4 bit 7 segment display with two 74HC595
Results 1 to 24 of 24
    Default 4 bit 7 segment display with two 74HC595
    Hello All,
    I start to play with one of this cheap 4 digit 7 segment display. The display is driven by two 74HC595 which one is for segments and the other is for common cathodes (digits).
    Here is the schematic:
    Name:  4 bit 7 segment module.jpg
    I writed a simple code using Darrel's interrupts. Code multiplexing the digits using TMR1 interrupt.
    It works OK, but I think that code is not as elegant. It looks rough, because I'm not a skilled programmer.
    Can someone explain to me a better way to do this task?
    Here is my code:
    '*  Name    : 4 bit 7 segment display                           *
    '*  Author  : LouisLouis                                        *
    '*  Notice  : Copyright (c) 2018                                *
    '*  Date    : 18. 2. 2018                                       *
    '*  MCU     : PIC 12F1840                                       *
      __config _CONFIG1, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_ON & _CLKOUTEN_OFF & _IESO_ON & _FCMEN_ON
      __config _CONFIG2, _WRT_OFF & _PLLEN_ON & _STVREN_ON & _BORV_19 & _LVP_OFF
    DEFINE OSC 32            ; Use internal clock
    OSCCON = %01110000
    CLKRCON = 0
    Include "modedefs.bas"
    INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
    TRISA = %000000
    ANSELA = %0000
    OPTION_REG.7=0           ; Enable internal pull-ups
    LPIN var porta.2         ; Latch
    DPIN var porta.4         ; Data
    CPIN var porta.5         ; Clock
    segment var byte
    value var word
    place var byte[4]
    ones var word
    tens var word
    hundreds var word
    thousands var word
        INT_Handler TMR1_INT, _DISP, PBP, yes
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    T1CON = $1
    ;---[simple counter 0 - to 9999]------------------------------------------------
    for value = 0 to 9999
    next value
    value = 0
    GOTO Main
    ;---[TMR1 - interrupt handler]--------------------------------------------------
    DISP:
    T1CON.0 = 0                ; stop timer
    TMR1H = %11111100
    TMR1L = %00011111
    T1CON.0 = 1                ; restart timer
    ;---[extract ones and show]-----------------------------------------------------
    ones = value//10
    lookup ones, [%11000000,%11111001,%10100100,%10110000,%10011001,%10010010,%10000010,%11111000,%10000000,%10010000],segment
    LOW  LPIN
    Shiftout DPIN, CPIN, MSBFIRST,[segment,%0001]
    high lpin
    pause 4
    ;---[extract tens and show]-----------------------------------------------------
    tens =  value/10
    tens = tens//10
    lookup tens, [%11000000,%11111001,%10100100,%10110000,%10011001,%10010010,%10000010,%11111000,%10000000,%10010000],segment
    LOW  LPIN
    Shiftout DPIN, CPIN, MSBFIRST,[segment,%0010]
    high lpin
    pause 4
    ;---[extract hundreds and show]-------------------------------------------------
    hundreds =   value/100
    hundreds = hundreds//10
    lookup hundreds, [%11000000,%11111001,%10100100,%10110000,%10011001,%10010010,%10000010,%11111000,%10000000,%10010000],segment
    LOW  LPIN
    Shiftout DPIN, CPIN, MSBFIRST,[segment,%0100]
    high lpin
    pause 4
    ;---[extract thousands and show]------------------------------------------------
    thousands = value/1000
    place = %1000
    lookup thousands, [%11000000,%11111001,%10100100,%10110000,%10011001,%10010010,%10000010,%11111000,%10000000,%10010000,%10001000],segment
    LOW  LPIN
    Shiftout DPIN, CPIN, MSBFIRST,[segment,%1000]
    high lpin
    @ INT_RETURN
    Aug 2003
    Default Re: 4 bit 7 segment display with two 74HC595
    It’s not bad except you don’t need 4 copies of the same lookup table. That should be a subroutine.
    If possible, there should be four identical subroutines that you feed each digit to.
    You’d normally do the display multiplex in the main program, and only use the interrupt to set a flag
    that is being watched by the main program to know when a second, or whatever period ticks over.
    The interrupt handler should be the smaller routine.
