DT_INTS and 18F26k22
Results 1 to 15 of 15
    OK
    Default Re: DT_INTS and 18F26k22
    A few things I learned about the DT_INT routines is:
    1 - You must have a copy of the DT_INT and ReEnterPBP code in the file where you save your current program. PBP3 will not search the computer and create a path. Thus, I have multiple copies of the code on my computer.
    2 - It is helpful to open the DT_INT in PBP3 and look at how the "RX1_INT" is structured in the code, and where it is looking for PIE, PIR, etc. The K22 family is relatively new, and as you stated, OSCCON SFR is structured differently than for older chips. You may have to alter the DT_INT itself, or alter the way you INT_LIST your IntSource.
    3 - At the top of the DT_INT (I believe for the PIC12F/16F) there are multiple wsave options that you have to comment out or uncomment, depending. I don't remember the -18 requiring that, but I may be wrong. On the lower chips, you must include one of the wsave options in your variable declarations of your main code (wsave VAR BYTE $20 SYSTEM for example).
    I'd wager a guess the issue you're having is #1, your interrupt routines are not in the folder you're saving your current program.
    mpgmike, I have been using DT_INTS-18 for quite a while with 18F26K22 parts as soon as Microchip released them. It's been a few years now. I have never had to change anything to do with Darrels code. What are you talking about?
    EN82fn
    Quebec, Canada
    FYI: You can specify a relative path. I have a separate folder for all my includes. It is located in the same root folder of all my projects:
    C:\
         ---Somewhere
               ---MyPBPProjects
                    ---MyIncludes
                    ---Project1
                    ---Project2
                    ---Project3
    Here my include folder is named _Include
    INCLUDE  "..\_Include\DT_INTS-18\DT_INTS-18.bas"   ' Base Interrupt System
    INCLUDE  "..\_Include\DT_INTS-18\ReEnterPBP-18.bas"   ' Include if using PBP interrupts
    INCLUDE "..\_Include\DT_INTS-14_V110\DT_INTS-14.bas"   ' Base Interrupt System
    INCLUDE "..\_Include\DT_INTS-14_V110\ReEnterPBP.bas"   ' Include if using PBP interrupts
    INCLUDE "..\_Include\ESP8266_Base.pbp"
    INCLUDE "..\_Include\NMEA_base.pbp"
    'etc
    Michel, That is exactly the way I have been doing mine for years....
    EN82fn
    Jul 2009
    Ohio, USA
    Dave, are you using DT_INTS for RX1/RX2 interrupts? If so, how?
    Mike
    Mike, Here are some snipits from a program I wrote about 4 years ago:
    TX485 VAR PORTB.6 '0-OUTPUT COMMUNICATIONS PORT PIN RS-485
    RX485 VAR PORTB.7 '1-INPUT COMMUNICATIONS PORT PIN RS-485
    TX232 VAR PORTC.6 '0-OUTPUT COMMUNICATIONS PORT PIN RS-232
    RX232 VAR PORTC.7 '1-INPUT COMMUNICATIONS PORT PIN RS-232
    BAUD1 CON 416 'TX/RX BAUD RATE (64000000/4/38400) - 1 (HIGH BAUD/16 BIT)
    BAUD2 CON 416 'TX/RX BAUD RATE (64000000/4/38400) - 1 (HIGH BAUD/16 BIT)
    BAUDCON1 = %00001000 'SET FOR 16 BIT BAUDRATE
    SCRATCH = BAUD1
    SPBRG1 = SCRATCH.LOWBYTE 'SET LOW BYTE OF BAUD GENERATOR
    SPBRGH1 = SCRATCH.HIGHBYTE 'SET HIGH BYTE OF BAUD GENERATOR
    RCSTA1 = %10010000 'ENABLE RECEIVER,CONTINUOUS
    TXSTA1 = %00100100 'ENABLE TRANSMIT,HIGH BAUD
    BAUDCON2 = %00001000 'SET FOR 16 BIT BAUDRATE
    SCRATCH = BAUD2
    SPBRG2 = SCRATCH.LOWBYTE 'SET LOW BYTE OF BAUD GENERATOR
    SPBRGH2 = SCRATCH.HIGHBYTE 'SET HIGH BYTE OF BAUD GENERATOR
    RCSTA2 = %10010000 'ENABLE RECEIVER,CONTINUOUS
    TXSTA2 = %00100100 'ENABLE TRANSMIT,HIGH BAUD
    asm
    INT_Handler TX1_INT, _UARTTX1, PBP, no
    INT_Handler RX1_INT, _UARTRX1, PBP, no
    INT_Handler TX2_INT, _UARTTX2, PBP, no
    INT_Handler RX2_INT, _UARTRX2, PBP, no
    INT_CREATE ; Creates the High Priority interrupt processor
    @ INT_ENABLE RX1_INT ; Enable RX UART Interrupts
    @ INT_ENABLE RX2_INT ; Enable RX UART Interrupts
    GOTO MAINLOOP 'JUMP OVER INTERRUPTS
    UARTRX1: 'INTERRUPT SERVICE ROUTINE FOR UART RECEIVER
    @ INT_RETURN
    UARTTX1: 'INTERRUPT SERVICE ROUTINE FOR UART TRANSMITTER
    @ INT_RETURN
    UARTRX2: 'INTERRUPT SERVICE ROUTINE FOR UART RECEIVER
    @ INT_RETURN
    UARTTX2: 'INTERRUPT SERVICE ROUTINE FOR UART TRANSMITTER
    @ INT_RETURN
    EN82fn
    Jul 2009
    Ohio, USA
    Thanks Dave, no matter what I try on the 18F26K22 it will not jump to the interrupt. I'm ordering some different chips with 2 UARTS to give them a try.
