When I program the code, LCD toggle's right away. If I cycle power, LCD takes forever to toggle. Any ideas? Internal OSC.
Code:#CONFIG CONFIG FOSC = INTIO67 CONFIG PLLCFG = ON CONFIG PRICLKEN = OFF CONFIG FCMEN = ON CONFIG IESO = OFF CONFIG PWRTEN = ON CONFIG BOREN = OFF CONFIG WDTEN = OFF CONFIG CCP2MX = PORTC1 CONFIG PBADEN = OFF CONFIG MCLRE = INTMCLR CONFIG STVREN = ON CONFIG LVP = OFF CONFIG XINST = OFF CONFIG DEBUG = OFF #ENDCONFIG DEFINE OSC 32 OSCCON = %01100000 OSCTUNE = %01000000'01000000 @ ERRORLEVEL -306 ; turn off crossing page boundary message 'Include "modedefs.bas" ' Mode definitions for Serou Baud var PortA.2 'Output Set Baud rate (high = force 9,600, low = 115 K or firmware setting) Master var PortA.3 'Output high=automaster-mode Input to RN-42 with weak pulldown TRISA=%010001 DEFINE DEBUG_REG PORTB ' Set Debug pin port DEFINE DEBUG_BIT 6 ' Set Debug pin bit DEFINE DEBUG_BAUD 57600 ' Set Debug baud rate DEFINE DEBUG_MODE 0 ' Set Debug mode: 0 = true, 1 = inverted DEFINE DEBUG_PACING 200'200 DEFINE DEBUGIN_REG PORTB ' Set Debugin pin port dEFINE DEBUGIN_BIT 7 ' Set Debugin pin bit DEFINE DEBUGIN_MODE 0 ' Set Debugin mode: 0 = true, 1 = inverted DEFINE HSER2_RCSTA 90h DEFINE HSER2_TXSTA 20h DEFINE HSER2_BAUD 57600 DEFINE HSER_RCSTA 90h DEFINE HSER_TXSTA 20h DEFINE HSER_BAUD 9600 LiftSwitch var PortB.0 'When low, shut off rows. STS var PortB.1 'Input Status, high when connected, low otherwise Discover var PortB.2 'Output Auto discovery = high Test var PortB.3 Defaults var PortB.4 'Output Set factory defaults Input to RN-42 with weak pulldown LCD Var PortB.5 BTX var PortB.6 'Wireless transmit BRX var PortB.7 'Wireless receive TRISB=%10000011 ADCON1.7=1 ADCON1.6=1 ADCON1.5=0 ADCON1.4=0 ADCON1.3=0 ADCON1.2=1 ADCON1.0=1 WRX var PortC.0 'Input RadarIn var PortC.1 'Input Config1 var PortC.2 'Input Config2 var PortC.3 'Input 'NC PortC.4 CTS var PortC.5 'Output WTX var PortC.6 'Output GRX var PortC.7 'Input TRISC=%10001111 GPGGA VAR BYTE[64] Blue var byte[64] RadarLow Var Word RadarHigh var Word RadarTotal var word qI VAR Word 'Quotient-integer------------------Maybe change to Byte qF VAR Word 'Quotient-fractional GSpeed var word Res var WOrd hh VAR BYTE 'hours mm VAR BYTE 'minutes ss VAR BYTE 'seconds sss var word 'milliseconds fix VAR WORD 'GPS fix latdeg VAR word 'degrees latitude latmin VAR byte 'minutes latitude latmin2 var word 'fractional minutes latitude totallat var long NS VAR BYTE 'north or south londeg VAR word 'degrees longitude lonmin VAR byte 'minutes longitude lonmin2 var long 'fractional minutes longitude totallon var WORD 'long EW VAR BYTE 'east or west Knots VAR byte 'speed in knots (units) Knotss var byte 'speed in fractional knots course var word 'heading dy VAR BYTE 'day mt VAR BYTE 'month yr VAR BYTE 'year quality var byte satnum var byte geoid var word geoiddec var byte dummy var byte altitude var word altitudedec var byte altunit var byte CBID var byte CBCount var byte RPM1X var word RPM2X var word RPM3X var word RPM4X var word RPM1R var word RPM2R var word RPM3R var word RPM4R var word RPM5R var word RPM6R var word RPM7R var word RPM8R var word RPM9R var word RPM10R var word RPM11R var