Rotary Encoder on 20x4 LCD with pushbutton digit select and other features
Results 1 to 24 of 24
    Default Re: Rotary Encoder on 20x4 LCD with pushbutton digit select and other features
    As per your code, it does not function properly on my setup even though I made the LCD changes. What am I not seeing or missing? See video of power up and what happens when I turn the knob of the encoder. See what happens when I select a digit and then turn the knob. I can only get it to respond to the knob turn when I do it fast, not when it is done slowly.
    I have the identical rotary encoder module and use no caps at all on it,
    I have used a pic18f458 @8mhz , a pic18f25k22 @64mhz they both work perfectly.
    I don't have a pic16 chip with the correct pinout to suit the lcd wiring in my easypic7 board so I can't test for those chips
    but can see no reason for it not to work.
    Jun 2017
    If your using 18F chips then that may be the reason why. Perhaps the commands are getting compiled differently for 18F's than for 16F's??
    No matter, I have an 18F4423 I can use to test that theory...
    Thanks.
    I don't use lcd's or pic16's much but here is a trap
    LCDOUT ".", digit[tmp1]+$30
    inline math for lcdout on a pic16 turns to crap,you need to do the math first then print result
    tmp2 =digit[tmp1]+$30
    LCDOUT  ".", tmp2
    the code still fails on pic16, may be too many nested gosubs
    moved enc to porta 234 on 16f648a, reduced nesting by two levels
    now works
    '*  Name    : LCD_TEST.BAS                                      *
    '*  Author  : RICHARD                                           *
    '*  Date    : 4/8/2017                                          *
    '*  Notes   :                                      *
    '*          :       16f648a                                   *
      __config  _HS_OSC & _WDT_ON & _PWRTE_OFF & _MCLRE_ON & _BODEN_ON & _LVP_OFF & _CP_OFF
        DEFINE OSC 8
    'LCD defines begin here
        DEFINE LCD_BITS 4  'defines the number of data interface lines (4 or 8)
        DEFINE LCD_DREG PORTB 'defines the port where data lines are connected to
        DEFINE LCD_DBIT 0  'defines the position of data lines for 4-bit interface (0 or 4)
        DEFINE LCD_RSREG PORTB 'defines the port where RS line is connected to
        DEFINE LCD_RSBIT 4  'defines the pin where RS line is connected to
        DEFINE LCD_EREG PORTB  'defines the port where E line is connected to
        DEFINE LCD_EBIT 5  'defines the pin where E line is connected
        DEFINE LCD_COMMANDUS 1500  'defines the delay after LCDOUT statement
        DEFINE LCD_DATAUS 50   'delay in micro seconds
    'END of LCD DEFINES
        DEFINE LCD_LINES 4
    cmcon=7
    Pause 500       ' LCD initialize time
    lcdout $FE,1
    num_digits      con 5        ; range 4 t0 9 tested ok     note sum_total will not work for more than 5 digits
    sw_threshhold   con 10
    lp_threshhold   con 100      ;long press
    sw_inhibit_time con 100
    msd_limit       con 5        ;limit value for msd  note sum_total will not work for more than 5 digits and limit > 5  ;optional
    digit       var byte[num_digits]
    d_index     var byte
    overflow    var bit
    underflow   var bit
    noroll_flg  var bit    ;optional
    d_inx       var byte
    sw_cnt      var byte
    sw_flag     var bit
    re          var byte
    last_re     var byte
    ev          var byte
    tmp1        var byte
    tmp2        var byte  ;optional
    tmp3        var byte  ;optional
    sw_inhibit  var byte
    total       var word
    enc_act     var byte
    enc_sw var PORTa.4
    enc_a  var porta.2
    enc_b  var porta.3
    clear
    d_index = num_digits
    re = porta&12
    last_re = re
    gosub dup
        if !sw_inhibit then gosub chk_sw
        if   sw_flag then    ;service the sw if active
            if sw_cnt > lp_threshhold then       ;long press clears settings
                for d_index = 0 to (num_digits-1)
                   digit[d_index] = 0
                next
                 gosub dup
                d_index = d_index - 1      ;increment set digit {index posn 6 will stop editing of settinge}
                if d_index > num_digits then d_index = num_digits
                gosub set_cursor
                sw_inhibit = sw_inhibit_time      ; don't reactivate sw immediately [more user friendly]
            sw_cnt = 0
            sw_flag = 0
        ;poll encoder    a poll rate of 5-10ms is adequate
        re = porta&12
        if re != last_re  then    ;encoder has moved
            last_re = re   ; this line fell off pic18 version
            ev=ev<<2              ;shift old reading into position  for compare
            ev=ev|((porta&12)>>2)  ;read enc pins 4,5  mask off others then  combine this reading with last reading
            ;lookup table is a form of digital filter to debounce encoder [no caps used on encoder at all]
            LOOKUP (ev&$f),[0,255, 1, 0, 1, 0, 0, 255, 255, 0, 0, 1, 0, 1, 255, 0],enc_act ;lookup the decision matrix  to determine rotation
        ;service encoder result if there is one
        if enc_act && (re == 0) then    ; tmp1 255 is anticlockwise or 1 for clockwise    [swap a/b pins if direction incorrect]
            if d_index != num_digits then
                if enc_act = 255 then
                        d_inx = d_index
                        gosub norolld              ;optional
                        if noroll_flg then         ;optional
                        digit[d_index] = digit[d_index] - 1
                            underflow = 0
                            if  digit[d_inx] > 127 then  underflow = 1
