Ds3231 rtc usage
Results 1 to 25 of 25
    Dec 2012
    Türkiye
    Default Ds3231 rtc usage
    Hello everyone ;
    I'm trying to get my DS3231 working but no luck so far ... I've read already posted threads about this IC but they don't help ..
    Here is the code I'm using on PIC16f628A
    '*  Name    : RTC.BAS                                           *
    '*  Author  : Burak Günay                                       *
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 8/9/2015                                          *
    '*  Notes   : REAL TIME CLOCK WITH DS3231                       *
    #config
      __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _LVP_OFF & _CP_OFF
    #endconfig
    Define OSC 4
    DEFINE LCD_EREG	    PORTA	'LCD Enable port
    DEFINE LCD_EBIT		6		'LCD Enable port pin
    DEFINE LCD_RSREG	PORTA	'LCD RS port
    DEFINE LCD_RSBIT	7		'LCD RS port pin
    define LCD RWREG    PORTA   'LCD R/W port
    define LCD_RWBIT    4       'LCD R/W port pin
    DEFINE LCD_DREG	    PORTB	'LCD data port
    DEFINE LCD_DBIT		4		'LCD data port starts from pin x
    DEFINE LCD_BITS     4       'LCD bus size 4 or 8
    DEFINE LCD_LINES	2		'LCD lines
    PORTA=%00000000 :   PORTB=%00000000
    CMCON=%00000111 'Comparators off
    OPTION_REG.7=0  'INTERNAL WEAK PULL-UPS OF PORTB ARE ENABLED.
    TRISA=%00000000 :   TRISB=%00000000
    SDA VAR PORTB.0
    SCL VAR PORTB.1
    i   var byte
    q   var byte[7]
    tens    var byte
    units   var byte
    tmp     var byte
    lcdout $FE,1
    Q[0]=0
    Q[1]=50
    Q[2]=20
    Q[3]=1
    Q[4]=8
    Q[5]=9
    Q[6]=15
    GOSUB TOBCD
    i2cwrite sda,scl,%11010000,$00,Q[0],Q[1],Q[2],Q[3],Q[4],Q[5],Q[6]
    MAIN:'>>>>>>>>>>>>>>>>>>>>>>>>>>>
    i2cREAD  SDA,SCL,%11010001,$00,Q[0],Q[1],Q[2],Q[3],Q[4],Q[5],Q[6]
    GOSUB TODEC
    LCDOUT $FE,$80, DEC2 Q[2],":",DEC2 Q[1],":",DEC2 Q[0]
    LCDOUT $FE,$C0, DEC2 Q[4],":",DEC2 Q[5],":",DEC2 Q[6]
    GOTO MAIN'<<<<<<<<<<<<<<<<<<<<<<<
    '******************************DECIMAL TO BCD***********************************
    TOBCD:              'Conversion to BCD
    for i=0 to 6
    TMP = Q[i] DIG 1    'Get TENS to temp variable
    TENS = TMP << 4
    UNITS = Q[i] DIG 0  'Get UNITS to units variable
    Q[i] = TENS + UNITS
    next i
    '**************************BCD TO DECIMAL SYSTEM********************************
    TODEC:
    for i=0 to 6
    TMP = Q[i] & %01110000
    TENS = TMP >> 4
    UNITS = Q[i] & %00001111
    Q[i] = TENS * 10 + UNITS
    next i
    Where do I make the mistake .. I've read its datasheet and wrote a code accordingly step by step but there must be something I'm missing .. By the way I supply the pic and the DS3231 with 5V
    Thanks in advance
    - Ipsa scientia potestas est -
    Default Re: Ds3231 rtc usage
    probably not a good idea to keep starting new threads then . whats the history ? what has been tried and failed ?
    so we start again at the beginning
    what is the actual problem ?
    do you have a accurate schematic of your setup ?
    do you have suitable pullup resistors ?
    can you flash a led with your pic ? do the scl,sda pins do anything ?
    do you have a oscilloscope or a logic analyser to check output ?
    have you tried to read the command and status regs of the ds3231 (0x0e,0x0f) ? if so what do you get ?
    is the ds3231 osc running ?
