Filtering noise from a wire
Results 1 to 31 of 31
    Default Re: Filtering noise from a wire
    MCP23017@400KHz , using a pic16 @32mhz can do that easily using mssp module
    using I2CREAD command. @32 mHz the cmd will do 166KHz at best, even at 64 MHz it will not reach 400kHz
    I've never used MSSP. At least now I know where I stand using the command.
    ...to read multiple rotary encoders with an MCP23017 the bus speed is the least of your problems , the hoops you need to jump through to track multiple edge transitions without error are extremely challenging....
    I am polling a controller for Flight Sim. I have multiple encoders on the circuit, but I do not expect more than 1 encoder to be active at the same time. I suppose with auto-pilot you could move 2 encoders at the same time, but there isn't an auto-pilot in this first plane (Cessna-152).
    ...16F1937 , why ? surely at least a 16f18875 would make tracking edges far easier. mind you its still difficult to keep track of more than one those 4 count per indent RE's
    13 will be interesting. ...
    Cost, size and availability at JLCPCB mainly. I want to make 100 units for the 1st batch, so every penny quickly adds up.
    ... have you tried any code to be sure a result is even viable with the encoders you have selected ?
    Not yet. My breadboards are crap, and my mini-CNC is not as useful as I hoped.
    I was going to get 5x PCBs from JLCPCB for testing. These are ordinary EC11 and EC10 (mouse wheel) encoders moved manually, it's NOT mechanically manipulated.
    The controllers will look something like this:
    Well, why not select from Mouser or Digikey?
    The price at JLCPCB is unbeatable by North American suppliers, as long as JLCPCB has the item in stock. Choosing PICs was probably the hardest thing, cause prices vary a lot depending on model, and then quickly rise when you go outside JLCPCB.
    - most likely will switch from 16F1936/37 to 16F18855 for secondary PIC; every pin can be On Interrupt,
    - 16F18877 is useful to handle both switches and ADC (7 pots on the right enclosure),
    - 16F1459 will be most likely used for USB communication and primary PIC.
    I'll be assembling all pots, switches and encoders myself since JLCPCB does not seem to beat prices from Alibaba.
    If you know another affordable PIC with so many IOC pins, please let me know.
  1. Noise on input signal
    By fanman in forum mel PIC BASIC Pro
    Last Post: - 28th February 2012, 03:55
  2. Notch filtering
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2010, 17:45
  3. Noise on OSC pins.
    By Tobias in forum General
    Last Post: - 31st December 2009, 02:29
  4. Input Noise
    By PJALM in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 20:26
  5. Loop noise
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 20th October 2005, 13:19
