Serin Not Recognizing Qualifier From Another PIC
Results 1 to 24 of 24
    Dec 2019
    Stuart, FL USA
    Default Serin Not Recognizing Qualifier From Another PIC
    Hi Experts,
    I have a very simple task to perform. I need to pass a couple of bytes from one PIC12F683 to another PIC12F683 and can't get it to work! I've tried everything that I could think of and can't pinpoint the problem. I am using GPIO.5. I have been very successful with SERIN in other projects. In fact, I am receiving packets from a radio receiver using GPIO.0 on this same PIC and it works fine. For some reason GPIO.5 is not cooperating.
    The Weak Pullup on GPIO.5 (DataOut) pin is enabled and the data is transmitted and received True". My idle state is in the "Mark" condition (High).
    The TX PIC sends this -
    Serout DataOut,1,[ProgID,IDByte] ' Xmit Qualifier and new ID
    The TX PIC is sending the packet out. I have my oscilloscope connected to verify it. I don't think the Qualifier is being recognized or processed. What am I missing???
    Receiver Code -
    ; set CONFIG1 for internal oscillator, watchdog on, MCLR pin as OFF
    __config _WDTE_ON & _MCLRE_OFF & _INTOSCIO & _PWRTE_ON
    OSCCON = 100000 ' Set system clock 4MHz(1MHz internal w/x4 PLL enabled)
    DEFINE OSC 4 ' Calibrate PBP timing to 4MHz system clock
    OPTION_REG = 000000 ' Enable Weak Pullups Control
    WPU = 100000 ' Disable all Weak Pullups except GPIO.5
    ANSEL = 0000 ' No analog inputs
    TRISIO = 1001 ' Make GP1, GP2 outputs. GP0, GP3, GP4 & GP5 = inputs
    CMCON0 = 0111 ' Turn off comparators
    ADCON0 = 0 ' Turn off A/D
    IDByte var byte ' Receiver ID.
    AlarmByte var Byte ' Received Alarm
    AlarmVal var byte ' Alarm Zone(s)
    RxIn var GPIO.0 ' Incoming Packet Port
    Z1Alarm var GPIO.2 ' Zone1 Alarm LED
    Z2Alarm var GPIO.1 ' Zone2 Alarm LED
    ByteSum var Byte ' IDByte & AlarmByte Sum Value
    ChkSum var byte ' ChkSum value to test
    ProgID var byte ' Programmer Present Verify
    PrgIn var GPIO.5 ' Programmer Detect & Data Port
    IDByteRx var byte ' New IDByte
    ProgIDRx var byte ' Received Programmer ID
    MainLoop:
    Serin PrgIn,1,5000,PassProg,[ProgIDRx],IDByteRx ' Wait for 5 seconds for new I.D. to arrive
    if ProgIDRx = $A THEN GOSUB UpdateID ' Verify arrival and execute UpdateID Subroutine
    PassProg: ' No Packet received - Timeout reached - Jump out and repeat
    PAUSE 500
    GOTO MainLoop
    UpdateID:
    Z1Alarm = 1 : Z2Alarm = 1 ' LEDs to Confirm programing Subroutine
    PAUSE 500
    Z1Alarm = 0 : Z2Alarm = 0 ' Turn off LEDs
    PAUSE 1000
    Z1Alarm = 1 : Z2Alarm = 1 ' LEDs to Confirm in programing mode
    PAUSE 1000
    IDByte = IDByteRx
    Write 1, IDByte ' Write new ID to EEPROM
    I appreciate your help. Thank you!
    Default Re: Serin Not Recognizing Qualifier From Another PIC
    I have not looked closely at your code yet and I don't know if this will make any difference but I did react to the following:
    Please note that the WPU is turned off when pin is configures as an output. See section 4.2.2 in the datasheet.
    Apart from that, are both PICs on the same PCB, sharing the same power supply and, more importantly, the same ground?
    Dec 2019
    Stuart, FL USA
    Thank you Henrik for you prompt reply.
    The Receiver PIC's GPIO.5 is indeed configured as an input and the two systems do share a common ground.
    Transmit PIC - GPIO.2 is set as an output and the outbound packet is sent by SEROUT DataOut,1,[ProgID,IDByte]
    Receive PIC
    - GPIO.5 is set as an input and is configured to receive the packet by SERIN
    I didn't include the transmitter PIC code because the oscilloscope verified that the packet is being sent.
    I wonder... what logic state should SERIN be idling at? I have it at logic high to generate a "mark" condition.
    two thoughts looking at your code.........