                            while underflow
                                underflow = 0
                                digit[d_inx] = 9
                                d_inx= d_inx + 1
                                if  d_inx < num_digits then
                                        digit[d_inx] = digit[d_inx] - 1
                                    endif              ;optional
                            wend
                        endif                      ;optional
                        d_inx = d_index
                        gosub norollu        ;optional
                        digit[d_index] = digit[d_index] + 1
                        overflow = 0
                        if  digit[d_inx] > 9 then  overflow = 1
                        while overflow
                            overflow = 0
                            digit[d_inx] = 0
                            d_inx = d_inx + 1
                                    digit[d_inx] = digit[d_inx] + 1
                                endif               ;optional
                        wend
                        endif                   ;optional
            gosub dup
            enc_act = 0
        ;service sw inhibit if necessary
        if  sw_inhibit then sw_inhibit = sw_inhibit - 1     ; [make sw action more user friendly]
        pause 5   ;adjust to suite desired responsiveness  or  more functions in loop
    dup:       ;update lcd
        LCDOUT $FE, $94
        tmp1=num_digits
        while tmp1
            tmp1=tmp1-1
            tmp2 = digit[tmp1]+$30
            if tmp1 = 1  then
               LCDOUT  ".", tmp2
               LCDOUT  tmp2
        wend
        gosub SUM_TOTALS
        LCDOUT $FE, $80, dec5 total
    set_cursor:      ;update cursor
        if d_index == num_digits then
            LCDOUT $FE,$0C
            tmp2 =  $94 + num_digits - d_index
            if d_index > 1 then  tmp2=tmp2-1
            LCDOUT $FE,$0f,$fe,tmp2
    chk_sw:      ;see if switch is active
        if sw_flag  then return
        if !enc_sw  then
            if    sw_cnt < 255 then sw_cnt = sw_cnt + 1
            if sw_cnt > sw_threshhold then
               sw_flag = 1
               sw_cnt=0
    norolld:       ; stop rollunder from 0000.00 to 9999.99  ;optional
       tmp3=digit[d_inx]                        ;optional
       noroll_flg=0                             ;optional
       for tmp2=(d_inx+1) to  (num_digits -1)   ;optional
          tmp3=tmp3+digit[tmp2]                 ;optional
       next                                     ;optional
       if tmp3 then noroll_flg = 1              ;optional
    return                                      ;optional
    norollu:      ; stop rollover from 9999.99 to 0000.00    and limit msd
       if  d_inx < (num_digits -1)  then            ;optional
           tmp3=9-digit[d_inx]                      ;optional
           for tmp2=(d_inx+1) to  (num_digits -2)   ;optional
               tmp3=tmp3+(9-digit[tmp2] )           ;optional
           next                                     ;optional
           tmp3=tmp3+(msd_limit-digit[tmp2] )       ;optional
       else                                         ;optional
           tmp3=msd_limit-digit[d_inx]              ;optional
       endif                                        ;optional
    return                                          ;optional
    SUM_TOTALS:    ;max digit is 5 and max_msd = 5 or else result will overflow
       tmp1=num_digits
       total=0
        while tmp1
            tmp1=tmp1-1
            total=total*10
            total=total+digit[tmp1]
        wend
    Jun 2017
    now works
    Yes now it does and I now see what you meant by scalable. Range is 000.00 to 599.99
    So at startup with no button push, the knob does nothing until the user is ready to use it.
    Push Button, user selects the hundreds digit from 000.00 to 500.00.
    Next push, user selects the tens digit for a range of 000.00 to 590.00.
    Next push, user selects the ones digit for a range of 000.00 to 599.00
    Next push is for tenths. 599.90
    Nest push is for hundredths. 599.99
    Push button for a second or so and it clears it all to zero.
    Last push, the knob is disabled again.
    Very interesting way of doing it. I must say that this method is way more functional that what I was doing.
    Thanks for a great lesson in programming.
    On a side note, this pic has an 8 level stack. I only counted 2 nested GOSUBS max. I guess 2 was 2 much...
    pbp uses 4 of them before your code even starts
    now see what happens when
    num_digits con 5 is changed
    try 4 up to 9 or beyond
    also try changing
    msd_limit con 5
    to other values
    also hold switch down for a couple of seconds
    On the http://www.best-microcontroller-proj...y-encoder.html site there was an article that uses a different type of encoder polling.
    It is in C but if I can read it then everyone can!
    I have not yet understood completely how it decodes the encoder data but seems very interesting and as the author says it decodes also the speed?
    No hardware set up to test it but if anyone has the time I'd like to know the results.
  1. Using an incremental rotary encoder?
    By keithv in forum mel PIC BASIC Pro
    Last Post: - 12th January 2016, 23:23
  2. Instant Interrupts for rotary encoder
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 15th August 2014, 09:24
  3. New approach to Rotary Encoder
    By Ioannis in forum Code Examples
    Last Post: - 11th July 2013, 22:05
  4. Automotive quality rotary encoder
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 8th October 2004, 16:46