    Quebec, Canada
    I think each I2C call address must be passed trought a variable:
        I2C_Adr = $0F
        I2C_NACK = 0
        I2CWrite RTC_SDA, RTC_SCL, $D0, I2C_Adr, [RTC_Reg], I2CNACK
    I've made an include file to deal with my DS3231 if you are interested:
    '*  Name    : ..\_INCLUDE\DS3231.PBP                            *
    '*  Author  : Michel Jasmin                                     *
    '*  Notice  : NOT Copyright (c) 2015 Michel Jasmin              *
    '*          : All Rights NOT Reserved                           *
    '*  Date    : 2015-04-11                                        *
    GOTO OverDS3231
    'ToDo: Alias pins
    'RTC_SDA Var PORTA.4
    'RTC_SCL Var PORTA.5
    '------------ Const -------------------------
    AL1_OpS      CON %00001111  'once per second
    AL1_S        CON %00001110  'when seconds match
    AL1_MS       CON %00001100  'when minutes and seconds match
    AL1_HMS      CON %00001000  'when hours, minutes and seconds match
    AL1_DtHMS    CON %00000000  'when DATE, hours, minutes and seconds match
    AL1_DayHMS   CON %00010000  'when DAY, hours, minutes and seconds match
    AL2_OpM      CON %00001110  'once per minute
    AL2_M        CON %00001100  'when minutes match
    AL2_HM       CON %00001000  'when hours and minutes match
    AL2_DtHM     CON %00000000  'when DATE, hours and minutes match
    AL2_DayHM    CON %00010000  'when DAY, hours and minutes match
    '------------ Variables -------------------------
    RTCYear     Var Byte
    RTCMonth    Var Byte
    RTCDate     Var Byte
    RTCDay      Var Byte
    RTCHour     Var Byte
    RTCMin      Var Byte
    RTCSec      Var Byte
    RTCCtrl     Var Byte
    HexValue    var byte
    DecValue    var byte
    I2C_Adr     VAR BYTE
    I2C_Flags   VAR BYTE
    I2C_NACK    VAR I2C_Flags.0
    'General Register variable
    RTC_Reg var byte
    'Aliases for Control Register @ $0E
    'EOSC BBSQW CONV RS2 RS1 INTCN A2IE A1IE
    RTC_EOsc    var RTC_Reg.7   'Enable Oscillator
    RTC_BBSQW   var RTC_Reg.6   'Battery-Backed Square-Wave Enable
    RTC_CONV    var RTC_Reg.5   'Convert Temperature
    RTC_RS2     var RTC_Reg.4   'Rate Select
    RTC_RS1     var RTC_Reg.3   'Rate Select
    RTC_INTCN   var RTC_Reg.2   'Interrupt Control
    RTC_A2IE    var RTC_Reg.1   'Alarm 2 Interrupt Enable
    RTC_A1IE    var RTC_Reg.0   'Alarm 1 Interrupt Enable
    'Aliases for Status Register @ $0F
    'OSF x x x EN32kHz BSY A2F A1F
    RTC_OSF     var RTC_Reg.7   'Oscillator Stop Flag
    RTC_EN32kHz var RTC_Reg.3   'Enable 32kHz Output
    RTC_BSY     var RTC_Reg.2   'Busy
    RTC_A2F     var RTC_Reg.1   'Alarm 2 Flag
    RTC_A1F     var RTC_Reg.0   'Alarm 1 Flag
    ' Subroutine to write time to RTC
    SetTime:
        I2C_NACK = 0
        I2C_Adr = $00
        I2CWrite RTC_SDA, RTC_SCL, $D0, I2C_Adr, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear], I2CNACK
    ' Subroutine to read time from RTC
    GetTime:
        I2C_NACK = 0
        I2C_Adr = $00
        I2CRead RTC_SDA, RTC_SCL, $D0, I2C_Adr, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate, RTCMonth, RTCYear], I2CNACK
    SetAlarm1:
        'Usage:
        '       set values to RTCSec, RTCMin, RTCHour, [RTCDay | RTCDate]
        '       RTC_Reg = AL1_HMS     'Set alarm type
        '       gosub SetAlarm1
        HSEROUT2 ["Alarm1 at: ", hex2 RTCDate, " ", hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec, 13, 10]
        'HSEROUT2 ["RTC_Reg = ", bin8 RTC_Reg, 13, 10]
        I2C_Adr = $07
        I2C_NACK = 0
        RTCSec.7 = RTC_Reg.0    'A1M1
        RTCMin.7 = RTC_Reg.1    'A1M2
        RTCHour.7 = RTC_Reg.2   'A1M3
        'Test A1M4
        if RTC_Reg.3 = 1 then
            'alarm by time only
            'Get the alarm1 date
    '        I2C_Adr = $0A
    '        I2CRead SDA, RTC_SCL, $D0, I2C_Adr, [RTCDate], I2CNACK
            RTCDate.7 = RTC_Reg.3   'A1M4
            RTCDate.6 = 0           'DY/DT!
