Hi All
I'm just looking to be pointed in the right direction on this one, save me barking up the wrong tree (or trees!)
I have a project (incubator) that is obviously going to have a temp sensor within, (Not choosen yet). Infrequently I will want to connect the incubator to the PC where I would like to stream data to the PC containin the temperature and read times in order to check the PID control and response times.
Can I stream this data to the PC to be loaded into one continuous file. Does it need to be stored on an Eeprom first and then all data sent to a hyperterminal? I have seen much hatred for the hyperterm application so is there a better free alternative to work with?
Thankin You..
