Pic or Crystal
Results 1 to 3 of 3
Thread: Pic or Crystal
    Puerto Rico
    Exclamation Pic or Crystal
    Hello
    If any one have expert opinion in how to now if the Crystal is bad or the pic chip is bad.
    i made some board and no all work fine but i need to now what is the problems before change any parts..
    thanks for the help .
    My Hobbies is PicBasic PRO
    - Try the Internal Oscillator. If the PIC has one.
    - Use another PIC project that you know is working with a crystal, and try the suspect crystal.
    - Use another PIC project that you know is working with a crystal, and connect the OSC2 pin to the OSC1 pin of the suspect PIC.
    - Use a 555 type oscillator to create a frequency to apply to the OSC1 pin of the suspect PIC.
    - Use a 74HC04 to create an oscillator that you can test the suspect crystal with.
    - Oh, and check your config lines for the proper Oscillator Configuration.
    Might want to try that one first.
    <br>
    Puerto Rico
    Thumbs up
    thanks for the help
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. PIC with 100 kHz crystal
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 28th January 2008, 10:09
  3. Crystal osc running but PIC not using it
    By p15218 in forum mel PIC BASIC Pro
    Last Post: - 18th February 2007, 23:33
  4. More than one Pic to one crystal?
    By Jcee324 in forum Schematics
    Last Post: - 19th July 2006, 20:40
    Last Post: - 12th March 2005, 00:14