            I2CWrite RTC_SDA, RTC_SCL, $D0, I2C_Adr, [RTCSec, RTCMin, RTCHour, RTCDate], I2CNACK
            HSEROUT2 ["alarm1 by time only", 13, 10]
            'HSEROUT2 [" at: ", bin8 RTCDate, " ", bin8 RTCHour, ":", bin8 RTCMin, ":", bin8 RTCSec, 13, 10]
            'alarm by time and (DAY or DATE)
            if RTC_Reg.4 = 1 then
                'alarm by DAY
                RTCDay.7 = 0    'A1M4
                RTCDay.6 = 1    'DY/DT!
                I2CWrite RTC_SDA, RTC_SCL, $D0, I2C_Adr, [RTCSec, RTCMin, RTCHour, RTCDay], I2CNACK
                HSEROUT2 ["alarm1 by DAY", 13, 10]
                'HSEROUT2 [" at: ", bin8 RTCDay, " ", bin8 RTCHour, ":", bin8 RTCMin, ":", bin8 RTCSec, 13, 10]
                'alarm by DATE
                RTCDate.7 = 0   'A1M4
                HSEROUT2 ["alarm1 by DATE", 13, 10]
    SetAlarm2:
        'Usage:
        '       set values to RTCMin, RTCHour, [RTCDay | RTCDate]
        '       gosub SetAlarm1
        HSEROUT2 ["Alarm2 at: ", hex2 RTCDate, " ", hex2 RTCHour, ":", hex2 RTCMin, 13, 10]
        I2C_Adr = $0B
        I2C_NACK = 0
        'Test A1M4
            'alarm by time only
            I2CWrite RTC_SDA, RTC_SCL, $D0, I2C_Adr, [RTCMin, RTCHour, RTCDate], I2CNACK
            HSEROUT2 ["alarm2 by time only", 13, 10]
    '        HSEROUT2 [" at: ", bin8 RTCDate, " ", bin8 RTCHour, ":", bin8 RTCMin, 13, 10]
                'alarm by DAY
                RTCDay.7 = 0    'A1M4
                I2CWrite RTC_SDA, RTC_SCL, $D0, I2C_Adr, [RTCMin, RTCHour, RTCDay], I2CNACK
                HSEROUT2 ["alarm2 by DAY", 13, 10]
    '            HSEROUT2 [" at: ", bin8 RTCDay, " ", bin8 RTCHour, ":", bin8 RTCMin, 13, 10]
                'alarm by DATE
                RTCDate.7 = 0   'A1M4
                HSEROUT2 ["alarm2 by DATE", 13, 10]
    'GetAlarm1:
    '    I2C_Adr = $07
    '    I2CRead RTC_SDA, RTC_SCL, $D0, I2C_Adr, [RTCSec, RTCMin, RTCHour, RTCDay, RTCDate], I2CNACK
    '    RETURN
    ReadControlRegister:
        I2C_Adr = $0E
        I2C_NACK = 0
        I2CRead RTC_SDA, RTC_SCL, $D0, I2C_Adr, [RTC_Reg], I2CNACK
    WriteControlRegister:
        I2C_Adr = $0E
        I2C_NACK = 0
    ReadStatusRegister:
        I2C_Adr = $0F
        I2C_NACK = 0
    WriteStatusRegister:
        I2C_Adr = $0F
        I2C_NACK = 0
    I2CNACK:
        I2C_NACK = 1
    Hex2BCD:
        DecValue = 10 * (HexValue >> 4)
        DecValue = DecValue + (HexValue & $0F)
    BCD2Hex:
        HexValue = (DecValue DIG 0) + ((DecValue DIG 1) << 4)
    OverDS3231:
    Usage:
    'Init
        gosub ReadStatusRegister
        RTC_OSF = 0
        RTC_EN32kHz = 1
        RTC_A2F = 0
        RTC_A1F = 0
        gosub WriteStatusRegister
        RTC_Reg = %00000100
        'RTC_EOsc    var RTC_Reg.7   'Enable Oscillator
        'RTC_BBSQW   var RTC_Reg.6   'Battery-Backed Square-Wave Enable
        'RTC_CONV    var RTC_Reg.5   'Convert Temperature
        'RTC_RS2     var RTC_Reg.4   'Rate Select
        'RTC_RS1     var RTC_Reg.3   'Rate Select
        'RTC_INTCN   var RTC_Reg.2   'Interrupt Control
        'RTC_A2IE    var RTC_Reg.1   'Alarm 2 Interrupt Enable
        'RTC_A1IE    var RTC_Reg.0   'Alarm 1 Interrupt Enable
        gosub WriteControlRegister
    ' Set initial time to 2014-01-01 8:02:01, day 4
    RTCYear = $14
    RTCDay = $04
    RTCMonth = $01
    RTCDate = $01
    RTCHour = $08
    RTCMin = 2
    RTCSec = 1
    Gosub SetTime   ' Set the time
    'Set Alarm 1
        RTCHour = 2
