4 bit 7 segment display with two 74HC595
Results 1 to 24 of 24
    Default Re: 4 bit 7 segment display with two 74HC595
    the difference with this method is that the mcu can now do other tasks and not spend all its time being just a display controller
    Yes that's great, now the MCU has a way more time to do other tasks which I write using my poor skills in picbasic.
    Probably this piece of your code will be used in my future projects with that type of 7 segment displays.
    Thanks.
    One further improvement is to ditch dt_ints
    it adds unnecessary bloat for this app
    '*  Name    : 4 bit 7 segment display                           *
    '*  Author  : RICHARD                                           *
    '*  Notice  :                                                   *
    '*  Date    : 18. 2. 2018                                       *
    '*  MCU     : PIC 12F1822 @32MHZ                                *
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
     goto overasm
    seg_val
        CHK?RP  _TM_TMP
        MOVWF   _TM_TMP
        SUBLW   0x21
        btfsc   STATUS, C
        retlw   0   ;" "
        MOVF    _TM_TMP,W
        SUBLW   0x2f
        btfsc   STATUS, C
        retlw   64   ;"-"
        MOVF    _TM_TMP,W
        MOVLW   0X40
        SUBWF   _TM_TMP,W
        btfsC   STATUS, C
        GOTO    TM_ALPHA
        MOVF    _TM_TMP,W
        ANDLW   0X0F
        GOTO    TM_LU
    TM_ALPHA
        ANDLW   0xdf    ;ucase
        SUBLW   6
        btfsS   STATUS, C
        retlw   0       ;ERROR
        MOVLW   0X37
        SUBWF   _TM_TMP,W
        ANDLW   0xdf    ;ucase
    TM_LU
        BRW
        retlw 	0X3F    ;0
        retlw 	6
        retlw 	0X5B
        retlw 	0X4F
        retlw 	0X66
        retlw 	0X6D
        retlw 	0X7D
        retlw 	7
        retlw 	0X7F
        retlw 	0X67    ;9
        retlw 	0X77    ;A
        retlw 	0X7C    ;b
        retlw 	0X39    ;C
        retlw 	0X5E    ;d
        retlw 	0X79    ;E
        retlw 	0X71    ;F
    endasm
     overasm:
    DEFINE OSC 32            ; Use internal clock
    ANSELA=0
    SSP1CON1=$22
    SSP1STAT=$40
    OSCCON=$70
    DEFINE INTHAND   _DISP
    TRISA = %11111000
    @LPORT=LATA
    LPIN CON 2     ;var LATa.2         ; Latch
    DPIN var porta.0         ; Data  SDO
    CPIN var porta.1         ; Clock SCK
    segment var byte
    value var word
    d_index var byte
    buff var byte[5]
    seg_buff   var byte[4]
    seg_cnt    var byte
    seg_dat    var byte
    tmp var byte
    TM_TMP    var byte
    d_pointer      var byte
    timer1_reload con    33543  ;4mS
    PIR1.0=0
    INTCON=$C0
    PIE1.0=1
    T1CON = $1
    d_index=0
    ;---[simple counter 0 - to ffff]------------------------------------------------
        for value = 0 to 65535
            arraywrite buff ,[HEX4 value,0]
            gosub load_seg
        next value
        value = 0
    GOTO Main
    load_seg :
        for seg_cnt=0 to 3
            seg_dat= buff[seg_cnt]
            asm
                MOVE?BA  _seg_dat
                L?CALL seg_val
                MOVE?AB _seg_dat
            endasm
            seg_buff[seg_cnt]= seg_dat
        next
    ;---[TMR1 - interrupt handler]--------------------------------------------------
    DISP:
    asm
        MOVE?CT 0, T1CON, TMR1ON ; 1 stop timer
        MOVLW LOW(_timer1_reload) ; 1 Add TimerReload to the
        ADDWF TMR1L,F ; 1 value in Timer1
        BTFSC STATUS,C ; 1/2
        INCF TMR1H,F ; 1
        MOVLW HIGH(_timer1_reload) ; 1
        ADDWF TMR1H,F ; 1
        MOVE?CT 1, T1CON, TMR1ON ; 1 start timer
        MOVE?CB  high _seg_buff, FSR0H         ;load highbyte
        MOVE?CB  low  _seg_buff, FSR0L         ;load low byte
        MOVE?BA  _d_index
        ADDWF  FSR0L,F
        MOVF   INDF0,W
        ;L?CALL seg_val
        MOVE?AB _segment
        MOVE?BB  _d_index ,_tmp
        BANKSEL   _tmp
        INCF  _tmp,F
        MOVLW 16
        BANKSEL   _d_pointer
        movwf _d_pointer
        BcF STATUS ,C
    N_BIT
        BANKSEL   _d_pointer
        RRF    _d_pointer,F
        BANKSEL   _tmp
        DECFSZ  _tmp,F
        GOTO N_BIT
        BANKSEL  _d_index
        INCF  _d_index,F
        MOVLW 3
        ANDWF  _d_index,F
        BANKSEL  LPORT
        BCF LPORT ,_LPIN
        BANKSEL PIR1
        BCF     PIR1,3
        BANKSEL  _segment
        MOVF    _segment,W   ;COMMENT USED TO INVERT DATA FOR COMMON cathode DISPLAY
        ;COMF    _segment,W  ;COMMENT USED TO INVERT DATA FOR COMMON ANODE DISPLAY
        BANKSEL SSP1BUF
        movwf   SSP1BUF
        BANKSEL PIR1
        BTFSs   PIR1,3
        GOTO    $-1
        BANKSEL  _d_pointer
        COMF    _d_pointer,W   ;COMMENT USED FOR COMMON cathode DISPLAY
        ;MOVF    _d_pointer,W  ;COMMENT USED FOR COMMON ANODE DISPLAY
        BANKSEL PIR1
        BCF     PIR1,3
        BANKSEL SSP1BUF
        movwf   SSP1BUF
        BANKSEL PIR1
        BTFSs   PIR1,3
        GOTO    $-1
        BANKSEL  LPORT
        BSF LPORT ,_LPIN
        BANKSEL PIR1
        BCF PIR1   ,0
        RETFIE
    endasm
    Last edited by richard; - 20th February 2018 at 00:59. Reason: USED INCF INSTEAD OF ADDING 1
    Final version after a bit of a clean up
  1. 7 segment display
    Last Post: - 13th January 2015, 14:24
  2. 1 Pin 7-Segment Display
    By Mike, K8LH in forum Schematics
    Last Post: - 23rd November 2009, 13:35
  3. 7-segment display with P16F84
    By spitfire in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 20:22
  4. Display Using Cascaded 74hc595
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 7th December 2004, 07:05
  5. Multiplex two 7 segment display
    By Fernando Santos in forum mel PIC BASIC Pro
    Last Post: - 20th July 2003, 14:26
