4 bit 7 segment display with two 74HC595
Results 1 to 24 of 24
    Default Re: 4 bit 7 segment display with two 74HC595
    Could you point to an example of that?
    me too
    I have never had to do that and can find no mention of that short coming anywhere
    anyways here is my take on the 7 seg display
    if you have a chip with mssp why waste time and code space when the hardware can do it for you
    I cheated a bit and did it in asm for speed and size gains
    no nasty pauses , all gone
    my displays are common anode so the data is inverted see comments
    '*  Name    : 4 bit 7 segment display                           *
    '*  Author  : RICHARD                                           *
    '*  Notice  :                                                   *
    '*  Date    : 18. 2. 2018                                       *
    '*  MCU     : PIC 16F1825 @32MHZ                                *
                 __config        _CONFIG1,    _FOSC_INTOSC & _CP_OFF & _WDTE_ON  &  _PWRTE_ON  &  _MCLRE_ON  & _CLKOUTEN_OFF
                  __config      _CONFIG2, _PLLEN_OFF & _LVP_OFF
     goto overasm
     asm
    timer1  = TMR1L
    seg_val
        addwf   PCL, F
        retlw  0xc0;0B11000000     0
        retlw  0xf9;0B11111001     1
        retlw  0xa4;0B10100100     2
        retlw  0xb0;0B10110000     3
        retlw  0x99;0B10011001     4
        retlw  0x92;0B10010010     5
        retlw  0x82;0B10000010     6
        retlw  0xf8;0B11111000     7
        retlw  0x80;0B10000000     8
        retlw  0x90;0B10010000     9
     endasm
     overasm:
    DEFINE OSC 32            ; Use internal clock
    ANSELC=0
    SSP1CON1=$22
    SSP1STAT=$40
    OSCCON=$f0
    TRISC = %11101010
    LPIN var portc.4         ; Latch
    DPIN var portc.2         ; Data  SDO
    CPIN var portc.0         ; Clock SCK
    segment var byte
    value var word
    d_index var byte
    buff var byte[5]
    tmp var byte
    d_pointer      var byte
    timer1 var word ext
    timer1_reload con    1543      ;8mS
        INT_Handler TMR1_INT, _DISP, ASM, yes
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    T1CON = $1
    d_index=0
    ;---[simple counter 0 - to 9999]------------------------------------------------
    for value = 0 to 9999
    arraywrite buff ,[dec4 value]
    next value
    value = 0
    GOTO Main
    ;---[TMR1 - interrupt handler]--------------------------------------------------
    DISP:
    asm
        MOVE?CT 0, T1CON, TMR1ON ; 1 stop timer
        MOVLW LOW(_timer1_reload) ; 1 Add TimerReload to the
        ADDWF TMR1L,F ; 1 value in Timer1
        BTFSC STATUS,C ; 1/2
        INCF TMR1H,F ; 1
        MOVLW HIGH(_timer1_reload) ; 1
        ADDWF TMR1H,F ; 1
        MOVE?CT 1, T1CON, TMR1ON ; 1 start timer
        MOVE?CB  high _buff, FSR0H         ;load highbyte
        MOVE?CB  low  _buff, FSR0L         ;load low byte
        MOVE?BA  _d_index
        ADDWF  FSR0L,F
        MOVLW 0X30
        SUBWF INDF0,W
        L?CALL seg_val
        MOVE?AB _segment
        MOVE?BB  _d_index ,_tmp
        BANKSEL   _tmp
        MOVLW 1
        ADDWF  _tmp,F
        BANKSEL   _d_pointer
        CLRF _d_pointer
        BSF STATUS ,C
    N_BIT
        BANKSEL   _d_pointer
        RLF    _d_pointer,F
        BCF STATUS ,C
        BANKSEL   _tmp
        DECFSZ  _tmp,F
        GOTO N_BIT
        MOVLW 1
        BANKSEL  _d_index
        ADDWF  _d_index,F
        MOVLW 3
        ANDWF  _d_index,F
        BANKSEL  LATC
        BCF LATC ,4
        BANKSEL PIR1
        BCF     PIR1,3
        BANKSEL  _segment
        COMF    _segment,W  ;COMMENT USED TO INVERT DATA FOR COMMON ANODE DISPLAY
        BANKSEL SSP1BUF
        movwf   SSP1BUF
        BANKSEL PIR1
        BTFSs   PIR1,3
        GOTO    $-1
        BANKSEL  _d_pointer
        COMF    _d_pointer,W ; ;COMMENT USED FOR COMMON ANODE DISPLAY
        BANKSEL PIR1
        BCF     PIR1,3
        BANKSEL SSP1BUF
        movwf   SSP1BUF
        BANKSEL PIR1
        BTFSs   PIR1,3
        GOTO    $-1
        BANKSEL  LATC
        BSF LATC ,4
        BANKSEL 0
        INT_RETURN
    endasm
    Last edited by richard; - 19th February 2018 at 12:18. Reason: convert to english instead of gibberish
    OK
    OK, looked through a K50 and 16F1619 Data Sheet for that note or catch phrase indicating a full write to TxCON is recommended after writing to the TMRxH/L registers and cannot find it. It might be for an older processor, or maybe I read it on a forum somewhere and now it's that propagating myth. Sorry.
