Need to get 4 independently controllable frequency outputs, PBP can do that?
Results 1 to 15 of 15
    OK
    Default Re: Need to get 4 independently controllable frequency outputs, PBP can do that?
    If you're not married to the PIC16F886, there are newer MCUs that might be able to meet your goals. Assuming a 50% duty cycle is desired, let's look at all the available Functions found on various PICs that would be capable of generating a square wave output.
    1 - Of course, CCP using the PWM function
    2 - Some PICs offer separate PWM SFRs in addition to the CCP
    3 - CLC: using the Flip Flop Mode, any timer could be fed into a CLC to generate PWM output
    4 - Timers where the Interrupt Handler Toggles the output
    5 - Numerically Controlled Oscillator (NCO)
    6 - Signal Measurement Timer
    7 - If you don't need all PWM outputs simultaneously, Peripheral Pin Select can change which pins output the PWM
    There are probably at least 1 or 2 I'm missing, but the point is to think outside the CCP box. Some PICs have upwards of 4 CCP modules, some up to 4 CLC, some have as many as 10 Timers, short of the new PIC18FxxQ43, only 1 NCO is available. You may be able to mix and match to achieve your goals.
    In addition to more Functions, newer PICs have more stable Internal Oscillators, Peripheral Pin Select, and are almost always way cheaper. You can use Microchip's Part Selector Guide (or whatever they call it) to find PICs that meet your needs:
    https://www.microchip.com/ParamChart...branchID=30048
    If you can accept frequencies up to only 1KHz, then the PCA9685 chip can output 16 pwm channels and is controlled by I2C bus.
    I need 4 outputs simultaneously, at different frequencies and w/o putting any load into "main" code execution.
    PCA9685 can output different dutycycle, but not frequency. There are a lot of such IC's with adjustable separate duty cycle, but not frequency (I even have 48 channel monster - LT8500)
    The only suitable chips I've found are FM synthesis chips from early computer soundcards, like Yamaha YMF262 or AY-3-8910 But they require extra periphery and are loaded with unnecessary bells and whistles. Looks like CD4536B (4 of them) is the best choice so far.
    Nice chip this seems. But could not figure out how to use it as an PWM.
    I don't need PWM, I need frequency
    4 separate PIC's with NCO modules. Done..... Why add unnecessary hardware?
    EN82fn
  1. Single PIC to Blink 5 LEDs Independently?
    By RossWaddell in forum mel PIC BASIC Pro
    Last Post: - 18th July 2015, 17:56
  2. 4 x PWM outputs
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 7th February 2012, 07:40
  3. help with multiple outputs...
    By rickvan in forum mel PIC BASIC Pro
    Last Post: - 25th November 2007, 18:34
  4. frequency meter in PBP
    Last Post: - 13th June 2007, 07:34
  5. PIC16F62X outputs
    By Deadeye in forum General
    Last Post: - 31st May 2005, 22:20
