Controlling OG-4 Decathron with PBP in an efficient way.
Results 1 to 40 of 40
    Default Re: Controlling OG-4 Decathron with PBP in an efficient way.
    And stop using HIGH/LOW, those waste both time and space.
    The animation can most likely be done with two FOR loops. An outer that steps thru the starting position from 1 to 29 and an inner that "sweeps the circle" one revolution starting/stopping at the dot pointed to by the outer loop.
    If I'm not mistaken the effect you're after is similar to the the common "please wait the computer is busy" circle thingy you see on Windows systems?
    You can't do it with two FOR loops, because you have to consider the reset pin and fact that number of dots is even, but number of control pins is odd. So it is always required to add an extra step out of loop, depending on even/odd current position.
    The effect I'm making is as follows. Rotation starts from dot 1 and comes again to dot 1, stops there for a second, then quickly rotates one full loop, but stops at dot #1. Waits for a second, full spin and stop at dot #2 and so on, till it makes full turn.
    If you say so :-)
    Do you have a datasheet describing the driving signals, I'm having some difficulties understanding how it works based on your description.
    I have only Russian book about it. But principle of operation is nicely shown in animation here:
    https://threeneurons.wordpress.com/dekatron-stuff/
    And stop using HIGH/LOW, those waste both time and space....
    Well, I have some doubts about this. If it relates to output port registers I think it is necessary to use High/Low commands. Or at least this used to be the case with older versions of PBB.
    Direct control of port registers like this portb.0=1 may cause problems when the program is long because of memory page issues. I may be wrong here. Anyone?
    the only problem with high/low is that they waste time and code space setting/clearing the tris register ,every time they are invoked.
    the only issue with direct port writes once you have the tris reg set appropriately is the potential for rmw issues , especially at high clock speeds.
    always use lat regs if possible and a shadow reg otherwise if rapid sequential port manipulation of individual pins will be employed
    OK
    Most everything PIC made in the past decade features LATx Registers;
    LATB.0 = 1
    (Of course you could also insert a bit of ASM if FOSC cycles are important
    @ BANKSEL LATB
    @ BSF LATB,0
    For this particular case, speed is not an issue, since these tubes have couple of KHz max operating frequency, and in my case there are Pause 30 and Pause 1000 statements
    Run into strange problem - setting GPIO.5 as input messes with GPIO.4 - it becomes high when GPIO.5 is read, so disrupts complete code routine. I'm using TRISIO=%00100000 to make GPIO.5 as input. If I disable it as input, then other code works fine.
    OK
    In your code at the top of the page you list TRISIO=%00001000. Of course GPIO.3 is MCLR and is Input only. In the previous post you state you are having problems with TRISIO=%00100000. It's probably not your issue, but try TRISIO=%00101000.
  1. Subroutine or repeated code, which is more memory efficient?
    Last Post: - 5th June 2014, 22:38
  2. large & efficient electro magnet
    By therian in forum Off Topic
    Last Post: - 19th October 2012, 06:53
  3. Making code more efficient, any ideas please?
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 26th July 2011, 13:28
  4. Efficient comparison on data (iButton)
    By enigma in forum mel PIC BASIC Pro
    Last Post: - 27th August 2010, 13:37
  5. Is there a more efficient way?
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 25th July 2005, 23:38