    Hello Richard, thanks for response. Your code is probably for 4 digit 7 segment display where the segments is driven via 74HC595 shift register, and the common anodes via transistors directly from MCU or for multiplexing a bare display whitout driver right?
    Look at mi first post, my display is driven by two 74HC595 shift register, one for segments, and the second for digits (like common anodes/cathodes).
    To send data I used:
    SHIFTOUT DPIN, CPIN, MSBFIRST,[ones,%0001]  ;(segment pattern, digit position)
    Now I tring to find more elegant way to extract ones, tens, hundreds and thousands like my previous solution:
    setdisp:
    segment = value//10
    gosub look
    ones=segment            ; extract ones
    segment =  value/10
    segment = segment//10
    gosub look
    tens=segment            ; extract tens
    segment =   value/100
    gosub look
    hundreds=segment        ; extract hundreds
    segment = value/1000
    gosub look
    thousands=segment       ; extract thousands
    Can you help me with it?
    wrong , my code is for your circuit but using a different pic chip . I don't have a 12f1840 on hand but I cannot see any reason for it not to work on that chip . if you use the right pins.
    your code is for common anode mine common cathode the commented lines can be changed to suit
    COMF _segment,W for common Anode becomes MOVF _segment,W
    COMF _d_pointer,W for common Anode becomes MOVF _d_pointer,W
    ie the current is reversed in the display
    here is a 12f1822 version
    with full hex [upper and lower case] space and - sign also
    note comments for common anode/cathode
    '*  Notice  :                                                   *
    '*  MCU     : PIC 12F1822 @32MHZ                                *
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
     goto overasm
    timer1  = TMR1L
    seg_val
        CHK?RP  _TM_TMP
        MOVWF   _TM_TMP
        SUBLW   0x21
        btfsc   STATUS, C
        retlw   0   ;" "
        MOVF    _TM_TMP,W
        SUBLW   0x2f
        btfsc   STATUS, C
        retlw   64   ;"-"
        MOVF    _TM_TMP,W
        MOVLW   0X40
        SUBWF   _TM_TMP,W
        btfsC   STATUS, C
        GOTO    TM_ALPHA
        MOVF    _TM_TMP,W
        ANDLW   0X0F
        GOTO    TM_LU
    TM_ALPHA
        ANDLW   0xdf    ;ucase
        SUBLW   6
        btfsS   STATUS, C
        retlw   0       ;ERROR
        MOVLW   0X37
        SUBWF   _TM_TMP,W
        ANDLW   0xdf    ;ucase
    TM_LU
        BRW
        retlw 	0X3F    ;0
        retlw 	6
        retlw 	0X5B
        retlw 	0X4F
        retlw 	0X66
        retlw 	0X6D
        retlw 	0X7D
        retlw 	7
        retlw 	0X7F
        retlw 	0X67    ;9
        retlw 	0X77    ;A
        retlw 	0X7C    ;b
        retlw 	0X39    ;C
        retlw 	0X5E    ;d
        retlw 	0X79    ;E
        retlw 	0X71    ;F
    endasm
     overasm:
    ANSELA=0
    SSP1CON1=$22
    SSP1STAT=$40
    OSCCON=$70
    TRISA = %11111000
    @LPORT=LATA
