Ds3231 rtc usage
Results 1 to 25 of 25
    Default Re: Ds3231 rtc usage
    from the book
    I2CREAD DataPin, ClockPin, Control,{Address,}[Var{,Var...}]{,Label}
    Dec 2012
    Türkiye
    from the book
    Indeed from the book yet not PBP's but DS3231's ... Obviously you haven't seen the number written in different format in my message .. Observe the bold formatted number .. The slave address + direction bit ...
    - Ipsa scientia potestas est -
    again
    from the book (i2cread)
    The upper 7 bits of the
    Control byte contain the control code along with chip select
    or additional address information, depending on the particular device. The low
    order bit is an internal flag indicating whether it is a read or write command and
    should be kept clear.
    Dec 2012
    Türkiye
    again
    So there is no use of the lsb of the control bit , then it's determined by the command's itself ... I mean if it is I2CREAD op then it automatically determines this bit itself ... Am I correct ? I'll give it a try once more by using
    i2cREAD SDA,SCL,%11010000,$00,var
    At least I may read the control or the status register ...
    Thanks ..
    Dec 2012
    Türkiye
    Quote Originally Posted by gunayburak View Post
    Thanks ..
    No luck with that either ... I have even pulled the scl and sda up with 4.7 k resistors ... neither I can write nor read the control and status registers ... 😕
    Quebec, Canada
    I don't want to be rude but RTFM, p.156:
    The Address size sent (byte or word) is determined by the size of the variable that is used. If a byte-sized variable is used for the Address, an 8-bit address is sent. If a word-sized variable is used, a 16-bit address is sent. Be sure to use the proper sized variable for the device you wish to communicate with. Constants should not be used for the Address as the size can vary dependent on the size of the constant. Also, expressions should not be used as they can cause an improper Address size to be sent.
    Pull-up resistors are mandatory for I2C. Keep trying, the DS3231 has nice features like alarms and is more accurate than the DS1307.
    you keep showing this
    it should be (apart from what michelj has pointed out)
    i2cREAD SDA,SCL,%11010000,0,[var]
    yet to be addressed :-
    none of the code you have posted seems to have the correct syntax for i2c commands .
    do you have a accurate schematic of your setup ?
    can you flash a led with your pic ? do the scl,sda pins do anything ?
    do you have a oscilloscope or a logic analyser to check output ?
    what do you get when you read the command and status regs of the ds3231 (0x0e,0x0f) ?
  1. Usage of built-in DAC ?
    Last Post: - 16th December 2014, 06:59
  2. Accurate serin usage?
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 10th July 2009, 09:36
  3. Interrupt usage
    Last Post: - 20th April 2008, 17:20
  4. Serin usage?
    By champion in forum mel PIC BASIC Pro
    Last Post: - 24th January 2007, 01:57
  5. HPWM usage with the 18F6520
    By slxrti in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 17:57
