I2C lcd ( arduino ) with PICBASIC, help
Page 1 of 3 123 LastLast
Results 1 to 40 of 93
    Jun 2008
    Varese , Italy
    Default I2C lcd ( arduino ) with PICBASIC, help
    good day,
    I have to interface the I2C LCD (arduino like) using picbasic.
    Any suggestion or code example please ?
    Thanks in advance.
    Ambrogio
    IW2FVO
    May 2012
    Merseyside, UK
    Default Re: I2C lcd ( arduino ) with PICBASIC, help
    Have a look at this :-
    Forgive some of the comments.... Code did help me out :-)
    http://www.picbasic.co.uk/forum/showthread.php?t=17302
    Jun 2008
    Varese , Italy
    Thanks Andy for the code,
    I am not a good programmer and I would like to convert the PBP program that is normally used now to EASY control the I2C display.
    At the moment I am using this piece of code:
    INS CON 254 ' $FE: INSTRUCTION COMMAND MODE
    CLR CON 1 ' CLEAR LCD , GOTO FIRST LINE, FIRST CHARACTER
    DG CON 223 ' DEG SYMBOL °
    LINE1 CON 128 ' $80: GOTO LINE 1
    LINE2 CON 192 ' $C0: GOTO LINE 2
    LINE3 CON 148 ' $94: GOTO LINE 3
    LINE4 CON 212 ' $D4: GOTO LINE 4
    And then I do the the following to write my own data on it:
    LCDOUT INS, LINE2, " V=", DEC2 VLT/10, ".", DEC1 VLT
    How could I translate the above in I2C enviroment for displaying ?
    Thanks for the assistance
    Ambrogio
    IW2FVO
    Jun 2009
    Sc*nthorpe, UK
    This does not look straight forward to use. How for have you got? Have you found its address for example?
    there is a similar thread on the pbp3 forum it might be worth a look
    http://support.melabs.com/threads/98...F8574-20x4-LCD
    Jun 2009
    Sc*nthorpe, UK
    this looks very interesting if you are open to alternatives.
    http://www.robot-italy.com/en/lcd05-...ackground.html
    I have used similar in the past and found them very easy, this one includes keypad inputs.
    Jun 2009
    Sc*nthorpe, UK
    Richard's link looks to be the solution you are looking for.
    Jun 2008
    Varese , Italy
    Steve,
    the address is 0x20.
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Do you need any more help?
    Jun 2008
    Varese , Italy
    Thanks Steve,
    I am running the PBP 2.50B version: is the Darrel include applicable to my pbp version ?
    If not, what could I do ? Any possible modification to the program ?
    ambrogio
    IW2FVO
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by iw2fvo View Post
    Thanks Steve,
    ambrogio
    IW2FVO
    I can not advise you on this. Is there a pressing reason you want to use this LCD? There are LCDs that are easier to use and this one just looks like hard work to me.
    Jun 2008
    Varese , Italy
    Steve,
    Thanks.
    I have no more pins available on the pic and I have this LCD on my hands.
    Anyway, what LCD ( 20x4) with serial interface could you suggest to me ? I could try to get one.
    Ambrogio
    IW2FVO
    Jun 2009
    Sc*nthorpe, UK
    See post 6 above
    Jun 2009
    Sc*nthorpe, UK
    Jun 2009
    Sc*nthorpe, UK
    The good news is that it can be done here is some code.
