Need to get 4 independently controllable frequency outputs, PBP can do that?
Results 1 to 15 of 15
    Default Re: Need to get 4 independently controllable frequency outputs, PBP can do that?
    4 separate PIC's with NCO modules. Done..... Why add unnecessary hardware?
    EN82fn
    OK
    I have a project I was using 3 PICs for 3 NCOs. I updated it adding a touch screen to replace buttons & LEDs, and while at it, replaced 3 PICs with a single PIC18F27Q43 (have to use MPLABX & XC8 since PBP doesn't yet cover that part). That still leaves one more NCO for you.
    and 3 extra PIC chips does not count as extra hardware, but CD4536 does?
    Please,Please explain how you are going to get a single CD14536 to support 4 independent frequency's. I must be REAL stupid.....
    EN82fn
    Either 4 pics or 4 CD4536...
    He meant that in either case you need 4 chips. PIC's need also programming but CD.. need some parts.
    CD does not need any extra part. Frequency input of all 4 is connected to PICs HPWM output, which allows to do some extra things - since all these frequencies will be driving stepper motors, having them controlled by master clock (HPWM) will allow to make smooth startup and stopping
    OK
    I still think you can do it with Timers. For a Timer 2/4/6, adjust the PR2 for your frequency. For Timer 1/3/5, adjust TMR1H_L for your frequency. Clear the IF & Toggle the output, and reset TMR1H_L in the ISR. For TMR2/4/6, you don't even need to reload PR2. Newer PICs with HLT can to that in the background without so much as an interrupt.
  1. Single PIC to Blink 5 LEDs Independently?
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 18th July 2015, 17:56
  2. 4 x PWM outputs
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 7th February 2012, 07:40
  3. help with multiple outputs...
    By rickvan in forum mel PIC BASIC Pro
    Last Post: - 25th November 2007, 18:34
  4. frequency meter in PBP
    Last Post: - 13th June 2007, 07:34
  5. PIC16F62X outputs
    By Deadeye in forum General
    Last Post: - 31st May 2005, 22:20