    LPIN CON 2     ;var LATC.4         ; Latch
    DPIN var porta.0         ; Data  SDO
    CPIN var porta.1         ; Clock SCK
    segment var byte
    value var word
    d_index var byte
    buff var byte[5]
    tmp var byte
    TM_TMP    var byte
    d_pointer      var byte
    timer1 var word ext
    T1CON = $1
    d_index=0
    ;---[simple counter 0 - to ffff]------------------------------------------------
    for value = 0 to 65535
    arraywrite buff ,[HEX4 value,0]
    next value
    value = 0
    GOTO Main
    DISP:
    asm
        INCF TMR1H,F ; 1
        ADDWF TMR1H,F ; 1
        MOVE?BA  _d_index
        ADDWF  FSR0L,F
        MOVF   INDF0,W
        L?CALL seg_val
        MOVE?AB _segment
        BANKSEL   _tmp
        MOVLW 1
        ADDWF  _tmp,F
        BANKSEL   _d_pointer
        CLRF _d_pointer
        BSF STATUS ,C
    N_BIT
        BANKSEL   _d_pointer
        RLF    _d_pointer,F
        BCF STATUS ,C
        BANKSEL   _tmp
        DECFSZ  _tmp,F
        GOTO N_BIT
        MOVLW 1
        BANKSEL  _d_index
        ADDWF  _d_index,F
        MOVLW 3
        ANDWF  _d_index,F
        BANKSEL  LPORT
        BCF LPORT ,_LPIN
        BANKSEL PIR1
        BCF     PIR1,3
        BANKSEL  _segment
        MOVF    _segment,W
        ;COMF    _segment,W  ;COMMENT USED TO INVERT DATA FOR COMMON ANODE DISPLAY
        BANKSEL SSP1BUF
        movwf   SSP1BUF
        BANKSEL PIR1
        BTFSs   PIR1,3
        GOTO    $-1
        BANKSEL  _d_pointer
        COMF    _d_pointer,W
        ;MOVF    _d_pointer,W  ;COMMENT USED FOR COMMON ANODE DISPLAY
        BANKSEL PIR1
        BCF     PIR1,3
        BANKSEL SSP1BUF
        movwf   SSP1BUF
        BANKSEL PIR1
        BTFSs   PIR1,3
        GOTO    $-1
        BANKSEL  LPORT
        BSF LPORT ,_LPIN
        BANKSEL 0
        INT_RETURN
    endasm
    Thanks Richard, that code works, but that is a way more difficult understand to me because ASM and so on.
    A few things I've noticed when I tried the code:
    - your code is a way shorter in MCU memory like mine, which is good
    - multiplex is a bit slower I see some flickers
    - if I put in to the "value" variable mumber "1234" the display shows "4321"
    of course I changed this line
    to
    arraywrite buff ,[DEC4 value,0]
    Anyway, it is a good example how the skilled programmer thinks, and how a beginner thinks.
    Last edited by louislouis; - 19th February 2018 at 23:49. Reason: My English is terrible, will we go to Hungarian :-)
    the refresh rate is 8mS to speed it up to 4mS change timer1_reload to 33543
    sic
    the digit scan direction can be reversed easily and would result in even smaller code
    the difference with this method is that the mcu can now do other tasks and not spend all its time being just a display controller
    Yes that's great, now the MCU has a way more time to do other tasks which I write using my poor skills in picbasic.
    Probably this piece of your code will be used in my future projects with that type of 7 segment displays.
    Thanks.