        RTCMin = 0
        RTCSec = 0
        RTC_Reg = AL1_MS
        gosub SetAlarm1
    Dec 2012
    Türkiye
    Let me get this straight ...
    A read op from DS3231 must be in this form I think ...
    i2cREAD SDA,SCL,%11010001,$00,var
    Am I mistaken ?
    from the book
    I2CREAD DataPin, ClockPin, Control,{Address,}[Var{,Var...}]{,Label}
    Dec 2012
    Türkiye
    from the book
    Indeed from the book yet not PBP's but DS3231's ... Obviously you haven't seen the number written in different format in my message .. Observe the bold formatted number .. The slave address + direction bit ...
    again
    from the book (i2cread)
    The upper 7 bits of the
    Control byte contain the control code along with chip select
    or additional address information, depending on the particular device. The low
    order bit is an internal flag indicating whether it is a read or write command and
    should be kept clear.
    Oct 2009
    Quote Originally Posted by gunayburak View Post
    Thanks in advance
    I'm no expert, but I don't think the PIC you are using has a Master Synchronous Serial Port (MSSP) module so doesn't actually support i2C communications. There are certainly no pins marked SCL and SDA in the datasheet
    Juts checked here http://www.microchip.com/ParamChartS...?branchID=1005 and the PIC you are using has no i2c support
    Scampy, I2CREAD and I2CWRITE are PBP "software" routines to emulate I2C operations. You don't need to have MSSP capability in hardware to use them. Infact you can use almost any pin to do the interface.
    EN82fn
    Dec 2012
    Türkiye
    again
    So there is no use of the lsb of the control bit , then it's determined by the command's itself ... I mean if it is I2CREAD op then it automatically determines this bit itself ... Am I correct ? I'll give it a try once more by using
    i2cREAD SDA,SCL,%11010000,$00,var
    At least I may read the control or the status register ...
    Thanks ..
    Oct 2009
    Dave,
    Interesting to know... but wouldn't it be better to use a chip that had an I2C module, rather than rely on software emulation ? Or doen't PBP make use of the physical modules incorporated in various PICs ?
    Dec 2012
    Türkiye
    Thanks ..
    No luck with that either ... I have even pulled the scl and sda up with 4.7 k resistors ... neither I can write nor read the control and status registers ... 😕
    Quebec, Canada
    I don't want to be rude but RTFM, p.156:
    The Address size sent (byte or word) is determined by the size of the variable that is used. If a byte-sized variable is used for the Address, an 8-bit address is sent. If a word-sized variable is used, a 16-bit address is sent. Be sure to use the proper sized variable for the device you wish to communicate with. Constants should not be used for the Address as the size can vary dependent on the size of the constant. Also, expressions should not be used as they can cause an improper Address size to be sent.
    Pull-up resistors are mandatory for I2C. Keep trying, the DS3231 has nice features like alarms and is more accurate than the DS1307.
    you keep showing this
    it should be (apart from what michelj has pointed out)
    i2cREAD SDA,SCL,%11010000,0,[var]
    yet to be addressed :-
    none of the code you have posted seems to have the correct syntax for i2c commands .
    what do you get when you read the command and status regs of the ds3231 (0x0e,0x0f) ?
