Filtering noise from a wire
Results 1 to 31 of 31
    Default Re: Filtering noise from a wire
    Then using shielded cables or wraping with copper foils like these may help on this...
    I already have a lot of manual tasks required to assemble a single unit. I would probably get shielded wire; something like this.
    I haven't searched for prices. I just took a pic of the first one I found.
    But first I want to test to see exactly what I'm facing.
    Case in point: these guys say a 10 meter wire is an antenna, but under 10 cm is nothing to be worried about (under normal circumstances).
    https://www.eevblog.com/forum/beginn...54/#msg3863054
    My longest wires might not even be longer than 10cm. I'm just starting the I/O Expander circuit (it's going to sit "somewhere" in the middle of a bunch of switches//buttons).
    what is the shortest switch activation period that you would expect to need to detect and how quickly do you need to respond ?
    generally any key press under 50mS i would just ignore . for basically "static" switches 200 0r 300 mS would be more than adequate
    why care about noise and debouncing if quick responses are not required
    The only issue I can think of is that I have rotary encoders. Nothing is preventing the user from turning 2 encoders at the same time while on auto-pilot.
    There's also the possibility of someone flying with a co-pilot/navigator; that could mean the "possibility" of up to 4 encoders moving at the same time. I want to be ready for that.
    My goal is to undercut the market by a wide margin. It's very possible someone with vested interests would try their best to find "bugs" with my product, and drag my name on flight sim groups.
    For example: back in college during the late 70ies, Burroughs brought in a main-frame but we thought it sucked. So most a lot of computer students flooded the queues with duplicates of their jobs. The techs from Burroughs were not prepared; the machine failed, badly, and IBM came back. We didn't have vested interests, we were just goofballs, but we did crash the system.
    Just look at this thing; couple of switches and 3 LEDs for $140CAD. That's insane. That's worth something like $20 at most. There's very few competition, so they pretty much do as they please.
    I'm not the next Delorean, but I still expect resistant.
    rotary encoders are a completely different story to switches, you have virtually no chance of reading multiple re's via i/o extenders with any confidence that steps and direction changes won't be missed
    Regarding the Rotary encoders Richard covered it 100%.
    With shielded wires I am pretty sure you won't have any problems. Forget about R's and C's, just read two times the switch state and your are done with debounce.
    As for long or short wires acting like antennas, well, the general statement "long wires act like antenna" is not quite right. It depends on the frequency we are talking about. For example, 10cm may seem very short, but this is an antenna for 750MHz and the 10m is an antenna for 7.5Mhz. So, which one may be a problem for you? It depends on what signal sources you have nearby, right?
    Best way to deal with all frequencies is both cable shielding and metal case box wherever there is a possibility of interference.
    But I think we are getting crazy on this...
    Aug 2011
    +1
    If you're trying to use an IO expander to do that good luck!
    Challenge accepted 😁
    I didn't have real world data yet. Here's the switch with the longest activation period mounted on a test PCB:
    (similar to this switch, yellow circuit, about 10cm end to end)
    Name:  B3F-4055 trace.png
    5vdc with 10:1 probe
    .1 volt / division
    .2 ms / division
    Name:  B3F-4055 at 0.2ms on PCB.jpg
    It takes 5 divisions for a press, so 1 millisecond end to end. The other switches take about 0.3 to 0.6 ms.
    It has a blurry bounce of under 2 sub-divisions at the top (∼0.07ms), I saw at least one other press with a bounce twice as long (it was out of focus - I didn't save it).
    I wasn't able to get any rising edges for some reason. I'm sure that has to do with the trigger settings, but I just don't know how to do that, yet.
    This is what I get probed directly to an identical unconnected switch:
    Name:  B3F-4055 at 0.2ms DIRECT.jpg
    It took a lot less time to activate, under 0.5ms. I assume this is what you guys meant about traces acting as antennas.
    At least now I have an idea of what sort of activation times and switch bounce that I'm facing. I really had no clue what sort of activation delays I was facing (never got this far in a project).
    Now I need to test from a secondary PCB, out using wires (max 10cm) to a 1" x 1" switch PCB, and back to the secondary PCB.
    That will give me actual data using the planned hardware.
  1. Noise on input signal
    By fanman in forum mel PIC BASIC Pro
    Last Post: - 28th February 2012, 03:55
  2. Notch filtering
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2010, 17:45
  3. Noise on OSC pins.
    By Tobias in forum General
    Last Post: - 31st December 2009, 02:29
  4. Input Noise
    By PJALM in forum mel PIC BASIC Pro
    Last Post: - 28th February 2006, 20:26
  5. Loop noise
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 20th October 2005, 13:19
