Serin Not Recognizing Qualifier From Another PIC
Results 1 to 24 of 24
    Dec 2019
    Stuart, FL USA
    Default Re: Serin Not Recognizing Qualifier From Another PIC
    Thanks Amgen. Good advice!
    Dec 2019
    Stuart, FL USA
    Still no progress. Beating my head against my desk on this one!
    if using 12f683 ..... check your OSCCON ..... no PLL on 12f683 unless there is new 12f....
    Dec 2019
    Stuart, FL USA
    Hi Amgen,
    I don't recall why I included a PPL in my oscillator comment but, I believe that I have my OSCON statement correct for an internal 4 MHz cock. Right?
    OSCCON = %01100000 ' Set system internal clock 4MHz.
    Thank you for pointing that out!
    looks right now, ...... first post was unsure for OSCCON..... no wait !!!!! check for ... $01100001, bit 0, system clock ,,, but looks like you had it right UNLESS the configuration setting didn't set properly, so can use this one which calls for system to use int osc...... good fkin luck if all that fails
    Dec 2019
    Stuart, FL USA
    This is a photo of the packet (8N1) generated by my PIC transmitter and that for some reason is not being received by my PIC receiver port GPIO.5. It's a two byte transmission $A and $61. Its in "true" format with idling level at +5VDC (Mark condition).
    SERIN is not recognizing it... Why?
    works perfectly for me if you don't try to use qualifier before you actually set it to a meaningful value as rocket troy indicated
    #CONFIG; set CONFIG1 for internal oscillator, watchdog on, MCLR pin as OFF
     __config _WDTE_ON & _MCLRE_OFF & _INTOSCIO & _PWRTE_ON
    OSCCON = %  01100000 ' Set system clock 4MHz
    DEFINE OSC 4 '  PBP timing to 4MHz system clock
    OPTION_REG.7 = 0 ' Enable Weak Pullups Control
    WPU = %  00100000 ' Disable all Weak Pullups except GPIO.5
    ANSEL = 0 ' No analog inputs
    TRISIO = %  00111001 ' Make GP1, GP2 outputs. GP0, GP3, GP4 & GP5 = inputs
    CMCON0 = %  00000111 ' Turn off comparators
    IDByte var byte ' Receiver ID.
    IDByteRx var byte ' New IDByte
    Z1Alarm var GPIO.2 ' Zone1 Alarm LED
    Z2Alarm var GPIO.1 ' Zone2 Alarm LED
    ProgIDRx var byte ' Received Programmer ID
    PrgIn var GPIO.5 ' Programmer Detect & Data Port
    ProgIDRx = $d  '   define qualifier
    gpio=0
    MainLoop:
    Serin PrgIn,1,[ProgIDRx],IDByteRx ' Wait  for new I.D. to arrive
    GOSUB UpdateID ' Verify arrival and execute UpdateID Subroutine
    GOTO MainLoop
    UpdateID:
    Z1Alarm = 1 : Z2Alarm = 1 ' LEDs to Confirm programing Subroutine
    PAUSE 500
    Z1Alarm = 0 : Z2Alarm = 0 ' Turn off LEDs
    PAUSE 1000
    Z1Alarm = 1 : Z2Alarm = 1 ' LEDs to Confirm in programing mode
    PAUSE 1000
    IDByte = IDByteRx
    'Write 1, IDByte ' Write new ID to EEPROM
    ENd
    Dec 2019
    Stuart, FL USA
    Hi Richard,
    Thank you and appreciate for your input.
    The function of this program is to allow the reprogramming of the Receiver's ID.
    The program is structured to provide a five second period of time upon power up of the Receiver to allow the attachment of a PIC based programmer (My design) to reprogram the ID of the respective receiver before the programs "MainLoop" begins.
    I added your modifications and still couldn't get it to work. BTW, why the GPIO=0? Does that clear all GPIO ports, I presume?
    Below is the modified code.
    ********************** Receiver Code *********************************
    DEFINE OSC 4 ' Calibrate PBP timing to 4MHz system clock
    OPTION_REG =% 00000000 ' Enable Weak Pullups Control
    WPU =% 00100000 ' Disable all Weak Pullups except on GPio.5
    ANSEL = %000000 ' No analog inputs
    TRISIO = %111001 ' Make GP1, GP2 outputs. GP0, GP3, GP4 & GP5 = inputs
    CMCON0 =%000111 ' Turn off comparators
    ADCON0 = 0 ' Turn off A/D
    AlarmByte var Byte ' Received Alarm
    AlarmVal var byte ' Alarm Zone(s)
    RxIn var GPIO.0 ' Incoming Packet Port
    ByteSum var Byte ' IDByte & AlarmByte Sum Value
    ChkSum var byte ' ChkSum value to test
    ProgID var byte ' Programmer Present Verify
    Pause 500 ' Pause for Register initialization
    ProgIDRx = $D ' Define qualifier
    GPIO=0
    Z2Alarm = 1 'Confirm in programing mode
    Serin PrgIn,1,5000,MainLoop,[ProgIDRx],IDByteRx ' Check for new I.D.
