Noise on input signal
Results 1 to 18 of 18
    May 2011
    Red face Noise on input signal
    Hi guys,
    new to this so looking for advice. I have a PIC16F88 that has been configured to receive analog inputs on pin 12 using ADCIN command and then strobe a LED as an output on pin 8 using HIGH/LOW commands. I noticed that when the LED strobes, it induces the strobe signal on the analog input. I have played around with the circuit to ensure good ground planes exist etc but still same problem. Has anyone experienced this before and how can I eliminate it?
    thanks
    mark.
    May 2008
    Italy
    Default Re: Noise on input signal
    If you want real help, you have to post the circuit.
    Cheers
    Al.
    May 2011
    Sure Al, please see attached image. Thanks Mark.
    May 2008
    Italy
    Did you set all the unused pins as outputs (using the tris register) and set them to low? If not please do it! Never leave floating inputs. If they cannot be set as outputs, then you must ground them.
    Cheers
    Al
    May 2011
    Hi Al,
    Went back and grounded the unused pins. Still get the pulse on the analog signal. Anything else I missed?
    cheers
    Mark.
    May 2008
    Italy
    Is C11 (decoupling) connected directly to pin 14 ?
    Add a large capacitor to the output of your regulator ( say 220 uF)
    X5-3 point goes to a pic pin. Is it an input? If yes and you have nothing connected to the terminal, then you have to ground or pullup also X5-3
    Cheers
    Al
    Dec 2007
    Finland
    Another vote for pull-up or pull-down (some high but reasonable value would be OK). Floating input will see your LED transient (voltage/current change) and interpret that as an input signal (=working as a sensitive receiver).
    -Gusse-
    Feb 2011
    Michigan, USA
    If X5-2 is power to your sensor, then maybe try a capacitor there.
    But first I would try what aratti said and use bigger caps by the regulator.
    Mike -
    May 2011
    Thanks guys. I will try your suggestions. I will double check the TRIS registers to ensure they have the correct setting. By the way C11 is connected directly to Pin 14 and the input signal is from a low impedance source.
    Bombay, India
    You need to check your grounding paths. If this circuit is built on a breadboard, it may not be easy to resolve this. Ground loops are a concern in most ADC problems. Try to get your ground routed like this
    Input -> 7805 -> Output transistor -> Microcontroller.
    Any changes in this sequence can contribute to the problem.
    Another possible problem is the rate at which you read the ADC. Do you filter the readings you get ??
    May 2011
    Hi Jerson, yep have tried ground planes on a PCB. Slight improvement but same issue. Good point regarding sampling rate. Its 50us as defined in the code. The source has inbuilt filtering. I don't use any averaging of the sampled data.
    Someone online mentioned that the PWM setting can affect the ADC?
    thanx
    Bombay, India
    No, the 50uS is the sampling time. If you happen to read your ADC at varying intervals(due to different paths of code execution), that affects the reading stability. Try to put the ADC read inside an ISR so that it reads at a constant rate. Then perhaps the coupling will break and get you stable readings.
    May 2011
    Hmmm...have tried the suggestions and still same problem. The interference is definitely induced by the strobe pulse. When the strobe is not triggered the signal is fine. Very strange.
    Bombay, India
    can you post your code? Might help identify any issues in code if present.
    Dec 2010
    Another vote for adding a large capacitor to the output of your regulator to supply the fast transient current demand when the LED comes on. Choose a type that has low ESR / ESL such as a ceramic in the 1-10 uF range. Leave the 0.1 where it is. You can prove if it's current induced noise or a software problem by either removing the LED, or making it's series resistor about 10X larger temporarily. Are you seeing the noise on the Power pin of the PIC too?
    May 2011
    Hi guys, I rechecked the circuit last night. I made the following changes to the bread board,
    1) Connected unused pins to each other then to ground.
    2) Set unused pins to LOW state.
    3) Set TRIS registers to output for unused pins.
    4) Changed the capacitors on the 7805 to ceramics.
    and after this the circuit worked fine. The pulse traced was still there but is was <<1mV which is good enough for me.
    I tried the 220uF capacitor but the 7805 and 16F88 started overheating so figured that wasn't a good idea. Maybe 7805 oscillation? The noise is originating from the power source and can be eliminated by using a battery supply.
    It was interesting that before grounding the unused pins I measured the signal from them and found that they had a low level sinusoidal output (about 0.3V p-p I think). However when I grounded them it seemed to dampen the interference. So all is good. Thanks to everyone for their suggestions.
    cheers
    mark.
    May 2011
    Hey guys,
    Was just reading online that some people tie each unused pin to ground using a resistor (about 1k)? I tied mine directly to ground. Is this the correct method?
    http://www.piclist.com/techref/logic/xtrapins.htm
    c
    heers
    Mark.
    Apr 2007
    Pennsylvania, USA
    The only real benefit I know if with using a resistor, if you accidentally set the pin to a high state, the pin will be fried due to a direct short to ground. With a resistor the current will be limited and prevent damage to the pin.
    Shawn