    ...ProgIDRx = $A............ did you CLEAR ProgIDRx after reception and might need to be ....$"A" not sure but
    Dec 2019
    Stuart, FL USA
    Hi Amgen,
    Thanks for the reply. Yes, ProgIDRx is cleared. And its value is $A (or10). But, I haven't been able to receive it yet because nothing is being received. SERIN always exits upon the 5 second Timeout variable "PassProg" as if nothing is present at the pin.
    And, in addition, If I had noise on the pin, SERIN would never time out. So, that indicates that SERIN is, at least, partially working, I would think.
    Dec 2010
    Melbourne Australia
    I don't really use serin so I can't be of much help, but just to educate me: isn't the contents inside the square brackets a qualifier or filter - like the WAIT modifier in serin2?
    Troy
    one easy thing to do to troubleshoot your system....... add a temporary serout for the receiving 283 to see receptions and get all that working first as you continue with the rest of your code.... (I know you know all this) but it is like proofing the functions as you go along
    Dec 2019
    Stuart, FL USA
    Hi Troy,
    Yes, the bracketed variable is the qualifier. SERIN won't receive or pass the data until it recognizes the presence of the qualifier in the received packet. For some reason, my qualifier is not being recognized or, GPIO.5 isn't correctly configured for SERIN? Or, something else???
    Dec 2019
    Stuart, FL USA
    Thanks Amgen. Good advice!
    Dec 2019
    Stuart, FL USA
    Still no progress. Beating my head against my desk on this one!
    if using 12f683 ..... check your OSCCON ..... no PLL on 12f683 unless there is new 12f....
    Dec 2010
    Melbourne Australia
    Quote Originally Posted by JESmitter View Post
    Hi Troy,
    Then, don't you need to nominate the qualifier as being something? like:
    Serin PrgIn,1,5000,PassProg,["ABC"],IDByteRx ' Wait for 5 seconds for "ABC" to arrive then put contents in IDByteRx?
    Troy
    Dec 2019
    Stuart, FL USA
    Hi Troy,
    Here's my OSCON
    OSCCON = %01100000 ' Set system clock 4MHz(1MHz internal w/x4 PLL enabled)
    My SERIN SYNTAX
    SERIN PrgIn,1,5000,PassProg,[ProgIDRx],IDByteRx ' Check for new I.D.
    My Qualifier Variable
    ProgIDRx VAR BYTE ' Received Programmer ID
    My Byte of interest
    IDByteRx VAR BYTE ' New IDByte
    This should work, right???
    Dec 2019
    Stuart, FL USA
    Hi Amgen,
    I don't recall why I included a PPL in my oscillator comment but, I believe that I have my OSCON statement correct for an internal 4 MHz cock. Right?
    OSCCON = %01100000 ' Set system internal clock 4MHz.
    Thank you for pointing that out!
    looks right now, ...... first post was unsure for OSCCON..... no wait !!!!! check for ... $01100001, bit 0, system clock ,,, but looks like you had it right UNLESS the configuration setting didn't set properly, so can use this one which calls for system to use int osc...... good fkin luck if all that fails
    Dec 2019
    Stuart, FL USA
    This is a photo of the packet (8N1) generated by my PIC transmitter and that for some reason is not being received by my PIC receiver port GPIO.5. It's a two byte transmission $A and $61. Its in "true" format with idling level at +5VDC (Mark condition).
    SERIN is not recognizing it... Why?
    Dec 2010
    Melbourne Australia
    Hi Troy,
    Here's my OSCON
    My SERIN SYNTAX
    My Byte of interest
    Well, that's what I'm confused about. Don't you need to actually nominate something as the qualifier rather than an empty variable?
    p207 of the manual:
    "list of data items to be received may be preceded by one or more qualifiers enclosed within brackets. SERIN must receive these bytes in exact order before receiving the data items. If any byte received does not match the next byte in the qualifier sequence, the qualification process starts over (i.e. the next received byte is compared to the first item in the qualifier list). A Qualifier can be a constant, variable or a string constant. Each character of a string is treated as an individual qualifier."
    So, if you have an empty variable as a qualifier, I guess serin is waiting for a "null" to arrive before accepting anything into IDByteRx.
    That's the way I read it, but again, I've never really used serin.
    Troy
    Dec 2019
    Stuart, FL USA
    Hi Troy,
    I understand what you're saying. But I do declare ProdIDRx as a Byte variable in the beginning of the program as "ProgIDRx VAR BYTE".
    What am I missing here?
    Dec 2010
    Melbourne Australia
    Hi Troy,
    Yes, I'm aware you declare it, but you don't assign anything to it. It's there as a newly declared variable with the contents of null. So, I'm guessing serin is waiting for a null character to arrive in your serial stream before accepting anything into your receiving placeholder. That's my interpretation of what I'm reading anyway.