    if ProgIDRx = $A then ' Match Programmer ID
    IDByte = IDByteRx
    Write 1, IDByte
    Z1Alarm = 1 : Z2Alarm = 1 ' Confirm programing Subroutine
    Z1Alarm = 1 : Z2Alarm = 1 'Confirm in programing mode
    ;;;;;;;;;;;;;;;;;;;;;;;;;;;;; START ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
    MainLoop:
    I suspect that I may have a protocol issue in that my packet isn't in proper form for SERIN? Below is a JPG of my oscilloscope screen showing the packet received from the Programmer (Transmitter).
    Thank you for your help!
    you misunderstand how the qualifier works
    this can not work as you set the qualifier to 0x0d as per my example , ProgIDRx will always be 0x0d
    untill you change it , serin will never change it
    if ProgIDRx = $A then ' Match Programmer ID ;;// will always fail
    this time out loop is pointless in this example as serin with [a qualifier ] will always block until the input qualifier is received
    this will do the same thing
    MainLoop:
    Serin PrgIn,1,[ProgIDRx],IDByteRx ' Check for new I.D.
    IDByte = IDByteRx
    Write 1, IDByte
    goto MainLoop
    note i used 0x0d AS a qualifier as its easer to use than 0x0a in proteus simulator
    u need to either change it back to 0x0a or alter the tx code to match
    yes because at power up the alarm leds could be in any random state if you don't
    Dec 2010
    Melbourne Australia
    Maybe all you want then is just:
    Serin PrgIn,1,5000,MainLoop, ProgIDRx
    Troy
    Dec 2019
    Stuart, FL USA
    Hi Troy,
    You were right on in assuming that I misunderstood how the Qualifier works. With your help, now I do!
    I've modified the program accordingly and now it works perfectly!
    Thank you for taking your valuable time to assist me!
    Thanks to all who responded to my post. This is a great website and support forum!
    Dec 2019
    Stuart, FL USA
    Hi Troy,
    Here's my OSCON
    OSCCON = %01100000 ' Set system clock 4MHz(1MHz internal w/x4 PLL enabled)
    My SERIN SYNTAX
    SERIN PrgIn,1,5000,PassProg,[ProgIDRx],IDByteRx ' Check for new I.D.
    My Qualifier Variable
    ProgIDRx VAR BYTE ' Received Programmer ID
    My Byte of interest
    IDByteRx VAR BYTE ' New IDByte
    This should work, right???
    Dec 2010
    Melbourne Australia
    Quote Originally Posted by JESmitter View Post
    Hi Troy,
    Here's my OSCON
    My SERIN SYNTAX
    My Byte of interest
    Well, that's what I'm confused about. Don't you need to actually nominate something as the qualifier rather than an empty variable?
    p207 of the manual:
    "list of data items to be received may be preceded by one or more qualifiers enclosed within brackets. SERIN must receive these bytes in exact order before receiving the data items. If any byte received does not match the next byte in the qualifier sequence, the qualification process starts over (i.e. the next received byte is compared to the first item in the qualifier list). A Qualifier can be a constant, variable or a string constant. Each character of a string is treated as an individual qualifier."
    So, if you have an empty variable as a qualifier, I guess serin is waiting for a "null" to arrive before accepting anything into IDByteRx.
    That's the way I read it, but again, I've never really used serin.
    Troy
    Dec 2019
    Stuart, FL USA
    Hi Troy,
    I understand what you're saying. But I do declare ProdIDRx as a Byte variable in the beginning of the program as "ProgIDRx VAR BYTE".
    What am I missing here?
    Dec 2010
    Melbourne Australia
    Hi Troy,
    Yes, I'm aware you declare it, but you don't assign anything to it. It's there as a newly declared variable with the contents of null. So, I'm guessing serin is waiting for a null character to arrive in your serial stream before accepting anything into your receiving placeholder. That's my interpretation of what I'm reading anyway.
    Troy
  1. RF Module Qualifier, CRC?
    By tazntex in forum Serial
    Last Post: - 22nd March 2010, 17:15
  2. HSERIN qualifier
    Last Post: - 14th December 2009, 12:53
  3. ICSP not recognizing..
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 11th June 2008, 21:31
  4. recognizing a serin2 string
    By ehertz in forum Serial
    Last Post: - 9th September 2006, 04:24
  5. Herin Qualifier
    By MORAND in forum mel PIC BASIC Pro
    Last Post: - 5th May 2004, 17:56
