K42 and Timer Interrupts
+ Reply to Thread
Results 1 to 9 of 9
    Aug 2011
    Default Re: K42 and Timer Interrupts
    Two things...
    Since you're using FOSC/4 as the source, set ASYNC bit in T0CON1.
    Also, when using 16 bit mode (MD16=1) you should always write TMR0H then TMR0L in that order so that the high byte is latched.
    looks like not reloading the tmr count every ms....... after first int, tmr counter looping from 0 .....???
    Sure it is. Inside the ISR, Timer 0 is stopped, reloaded and restarted.
    Two things...
    I think is it obligatory to use Fosc/4. Unless I misunderstood the DS. Then why is it necessary to use ASYNC=1? Could not fine any notes on the DS.
    Same for TMR0H. Is it in the DS this?
    Thank you for the suggestions, will test them the soonest.
    Aug 2011
    The SYNC block uses FOSC/4 as its sync clock, so it's difficult to use it if it's using FOSC/4 as its input source for counting too.
    for 16-bit read/write see sec 20.1.1.1:
    In 16-bit mode the operations should be: write TMR0H, TMR0L and read TMR0L, TMR0H
    Thanks for the explanation.
    I misinterpreted these paragraphs. My understanding was to have ASYNC cleared and use Fosc/4.
  1. Timer Interrupts
    By gadelhas in forum General
    Last Post: - 19th August 2011, 17:00
  2. fast timer block other interrupts?
    By flipper_md in forum mel PIC BASIC Pro
    Last Post: - 9th November 2010, 03:06
  3. Handling External/Timer Interrupts
    By Tacky3000 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2008, 12:09
  4. 3 Timer Interrupts Running simultaneously
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 20th February 2007, 04:49
  5. Timer overflows and interrupts
    By barkerben in forum General
    Last Post: - 18th December 2004, 02:42
Members who have read this thread : 14