word RPM12R var word RPM13R var word RPM14R var word RPM15R var word RPM16R var word RPM17R var word RPM18R var word RPM19R var word RPM20R var word RPM21R var word RPM22R var word RPM23R var word RPM24R var word RPM25R var word RPM26R var word RPM27R var word RPM28R var word RPM29R var word RPM30R var word RPM31R var word RPM32R var word RPM33R var word RPM34R var word RPM35R var word RPM36R var word RPM37R var word RPM38R var word RPM39R var word RPM40R var word RPM41R var word RPM42R var word RPM43R var word RPM44R var word RPM45R var word RPM46R var word RPM47R var word RPM48R var word RPM1T var word RPM2T var word RPM3T var word RPM4T var word RPM5T var word RPM6T var word RPM7T var word RPM8T var word RPM9T var word RPM10T var word RPM11T var word RPM12T var word RPM13T var word RPM14T var word RPM15T var word RPM16T var word RPM17T var word RPM18T var word RPM19T var word RPM20T var word RPM21T var word RPM22T var word RPM23T var word RPM24T var word RPM25T var word RPM26T var word RPM27T var word RPM28T var word RPM29T var word RPM30T var word RPM31T var word RPM32T var word RPM33T var word RPM34T var word RPM35T var word RPM36T var word RPM37T var word RPM38T var word RPM39T var word RPM40T var word RPM41T var word RPM42T var word RPM43T var word RPM44T var word RPM45T var word RPM46T var word RPM47T var word RPM48T var word RPM1O var word RPM2O var word RPM3O var word RPM4O var word RPM5O var word RPM6O var word RPM7O var word RPM8O var word RPM9O var word RPM10O var word RPM11O var word RPM12O var word RPM13O var word RPM14O var word RPM15O var word RPM16O var word RPM17O var word RPM18O var word RPM19O var word RPM20O var word RPM21O var word RPM22O var word RPM23O var word RPM24O var word RPM25O var word RPM26O var word RPM27O var word RPM28O var word RPM29O var word RPM30O var word RPM31O var word RPM32O var word RPM33O var word RPM34O var word RPM35O var word RPM36O var word RPM37O var word RPM38O var word RPM39O var word RPM40O var word RPM41O var word RPM42O var word RPM43O var word RPM44O var word RPM45O var word RPM46O var word RPM47O var word RPM48O var word TXID var byte EPDCount var byte BTPrefix var Long SimYN var byte T1 var word 'Used to measure RPM T2 var word 'Used to measure RPM T3 var word 'Used to measure RPM Prefix con $FE ' needed before each command LcdCls CON $51 ' clear LCD (use PAUSE 5 after) CursorPS con $45 'Cursor Position Backlight con $53 ' Backlighting 1-8 Contrast con $52 ' Contrast 1-50 Shit var byte BTArray var byte[4] Prefix1 var byte Prefix2 var byte Prefix3 var byte Prefix4 var byte RFCheck var bit ADCON0.0=0 ADCON1=%00001111 Symbol Capture = PIR2.0 ' CCP2 capture flag Symbol Overflow = PIR1.0 INTCON.7 = 1 INTCON.6 = 1 CCP2CON = %00000101 ' Capture mode, capture on rising edge T1CON = %00110011 ' TMR1 prescale=1, clock=Fosc/4, TMR1=on ANSELA=%00000000 ANSELB=%00000000 ANSELC=%00000000 Low Discover high lcd low Baud Low Master Low CTS pause 200 'GOSUB INITIALIZE 'gosub Send_BT do until STS=1 'gosub RFOOff pause 50 toggle lcd loop 'GOSUB INITIALIZE pause 100 CCPTMRS0.4=0 'CCP2 uses Timer1 CCPTMRS0.3=0 'CCP2 uses Timer1 PIE2.0=1 'CCPIE Enabled IPR2.0=0 'Low PRiority Interrupt
