how to use external crystal?
Results 1 to 27 of 27
    Oct 2014
    Default Re: how to use external crystal?
    Thanks for this. I'm using pbp3 so I copied and pasted and it compiled. The program still doesn't seem to time correctly tho, which I describe below.
    -- How did you know this was the correct configuration? I've read many threads, tried many different suggestions including some that use @ DEVICE. I've looked in the manual and went by its examples. The manual comes close but it has a couple spaces before the CONFIG, which it shows in caps and yours is lowercase. This is what I get when I type it in:
    __config _CONFIG1, _HS_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOR_ON & _IESO_ON & _FCMEN_ON & _LVP_OFF & _DEBUG_OFF
    __config _CONFIG2, _BOR40V & _WRT_OFF
    #endconfig
    Note that CONFIG is uppercase and endconfig is lowercase, tho when I cut and pasted the code they were both uppercase. Go figure.
    How did you know your code would work? Trial and error? Is there a book you can recommend? I spent hours and hours getting nowhere.
    To test the timing I toggle a bit and look at it with a scope. This is the code:
    portb.7 = 0
    PAUSEUS 100
    portb.7 = 1
    PAUSEUS 100
    portb.7 = 0
    pauseus 100
    portb.7 = 1
    PAUSEUS 100
    portb.7 = 0
    pauseus 100
    portb.7 = 1
    pauseus 100
    portb.7 = 0
    I have OSCCON set to select the external crystal and define the oscillator as 20:
    OSCCON = %01111110 'runs at 20 MHz set in configuration bits
    define OSC 20
    (again the word define is lowercase in pbp but copies and pastes as uppercase, tho I show it ias it appears on pbp)
    I expect
    portb.7 to toggle at 100usec high, 100usec low. Instead it is 250usec hi/lo. It's as if the pic is running at 8MHz but doing the timing calculations at 20MHz.
    What am I missing?
    don't trust copy and paste for case sensitive defines
    Quote Originally Posted by tbarania View Post
    What am I missing?
    Micro Code Studio is changing what you see, whereas what you copy paste is what you have. To fix this, open MCS and click the tab marked view, then click Editor Options,in Options click the tab Highlighter Options, at the bottom you will see Reserved Word Formatting, click the checkbox marked "DEFAULT" and click OK to close the box.
  1. 1 x external crystal oscillator for multiple PICs
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 27th November 2013, 15:05
  2. Help using this crystal?
    By Kamikaze47 in forum General
    Last Post: - 14th November 2009, 15:48
  3. 16f877A and tmr1 external crystal question
    By comwarrior in forum General
    Last Post: - 13th July 2009, 01:40
  4. Pic or Crystal
    By jetpr in forum General
    Last Post: - 16th September 2008, 02:56
  5. Crystal
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 12th April 2005, 17:05