    Dec 2012
    Türkiye
    I'm a total idiot ... I'll correct the code ...
    Thanks guys ...
    Dec 2012
    Türkiye
    Now the clock ticks like a clock But another problem has revealed .... The RTC I'm using has arrived in a form of a module bought from eBay it has everything on it including an EEPROM ... But the thing is when I remove the primary power source it stops ticking , but I assume the 3V battery on it (it's full by the way 3.2V measured) would take the rebound as it should but it doesn't , I guess there is something I must set in the register which I can not see ... Any ideas ?
    Dec 2012
    Türkiye
    EOSC bit it was .. It must be cleared for once .. Then the Vbat takes the job when the primary power source is removed ...
    Thanks to everyone for correcting the syntax mistake in my code .. The paranthesis .... God .. How can I be so blind ...
    Mar 2008
    'DS3231
    'Can anyone tell me why this code does not work?
    settime:
    sda var portb.6
    scl var portb.5
    cntrl CON $10
    rtc CON %11010000
    SecReg CON $00
    hours = $16
    minutes = $40
    seconds = $00
    month = $01
    date = $04
    year = $16
    day = $02
    I2cwrite sda,scl, rtc, $D0, $00,[seconds,minutes,hours,day,date,month,year,cntrl]
    'This line works fine to read from the DS3231
    I2CRead sda,scl, rtc, secreg,[seconds,minutes,hours,day,date,month,year]
    Quebec, Canada
    See page 159:
    I2C_Adr     VAR BYTE
    I2C_Adr = $00
    I2cwrite sda,scl, rtc, $D0, I2C_Adr,[seconds,minutes,hours,day,date,month,year,cntrl]
    HTH
    Mar 2008
    After reading your post I took a look at all of the things you mentioned. While doing this I noticed that I had put the RTC variable in the I2cwrite statement two times .
    This did not work > I2cwrite sda,scl,rtc,$D0,I2C_Adr,[seconds,minutes,hours,day,date,month,year,cntrl]
    This works > I2cwrite sda,scl,$D0,I2C_Adr,[seconds,minutes,hours,day,date,month,year,cntrl]
    I would have looked at that code for a week if you had not helped me!
    Thank You !
    rc
    Dec 2008
    Ploiesti, ROMANIA
    Hi ! Can you post your full code for DS3231 ? I intend to build something based on Nokia 3310 display ... (upgrade of this : http://www.picbasic.co.uk/forum/show...083#post129083 )
    Quebec, Canada
    Quote Originally Posted by fratello View Post
    See attached file. I use it as an include.
    Displaying time is like
    '----[ ALIAS }-------------------------
    RTC_SDA         Var PORTB.3
    RTC_SCL         Var PORTB.2
    '----[ INCLUDES }-------------------------
    INCLUDE "..\_Include\DS3231.pbp"
    gosub GetTime
    HSEROUT2  [hex2 RTCHour, ":", hex2 RTCMin, ":", hex2 RTCSec, 13, 10]
    Dec 2008
    Ploiesti, ROMANIA
    Thank You so much !
    Nov 2006
    Ventura, CA
    Quote Originally Posted by MichelJasmin View Post
    RTC_SDA         Var PORTB.3
    RTC_SCL         Var PORTB.2
    gosub GetTime
    Michel, I know it's been a long time since this was posted, but doesn't the statement "GOTO OverDS3231" skip over the entire program? Or is this just a case of me not understanding how include files work? -Jeff
    Quebec, Canada
    Quote Originally Posted by JBKerner View Post
    It skips the include file which contains only functions to be called.
  1. Usage of built-in DAC ?
    Last Post: - 16th December 2014, 05:59
  2. Accurate serin usage?
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 10th July 2009, 08:36
  3. Interrupt usage
    Last Post: - 20th April 2008, 16:20
  4. Serin usage?
    By champion in forum mel PIC BASIC Pro
    Last Post: - 24th January 2007, 00:57
  5. HPWM usage with the 18F6520
    By slxrti in forum mel PIC BASIC Pro
    Last Post: - 17th November 2005, 16:57
