SOLVED - IOC works on B0 but not B5
Results 1 to 20 of 20
    Default Re: IOC works on B0 but not B5
    If MCC can produce all the config code, why not use this tool? ...
    What is MCC, and what tool are you talking about?
    MCC is the tool. MPLAB Code Configurator.
    Select a device, select peripheral(s), select configuration for those peripheral(s) and it outputs configuration code for you (in C syntax).
    This tool comes in two flavors. Stand alone and plug-in for MPLABX
    Here it is https://www.microchip.com/en-us/tool...e-configurator
    There are tutorials also in YouTube
  1. Replies: 12
    Last Post: - 7th September 2024, 15:10
  2. Replies: 8
    Last Post: - 30th August 2024, 19:45
  3. Replies: 4
    Last Post: - 22nd March 2023, 11:32
  4. DS3231 works in one config, but does not works with other IC.
    Last Post: - 3rd December 2019, 19:52