    Troy
    works perfectly for me if you don't try to use qualifier before you actually set it to a meaningful value as rocket troy indicated
    #CONFIG; set CONFIG1 for internal oscillator, watchdog on, MCLR pin as OFF
    OSCCON = %  01100000 ' Set system clock 4MHz
    DEFINE OSC 4 '  PBP timing to 4MHz system clock
    OPTION_REG.7 = 0 ' Enable Weak Pullups Control
    WPU = %  00100000 ' Disable all Weak Pullups except GPIO.5
    ANSEL = 0 ' No analog inputs
    TRISIO = %  00111001 ' Make GP1, GP2 outputs. GP0, GP3, GP4 & GP5 = inputs
    CMCON0 = %  00000111 ' Turn off comparators
    ProgIDRx = $d  '   define qualifier
    gpio=0
    MainLoop:
    Serin PrgIn,1,[ProgIDRx],IDByteRx ' Wait  for new I.D. to arrive
    GOTO MainLoop
    UpdateID:
    PAUSE 500
    PAUSE 1000
    PAUSE 1000
    IDByte = IDByteRx
    'Write 1, IDByte ' Write new ID to EEPROM
    ENd
    Dec 2019
    Stuart, FL USA
    Hi Richard,
    Thank you and appreciate for your input.
    The function of this program is to allow the reprogramming of the Receiver's ID.
    The program is structured to provide a five second period of time upon power up of the Receiver to allow the attachment of a PIC based programmer (My design) to reprogram the ID of the respective receiver before the programs "MainLoop" begins.
    I added your modifications and still couldn't get it to work. BTW, why the GPIO=0? Does that clear all GPIO ports, I presume?
    Below is the modified code.
    ********************** Receiver Code *********************************
    OPTION_REG =% 00000000 ' Enable Weak Pullups Control
    WPU =% 00100000 ' Disable all Weak Pullups except on GPio.5
    ANSEL = %000000 ' No analog inputs
    TRISIO = %111001 ' Make GP1, GP2 outputs. GP0, GP3, GP4 & GP5 = inputs
    CMCON0 =%000111 ' Turn off comparators
    Pause 500 ' Pause for Register initialization
    ProgIDRx = $D ' Define qualifier
    GPIO=0
    Z2Alarm = 1 'Confirm in programing mode
    Serin PrgIn,1,5000,MainLoop,[ProgIDRx],IDByteRx ' Check for new I.D.
    if ProgIDRx = $A then ' Match Programmer ID
    IDByte = IDByteRx
    Write 1, IDByte
    Z1Alarm = 1 : Z2Alarm = 1 ' Confirm programing Subroutine
    Z1Alarm = 1 : Z2Alarm = 1 'Confirm in programing mode
    ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; START ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
    MainLoop:
    I suspect that I may have a protocol issue in that my packet isn't in proper form for SERIN? Below is a JPG of my oscilloscope screen showing the packet received from the Programmer (Transmitter).
    Thank you for your help!
    you misunderstand how the qualifier works
    this can not work as you set the qualifier to 0x0d as per my example , ProgIDRx will always be 0x0d
    untill you change it , serin will never change it
    if ProgIDRx = $A then ' Match Programmer ID ;;// will always fail
    this time out loop is pointless in this example as serin with [a qualifier ] will always block until the input qualifier is received
    this will do the same thing
    MainLoop:
    Serin PrgIn,1,[ProgIDRx],IDByteRx ' Check for new I.D.
    IDByte = IDByteRx
    Write 1, IDByte
    goto MainLoop
    note i used 0x0d AS a qualifier as its easer to use than 0x0a in proteus simulator
    u need to either change it back to 0x0a or alter the tx code to match
    yes because at power up the alarm leds could be in any random state if you don't
    Dec 2010
    Melbourne Australia
    Maybe all you want then is just:
    Serin PrgIn,1,5000,MainLoop, ProgIDRx
    Troy
    Dec 2019
    Stuart, FL USA
    Hi Troy,
    You were right on in assuming that I misunderstood how the Qualifier works. With your help, now I do!
    I've modified the program accordingly and now it works perfectly!
    Thank you for taking your valuable time to assist me!
    Thanks to all who responded to my post. This is a great website and support forum!
  1. RF Module Qualifier, CRC?
    By tazntex in forum Serial
    Last Post: - 22nd March 2010, 16:15
  2. HSERIN qualifier
    Last Post: - 14th December 2009, 11:53
  3. ICSP not recognizing..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 20:31
  4. recognizing a serin2 string
    By ehertz in forum Serial
    Last Post: - 9th September 2006, 03:24
  5. Herin Qualifier
    By MORAND in forum mel PIC BASIC Pro
    Last Post: - 5th May 2004, 16:56
