SOLVED - IOC works on B0 but not B5
+ Reply to Thread
Results 1 to 20 of 20
    Default Re: IOC works on B0 but not B5
    Quote Originally Posted by rocket_troy View Post
    I don't understand how you seem to have disabled the PPS for pins B0 and B5 without allocating something to them. Don't they need something allocated to them whether it's a port access or peripheral whatever if you plan to use the pins?
    Apologies, I'm still learning this stuff,
    Troy
    Yeah, so am I.
    I looked for a way to move "treat this like a GP pin" via PPS settings, but I don't see anything like that.
    Unless you just can't recycle CCP pins, unless you move another peripheral to it (which is very possible).
    Dec 2010
    Melbourne Australia
    Yeah, so am I.
    I was thinking outputs not inputs - [slapping forehead] my bad
    Troy
    Troy
    I'm no better; look at the previous post when I was blindly setting inputs when I was using outputs only.
    If MCC can produce all the config code, why not use this tool?
    For some reason I have not found why I am not able to use it on my PC. But I guess Richard can as we discussed that some time ago.
    If MCC can produce all the config code, why not use this tool? ...
    What is MCC, and what tool are you talking about?
    MCC is the tool. MPLAB Code Configurator.
    Select a device, select peripheral(s), select configuration for those peripheral(s) and it outputs configuration code for you (in C syntax).
    This tool comes in two flavors. Stand alone and plug-in for MPLABX
    Here it is https://www.microchip.com/en-us/tool...e-configurator
    There are tutorials also in YouTube
  1. Replies: 12
    Last Post: - 7th September 2024, 15:10
  2. Replies: 8
    Last Post: - 30th August 2024, 19:45
  3. Replies: 4
    Last Post: - 22nd March 2023, 11:32
  4. DS3231 works in one config, but does not works with other IC.
    Last Post: - 3rd December 2019, 19:52
Members who have read this thread : 11
