DT_INTS and 18F26k22
Results 1 to 15 of 15
    Default Re: DT_INTS and 18F26k22
    this works for me
      CONFIG  FOSC = INTIO67
      CONFIG  PLLCFG = OFF
      CONFIG  PRICLKEN = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BOREN = SBORDIS
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  WDTPS = 32768
      CONFIG  CCP2MX = PORTC1
      CONFIG  PBADEN = OFF
      CONFIG  CCP3MX = PORTB5
      CONFIG  HFOFST = ON
      CONFIG  T3CMX = PORTC0
      CONFIG  P2BMX = PORTB5
      CONFIG  MCLRE = EXTMCLR
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
            ;INCLUDE "modedefs.bas"
            ;INCLUDE"ALLDIGITAL.pbp"
            ;INCLUDE "HomeAutomationVars.bas"  'Open with PBP editor
            INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
            INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
        define OSC 8
        DEFINE DEBUG_REG PORTB
        DEFINE DEBUG_BIT 7
        DEFINE DEBUG_BAUD 9600
        ' Set Debug mode: 0 = true, 1 = inverted
        DEFINE DEBUG_MODE 0
        x var word
        rxflag   var bit
        rxchar var byte
     INT_Handler    RX1_INT ,    _read_serial,   PBP,  no
     INT_CREATE             ; Creates the interrupt processor
    OSCCON = $60   ;  OSC 8
    anselc = 0
    RCSTA  = $90   ' Enable serial port & continuous receive
    TXSTA  = $20   ' Enable transmit, BRGH = 0
    SPBRG  = 51    ' 9600 Baud @ 8MHz, 0.16%
    SPBRGH = 0
    BAUDCON.3 = 1  ' Enable 16 bit baudrate generator
    baudcon1= baudcon1&%11001111  ;invert tx/rx polarity   for usb-tty adapter
    TRISB.7 = 0  ;DEBUG
    LATB.7  = 1  ;DEBUG
    @   INT_ENABLE   RX1_INT     ; enable external (RX) interrupts
    debug "running",13,10
        debug "."
        for x = 1 to 1000
          if rxflag then
             Debug 13,10,"got !! asc chr ",#rxchar,13,10
             rxflag=0
          pauseus 1000
        next x
    Goto main
    read_serial:
        rxflag = 1
        rxchar = rc1reg
    @   INT_RETURN
    this is much better , get rid of all those nasty pauses and goto's
     ;pic18f26k22 rx1 int demo
      CONFIG  PLLCFG = OFF
      CONFIG  FCMEN = OFF
      CONFIG  IESO = OFF
      CONFIG  PWRTEN = OFF
      CONFIG  BORV = 190
      CONFIG  WDTEN = ON
      CONFIG  PBADEN = OFF
      CONFIG  HFOFST = ON
      CONFIG  STVREN = ON
      CONFIG  LVP = OFF
      CONFIG  XINST = OFF
      CONFIG  DEBUG = OFF
      CONFIG  CP0 = OFF
      CONFIG  CP1 = OFF
      CONFIG  CP2 = OFF
      CONFIG  CP3 = OFF
      CONFIG  CPB = OFF
      CONFIG  CPD = OFF
      CONFIG  WRT0 = OFF
      CONFIG  WRT1 = OFF
      CONFIG  WRT2 = OFF
      CONFIG  WRT3 = OFF
      CONFIG  WRTC = OFF
      CONFIG  WRTB = OFF
      CONFIG  WRTD = OFF
      CONFIG  EBTR0 = OFF
      CONFIG  EBTR1 = OFF
      CONFIG  EBTR2 = OFF
      CONFIG  EBTR3 = OFF
      CONFIG  EBTRB = OFF
    define OSC 8
    DEFINE DEBUG_BIT 7
    DEFINE DEBUG_MODE 0
    x         var  byte bank0
    flag      var  byte bank0
    rxflag    var flag.7
    dotflag   var flag.0
    rxchar    var byte
     INT_Handler    RX1_INT  , _read_serial,asm,no
     INT_Handler    TMR1_INT , _TOCK,asm,no
    clear
    anselc = 0
    SPBRGH = 0
    T1CON=1         ;32mS tick
    TRISB.7 = 0  ;DEBUG
    LATB.7  = 1  ;DEBUG
    pause 2000    ;give me time to setup debug
    debug 13,10 ,"listening "
    @ INT_ENABLE  TMR1_INT
    x=31
    while 1
        if rxflag then
             ;Debug 13,10,"got asc chr ",#rxchar,13,10
             tx1reg = rxchar     ;echo back
             rxflag = 0
        if dotflag then
            debug "."
            dotflag=0
    wend
    read_serial:
        bsf _flag ,7
        MOVE?BB RC1REG,_rxchar
        INT_RETURN
    TOCK:
    asm
        DECFSZ  _x,F
        BRA BREXIT
        movlw 31
        bsf _flag ,0
        movwf _x
    BREXIT
        BCF PIR1 ,0
        INT_RETURN
    Jul 2009
    Ohio, USA
    Bingo!
    Thanks Richard, this line
    anselc = 0 '0 = Digital input buffer enabled
    did it!
    Mike
  1. DT_Ints w/18F26K22 stop if incorrect baud rate
    By Dave in forum mel PIC BASIC Pro
    Last Post: - 8th September 2017, 14:54
  2. PROBLEM ICD 18F26K22 no work
    By FRAN200 in forum mel PIC BASIC Pro
    Last Post: - 4th July 2016, 13:55
  3. 18F26K22 slow startup
    Last Post: - 7th January 2014, 23:10
  4. Compiling for 18F26K22 - Does anyone have a solution for me?
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 28th August 2012, 13:49
  5. Anyone found a Bootloader for 18F26K22?
    Last Post: - 11th August 2011, 19:23
