Rotary Encoder on 20x4 LCD with pushbutton digit select and other features
Results 1 to 24 of 24
    Jun 2017
    Post Re: Rotary Encoder on 20x4 LCD with pushbutton digit select and other features
    Thanks Richard for commenting and posting code. Your code takes up much less space. I made the hardware changes to my setup and included the necessary configuration registers for programming. I don't understand why you "and" PortA with decimal 48. Please explain. See example below.
    As per your code, it does not function properly on my setup even though I made the LCD changes. What am I not seeing or missing? See video of power up and what happens when I turn the knob of the encoder. See what happens when I select a digit and then turn the knob. I can only get it to respond to the knob turn when I do it fast, not when it is done slowly.
    Encoder type used: I had used 3 10nF caps on the 3 lines to ground for debounce in my original setup. Failed to mention that, but I used a new one with no caps and still didn't work.
    Video:
    Thanks, csantex
    if you do it more algorithmically the size can be reduced dramatically ,it becomes scalable digit wise
    more functions can easily be added and the mcu can be employed to perform a real task like pid control of a power supply and not just become a display controller
    ps note my lcd defines suite my setup and are different
    '*  Name    : LCD_TEST.BAS                                      *
    '*  Author  : RICHARD                                           *
    '*  Date    : 4/8/2017                                          *
    '*  Notes   :                                      *
    '*          :       16f887                                   *
     __CONFIG    _CONFIG1, _LVP_OFF & _FCMEN_OFF & _IESO_OFF & _BOR_ON & _CPD_OFF & _CP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _INTOSCIO
     __CONFIG    _CONFIG2, _WRT_OFF & _BOR40V
        DEFINE OSC 8
    'LCD defines begin here
        DEFINE LCD_BITS 4  'defines the number of data interface lines (4 or 8)
        DEFINE LCD_DREG PORTB 'defines the port where data lines are connected to
        DEFINE LCD_DBIT 0  'defines the position of data lines for 4-bit interface (0 or 4)
        DEFINE LCD_RSREG PORTB 'defines the port where RS line is connected to
        DEFINE LCD_RSBIT 4  'defines the pin where RS line is connected to
        DEFINE LCD_EREG PORTB  'defines the port where E line is connected to
        DEFINE LCD_EBIT 5  'defines the pin where E line is connected
        DEFINE LCD_COMMANDUS 1500  'defines the delay after LCDOUT statement
        DEFINE LCD_DATAUS 50   'delay in micro seconds
    'END of LCD DEFINES
    ;TRIS REGISTERS FROM MY CODE WITH COMMENTS****************************
        OSCCON  = %01110000     ; Set PIC16F88 to 4MHz = %01100000, or
                                ; 8MHz = %01110000
    '    TRISA   = %11111111     ; Port A set to inputs    'COMMENTED OUT SINCE IT BOOTS UP AS INPUTS ANYWAYS.   <<<<<<<<<<<<<<<
    '    TRISB   = %11101100     ; Port B set to OUTPUTS   'COMMENTED OUT SINCE LCD DEFINES SET DATA DIRECTIONS.   <<<<<<<<<<<<<<<<
        TRISC   = %01111111     ; Port C set to inputs
    '    TRISD   = %00000000     ; Port D set to Ouputs     'NOT USED IN YOUR CODE    <<<<<<<<<<<<<<<<<<<<<<<
        ANSEL   = %00000000     ; Set all analog pins to digital
        ANSELH  = %00000000
    ; YOUR CODE==============================================
    Pause 500       ' LCD initialize time
    lcdout $FE,1
    num_digits      con 5        ; range 4 t0 9 tested ok     note sum_total will not work for more than 5 digits
    sw_threshhold   con 10
    lp_threshhold   con 100      ;long press
    sw_inhibit_time con 100
    msd_limit       con 5        ;limit value for msd  note sum_total will not work for more than 5 digits and limit > 5  ;optional
    digit       var byte[num_digits-1]
    d_index     var byte
    overflow    var bit
    underflow   var bit
    noroll_flg  var bit    ;optional
    d_inx       var byte
    sw_cnt      var byte
    sw_flag     var bit
    re          var byte
    last_re     var byte
    ev          var byte
    tmp1        var byte
    tmp2        var byte  ;optional
    tmp3        var byte  ;optional
    sw_inhibit  var byte
    total       var word
    enc_sw var PORTC.4
    enc_a  var portc.5
    enc_b  var portc.6
    clear
    d_index = num_digits
    re = porta&48     '<<<<<<<<<<<<<<<  Why do you "&" dec48 with Port A?
    last_re = re
    gosub dup
    The rest of the code is as you wrote it....
  1. Using an incremental rotary encoder?
    By keithv in forum mel PIC BASIC Pro
    Last Post: - 12th January 2016, 23:23
  2. Instant Interrupts for rotary encoder
    By fnovau in forum mel PIC BASIC Pro
    Last Post: - 15th August 2014, 09:24
  3. New approach to Rotary Encoder
    By Ioannis in forum Code Examples
    Last Post: - 11th July 2013, 22:05
  4. Automotive quality rotary encoder
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 8th October 2004, 16:46
