temperature controller
Results 1 to 4 of 4
    johor,Malaysia
    Default temperature controller
    i want build temperature controller using PIC16f877, temperature sensor ( LM35 )
    and Lcd.
    can some one help me..
    Talking With a little help from your brain ...
    Quote Originally Posted by PoTeToJB
    and Lcd.
    YES ...
    Some reading of the Parallax Industrial Control Application manual could lead you to an acceptable project.
    see : http://www.parallax.com/dl/docs/books/edu/ic.pdf
    johor,Malaysia
    thank..
    i want build the projek like this link
    http://www.rentron.com/PicBasic/LM34.htm
    but just change the sensor to LM35 and use lcd (HD44780)..
    can some one help me for change the code
    Sep 2003
    INDIA
    Default Start the Project !
    U can atleast start the project and the code , and when you get stuck, you can refer back to the forum.
    If you are looking for a ready made solution, the use google to search the net. I am sure you must have done that.
    This place is all for help and advice, but when you get stuck, not .......
    This point is well explained by other guru's some where ......
    regards
  1. Replies: 10
    Last Post: - 17th February 2012, 08:19
  2. Temperature Controller using PIC16F628A
    By bentech4u in forum mel PIC BASIC
    Last Post: - 14th March 2010, 20:44
  3. DS18S20 reading negative temperature
    By srob in forum mel PIC BASIC Pro
    Last Post: - 28th December 2007, 22:21
  4. Conversion problem
    By eva in forum mel PIC BASIC Pro
    Last Post: - 15th March 2007, 19:21
  5. Help for decimal conversion
    Last Post: - 15th March 2007, 19:20