    digit order reversed,scan 4mS
    and I moved the lookup out of the isr into the foreground (reduce isr overhead)
    '*  Notice  :                                                   *
     goto overasm
    seg_val
        CHK?RP  _TM_TMP
        MOVWF   _TM_TMP
        SUBLW   0x21
        btfsc   STATUS, C
        retlw   0   ;" "
        MOVF    _TM_TMP,W
        SUBLW   0x2f
        btfsc   STATUS, C
        retlw   64   ;"-"
        MOVF    _TM_TMP,W
        MOVLW   0X40
        SUBWF   _TM_TMP,W
        btfsC   STATUS, C
        GOTO    TM_ALPHA
        MOVF    _TM_TMP,W
        ANDLW   0X0F
        GOTO    TM_LU
    TM_ALPHA
        ANDLW   0xdf    ;ucase
        SUBLW   6
        btfsS   STATUS, C
        retlw   0       ;ERROR
        MOVLW   0X37
        SUBWF   _TM_TMP,W
        ANDLW   0xdf    ;ucase
    TM_LU
        BRW
        retlw 	0X3F    ;0
        retlw 	6
        retlw 	0X5B
        retlw 	0X4F
        retlw 	0X66
        retlw 	0X6D
        retlw 	0X7D
        retlw 	7
        retlw 	0X7F
        retlw 	0X67    ;9
        retlw 	0X77    ;A
        retlw 	0X7C    ;b
        retlw 	0X39    ;C
        retlw 	0X5E    ;d
        retlw 	0X79    ;E
        retlw 	0X71    ;F
    endasm
     overasm:
    ANSELA=0
    SSP1CON1=$22
    SSP1STAT=$40
    OSCCON=$70
    TRISA = %11111000
    @LPORT=LATA
    LPIN CON 2     ;var LATa.2         ; Latch
    segment var byte
    value var word
    d_index var byte
    buff var byte[5]
    seg_buff   var byte[4]
    seg_cnt    var byte
    seg_dat    var byte
    tmp var byte
    TM_TMP    var byte
    d_pointer      var byte
    timer1_reload con    33543  ;4mS
    T1CON = $1
    d_index=0
            gosub load_seg
        next value
        value = 0
    GOTO Main
    load_seg :
        for seg_cnt=0 to 3
            seg_dat= buff[seg_cnt]
            asm
                MOVE?BA  _seg_dat
                L?CALL seg_val
                MOVE?AB _seg_dat
            endasm
            seg_buff[seg_cnt]= seg_dat
        next
    DISP:
    asm
        INCF TMR1H,F ; 1
        ADDWF TMR1H,F ; 1
        MOVE?CB  high _seg_buff, FSR0H         ;load highbyte
        MOVE?CB  low  _seg_buff, FSR0L         ;load low byte
        MOVE?BA  _d_index
        ADDWF  FSR0L,F
        MOVF   INDF0,W
        ;L?CALL seg_val
        MOVE?AB _segment
        BANKSEL   _tmp
        MOVLW 1
        ADDWF  _tmp,F
        MOVLW 16
        BANKSEL   _d_pointer
        movwf _d_pointer
        BcF STATUS ,C
    N_BIT
        BANKSEL   _d_pointer
        RRF    _d_pointer,F
        BANKSEL   _tmp
        DECFSZ  _tmp,F
        GOTO N_BIT
        MOVLW 1
        BANKSEL  _d_index
        ADDWF  _d_index,F
        MOVLW 3
        ANDWF  _d_index,F
        BANKSEL  LPORT
        BCF LPORT ,_LPIN
        BANKSEL PIR1
        BCF     PIR1,3
        BANKSEL  _segment
        MOVF    _segment,W   ;COMMENT USED TO INVERT DATA FOR COMMON cathode DISPLAY
        BANKSEL SSP1BUF
        movwf   SSP1BUF
        BANKSEL PIR1
        BTFSs   PIR1,3
        GOTO    $-1
        BANKSEL  _d_pointer
        COMF    _d_pointer,W   ;COMMENT USED FOR COMMON cathode DISPLAY
        BANKSEL PIR1
        BCF     PIR1,3
        BANKSEL SSP1BUF
        movwf   SSP1BUF
        BANKSEL PIR1
        BTFSs   PIR1,3
        GOTO    $-1
        BANKSEL  LPORT
        BSF LPORT ,_LPIN
        BANKSEL 0
        INT_RETURN
    endasm
  1. 7 segment display
    Last Post: - 13th January 2015, 14:24
  2. 1 Pin 7-Segment Display
    By Mike, K8LH in forum Schematics
    Last Post: - 23rd November 2009, 13:35
  3. 7-segment display with P16F84
    By spitfire in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 20:22
  4. Display Using Cascaded 74hc595
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 7th December 2004, 07:05
  5. Multiplex two 7 segment display
    By Fernando Santos in forum mel PIC BASIC Pro
    Last Post: - 20th July 2003, 14:26