    Mike
    this works for me
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = OFF
      CONFIG  PRICLKEN = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  HFOFST = ON
      CONFIG  T3CMX = PORTC0
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
            ;INCLUDE "modedefs.bas"
            ;INCLUDE"ALLDIGITAL.pbp"
            ;INCLUDE "HomeAutomationVars.bas"  'Open with PBP editor
            INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
            INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
        define OSC 8
        DEFINE DEBUG_REG PORTB
        DEFINE DEBUG_BIT 7
        DEFINE DEBUG_BAUD 9600
        ' Set Debug mode: 0 = true, 1 = inverted
        DEFINE DEBUG_MODE 0
        x var word
        rxflag   var bit
        rxchar var byte
     INT_Handler    RX1_INT ,    _read_serial,   PBP,  no
     INT_CREATE             ; Creates the interrupt processor
    OSCCON = $60   ;  OSC 8
    anselc = 0
    RCSTA  = $90   ' Enable serial port & continuous receive
    TXSTA  = $20   ' Enable transmit, BRGH = 0
    SPBRG  = 51    ' 9600 Baud @ 8MHz, 0.16%
    SPBRGH = 0
    BAUDCON.3 = 1  ' Enable 16 bit baudrate generator
    baudcon1= baudcon1&%11001111  ;invert tx/rx polarity   for usb-tty adapter
    TRISB.7 = 0  ;DEBUG
    LATB.7  = 1  ;DEBUG
    @   INT_ENABLE   RX1_INT     ; enable external (RX) interrupts
    debug "running",13,10
        debug "."
        for x = 1 to 1000
          if rxflag then
             Debug 13,10,"got !! asc chr ",#rxchar,13,10
             rxflag=0
          pauseus 1000
        next x
    Goto main
    read_serial:
        rxflag = 1
        rxchar = rc1reg
    @   INT_RETURN
    this is much better , get rid of all those nasty pauses and goto's
     ;pic18f26k22 rx1 int demo
      CONFIG  PLLCFG = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  PBADEN = OFF
      CONFIG  HFOFST = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    define OSC 8
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_MODE 0
    x         var  byte bank0
    flag      var  byte bank0
    rxflag    var flag.7
    dotflag   var flag.0
    rxchar    var byte
     INT_Handler    RX1_INT  , _read_serial,asm,no
     INT_Handler    TMR1_INT , _TOCK,asm,no
    clear
    anselc = 0
    SPBRGH = 0
    T1CON=1         ;32mS tick
    TRISB.7 = 0  ;DEBUG
    LATB.7  = 1  ;DEBUG
    pause 2000    ;give me time to setup debug
    debug 13,10 ,"listening "
    @ INT_ENABLE  TMR1_INT
    x=31
    while 1
        if rxflag then
             ;Debug 13,10,"got asc chr ",#rxchar,13,10
             tx1reg = rxchar     ;echo back
             rxflag = 0
        if dotflag then
            debug "."
            dotflag=0
    wend
    read_serial:
        bsf _flag ,7
        MOVE?BB RC1REG,_rxchar
        INT_RETURN
    TOCK:
    asm
        DECFSZ  _x,F
        BRA BREXIT
        movlw 31
        bsf _flag ,0
        movwf _x
    BREXIT
        BCF PIR1 ,0
        INT_RETURN
  1. DT_Ints w/18F26K22 stop if incorrect baud rate
    By Dave in forum mel PIC BASIC Pro
    Last Post: - 8th September 2017, 14:54
  2. PROBLEM ICD 18F26K22 no work
    By FRAN200 in forum mel PIC BASIC Pro
    Last Post: - 4th July 2016, 13:55
  3. 18F26K22 slow startup
    Last Post: - 7th January 2014, 23:10
  4. Compiling for 18F26K22 - Does anyone have a solution for me?
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 28th August 2012, 13:49
  5. Anyone found a Bootloader for 18F26K22?
    Last Post: - 11th August 2011, 19:23
