Temperature does not go below 0
Results 1 to 17 of 17
    Sep 2014
    Default Re: Temperature does not go below 0
    An example needed.iam using 10 bit adc and sensor is 10k thermistor.
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by amodpathak View Post
    A Thermistor changes resistance with temperature change. To read a 'remote' Thermistor a 'completion resistor' (CR), typically 1000 ohms, is used in series and a known voltage is applied to the circuit then the voltage drop across the CR is measured. If the thermistor is on the board then voltage drop across the Thermistor can be measured directly. The resistance changes with temperature change which is not linear and this is required
    http://en.wikipedia.org/wiki/Thermistor#NTC
    Steinhart–Hart equation
    For accurate temperature measurements, the resistance/temperature curve of the device must be described in more detail. The Steinhart–Hart equation is a widely used third-order approximation:
    1 \ T = a + b\,\ln(R) + c\,(\ln(R))^3
    where a, b and c are called the Steinhart–Hart parameters, and must be specified for each device. T is the absolute temperature and R is the resistance.
    As you can see natural logarithms are needed to use this conversion, which are not available with PBP.
    Oct 2009
    Why not use a DS18B20 - It would be a lot simpler going digital
    Dec 2010
    Or you could simply use a look-up table...
  1. IR Temperature Sensor
    By TravisM in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2012, 16:04
  2. read temperature
    By breeno in forum General
    Last Post: - 6th October 2010, 13:55
  3. Temperature Logging
    By tonyfelloni in forum mel PIC BASIC Pro
    Last Post: - 18th June 2008, 11:29
  4. Temperature Meter
    By Mohammed Mazed in forum Schematics
    Last Post: - 18th December 2006, 03:12
  5. temperature controller
    By PoTeToJB in forum mel PIC BASIC Pro
    Last Post: - 24th April 2006, 21:01