    Hello Art,
    something like this:
    OSCCON = %01110000
    CLKRCON = 0
    TRISA = %000000
    ANSELA = %0000
    segment var byte
    value var word
    place var byte[4]
    ones var word
    tens var word
    hundreds var word
    thousands var word
    T1CON = $1
    ;---[show HELO for 0,5sec.]-----------------------------------------------------
    intro:
    segment=12
    gosub look
    ones=segment
    segment=11
    gosub look
    tens=segment
    segment=10
    gosub look
    hundreds=segment
    segment=13
    gosub look
    thousands=segment
    gosub setdisp
    pause 10
    next value
    value = 0
    GOTO Main
    setdisp:
    segment = value//10
    gosub look
    ones=segment            ; extract ones
    segment =  value/10
    segment = segment//10
    gosub look
    tens=segment            ; extract tens
    segment =   value/100
    gosub look
    hundreds=segment        ; extract hundreds
    segment = value/1000
    gosub look
    thousands=segment       ; extract thousands
    ;---[7 segment pattern 0123456789 and letters H E L O]--------------------------
    look:
    lookup segment, [%11000000,%11111001,%10100100,%10110000,%10011001,%10010010,%10000010,%11111000,%10000000,%10010000,%10000110,%11000111,%11000000,%10001001],segment
    DISP:
    TMR1H = %11111100
    TMR1L = %00011111
    ;---[multiplex and show]--------------------------------------------------------
    LOW  LPIN
    Shiftout DPIN, CPIN, MSBFIRST,[ones,%0001]
    high lpin
    pause 2
    LOW  LPIN
    Shiftout DPIN, CPIN, MSBFIRST,[tens,%0010]
    high lpin
    pause 2
    LOW  LPIN
    Shiftout DPIN, CPIN, MSBFIRST,[hundreds,%0100]
    high lpin
    pause 2
    LOW  LPIN
    Shiftout DPIN, CPIN, MSBFIRST,[thousands,%1000]
    high lpin
    @ INT_RETURN
    It is a bit slower, but now I can display digits and letters.
    Otherwise, I don't think this is a more efficient and elegant code, it must be a better way.
    OK
    At the bottom of look: you have RETURN listed twice.
    You turn TMR1 Off (T1CON = 0) in your Disp: Interrupt Handler but I don't see where you turn it back on.
    "segment = value/1000
    gosub look
    thousands=segment ; extract thousands"
    Leads right into your look: Interrupt Handler. If that was to be a subroutine, you need that extra RETURN relocated to the end of that grouping.
    yes I forgot to delete one return, but it doesn't matter.
    Here: T1CON.0 = 1 ; restart timer
    DISP:
    TMR1H = %11111100
    TMR1L = %00011111
    Both codes which I posted works fine. I'm looking for more professional (easier, better, more skilled) example to do this.
    Aug 2003
    One of many ways to pull your counter value apart in BASIC is using DIG.
    Copy the counter to another buffer so it stays safe.
    This may be rough, and won't compile straight up.
    destructobuffer = countervalue
    FOR loopcounter = 0 TO 3
    digitvalue = destructobuffer DIG 0
    print digitvalue
    shift out a digit
    delay for digit (if you must)
    destructobuffer = destructobuffer / 10
    NEXT loopcounter
    OK
    Quote Originally Posted by louislouis View Post
    TMR1H = %11111100
    TMR1L = %00011111
    Most of the data sheets say that when you write to the TMRxH/L, you must declare the entire TxCON SFR. I personally have made a practice of using T1CON = %xxxxxxxx instead of isolating a single bit in the TxCON register after preloading the TMRx register. I actually had a bug that I couldn't figure out for the longest time. When I wrote to the entire Timer Register instead of just a single 1/0 bit, it started working. If it works now, you could leave it as is. If you have issues, try what I suggested here.
    Apr 2003
    Cambridge - UK
    Lester - Forum Administrator
    www.crownhill.co.uk
    Published in the WiKI
    lester
    the two small code windows are blank in the wiki article , i'm sure that was not the intention
    might also add that a decimal point can be lit in the appropriate display using
    for value = 0 to 65535
    arraywrite buff ,[HEX4 value]
    gosub load_seg
    seg_buff[2]=seg_buff[2]|128 ; place a dp in digit 2
    next value
    value = 0
    GOTO Main
    Apr 2003
    Cambridge - UK
    Thank you Richard, the editor went a little funky and added some crazy formatting, causing the blank code boxes. Its fixed now.
    Thank you for your generous contribution.
    www.crownhill.co.uk
    there are still something wrong, because missing "%" character in the codes published on wiki
    Orig. code:
    TRISA = %111000
    Code on wiki:
    TRISA = 111000
    Apr 2003
    Cambridge - UK
    OK thanks for that
    I think the % is displayed correctly now.
    www.crownhill.co.uk
  1. 7 segment display
    Last Post: - 13th January 2015, 13:24
  2. 1 Pin 7-Segment Display
    By Mike, K8LH in forum Schematics
    Last Post: - 23rd November 2009, 12:35
  3. 7-segment display with P16F84
    By spitfire in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2009, 19:22
  4. Display Using Cascaded 74hc595
    By charudatt in forum mel PIC BASIC Pro
    Last Post: - 7th December 2004, 06:05
  5. Multiplex two 7 segment display
    By Fernando Santos in forum mel PIC BASIC Pro
    Last Post: - 20th July 2003, 13:26
