status is: when I powerup the circuit, the LED display shows up some digits and nothing more. The program should make the display count up from 00000 to 65535.
    Before I invastigate the program, I think I may have a timing problem.
    Can somebody tell my if, according to the MAX7219's datasheet (I have attached an extract), I need to set 10MHz clock frequency on the PIC yes or no?
    If yes, can I do it with my 16F88 and how?
    Roger
    No. That just means that you can clock data in at "UP TO" 10mhz.
    It will work at much lower data speeds too.
    The pic doesn't need to be running at that speed.
    Are you using MSBFIRST in your SHIFTOUT statements?
    Default Niet...
    Hi Darrel,
    No, I use "1" since I do not include any variables definiton file.
    If I'm not wrong, I read that "1" stands for MSBFirst in the PBP compiler manual.
    I also took big care to make short wiring and good power feed (caps) as stated in the MAX7219's datasheet.
    Btw, I clock my PIC at 4Mhz.
    Roger
    Hi Darrel,
    Do ya got the code handy for us to see, maybe a schematic we can look at?
    At 4mhz, the fastest you could shiftout (using the hardware) is 1mhz (if I remember right). So, assuming everything else is ok, you could run the PIC all the way up to 40mhz and be alright.
    I have to wonder why you aren't using a PIC to handle this job instead of the MAX7219 (besides having to develop a 2nd PIC application in addition to the one you're working on in the 1st place)?
    I can think of a couple of reasons, 1. learn something new, 2. possible free sample
    I like the 2. the best.
  1. Conway's Game Of Life
    Last Post: - 28th May 2020, 07:14
  2. MAX7219 Helping Hand Please
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 14th February 2014, 16:07
  3. Free Project - 245 LED Display
    Last Post: - 16th August 2009, 05:59
  4. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  5. LCD will not start