    'ARDUINO IIC LCD GY-LCD-V1
    'PIC 12F629
    'PRINTS " HELLO RCG!_"
    Define OSC 20
    DEFINE I2C_SLOW 1
    CMCON = $7
    OPTION_REG.7 = 0
    C VAR GPIO.1
    D VAR GPIO.0
    ADDR VAR BYTE
    ADDR = $40
    CMD VAR BYTE
    LCD_CMD VAR BYTE
    E VAR LCD_CMD.BIT4
    RS VAR LCD_CMD.BIT6
    E=0:RS=0
    LCD_CMD = 0
    PAUSE 1000
    LCD_CMD = $2
    GOSUB LCDWRITE
    GOSUB LCDWRITE
    LCD_CMD = $8
    GOSUB LCDWRITE
    LCD_CMD = $0
    GOSUB LCDWRITE
    LCD_CMD = $E
    GOSUB LCDWRITE
    LCD_CMD = $0
    GOSUB LCDWRITE
    LCD_CMD = $6
    GOSUB LCDWRITE
    RS=1
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $48
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $45
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $4C
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $4C
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $4F
    GOSUB LCDWRITE
    LCD_CMD = $42
    GOSUB LCDWRITE
    LCD_CMD = $40
    GOSUB LCDWRITE
    LCD_CMD = $45
    GOSUB LCDWRITE
    LCD_CMD = $42
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $43
    GOSUB LCDWRITE
    LCD_CMD = $44
    GOSUB LCDWRITE
    LCD_CMD = $47
    GOSUB LCDWRITE
    LCD_CMD = $42
    GOSUB LCDWRITE
    LCD_CMD = $41
    GOSUB LCDWRITE
    LCDWRITE:
    I2CWRITE D,C,ADDR,[LCD_CMD]
    E=1
    E=0
    from this thread
    If you need more help just ask,
    Jun 2009
    Sc*nthorpe, UK
    Does this code work?
    If it does we can use it as a starting point and adapt it for your use.
    Jun 2008
    Varese , Italy
    Thanks Steve for the kind assistance,
    I can not test the code soon : the day before yesterday my display went off. I ordered another one and will be here in two weeks tiime.
    Anyway : the dispaly is exactly the same of the one shown in the images attached to the link you have sent to me.
    I really think that a smart code to control the i2c LCD will be appreciate by a lot of people that use PBP.
    Thanks a lot for helping.
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Let me know when you have a replacement. I am confident that we can get this to work between us. You do the testing and I will help with the programing.
    I would do it all but I do not have the hardware anymore as I went over to touch screen PLCs. I am more interested in touch screen GLCD solutions based on a PIC (Amicus18 for example) which I need the hardware for.
    Jun 2008
    Varese , Italy
    Thanks Steve,
    I do appreciate your help. I will tell you as soon as I have the new dispaly in my hands.
    Ambrogio
    Jun 2008
    Varese , Italy
    Hi Steve,
    I received the new display just now.
    It is equipped with the PCF 8574T.
    It is connected to the QC2004A display in the following way:
    pin_4 p0 > RS
    pin_5 p1 > RW
    pin_6 p2 > enable
    pin_7 p3 > Backlight
    pin_9 p4> data4
    pin_10 p5 > data5
    pin_11 p6 > data6
    pin_12 p7 > data7
    It is different wrt the one I had before: it has a different connections between the PCF and the LCD.
    I will be ready for testing tomorrow or monday: please suggest me what trials to do just to start.
    Thanks for all
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    We start with Darrel's routine for PBP3 and make changes for your LCD pin setup and PBP2.x
    Jun 2008
    Varese , Italy
    Steve,
    the point is that I do not have PBP_3.
    My pbp is 2.50 B.
    No arraywrite or read, no usercommand ... are available to me .
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Steve,
    My pbp is 2.50 B.
    Ambrogio
    Yes the arraywrite command has to be handled differently in pbp2.5.
    Arraywrite loads the LCD_Buff you need to replace Arraywrite with a routine that loads what you want displayed on the LCD into LCD_Buff.
    For example
    LCD_BuffLen = 4
    LCD_Buff.0 = "T"
    LCD_Buff.1 = "e"
    LCD_Buff.2 = "s"
    LCD_Buff.3 = "t"
    LCD_WriteBuff
    Just to give you an idea as I think this is how it works but obviously I have not tested it as only you have the hardware.
    Also johncouture's LCD has the same pins as your's (check it) so his modified programs are the ones you need to use.
    This is the first step more issues could be thrown up. I am expecting to enjoy the ride (voyage of discovery) and hopefully get it working.
    Jun 2008
    Varese , Italy
    Steve,
    sorry for not having reply soon because of " family duty ".
    I wrote this small program and I am able to control Backlight :
    DEFINE OSC 40 ' 10 MHz XTAL AND X 4 INTERNAL PLL
    DEFINE I2C_SLOW 1
    C VAR portd.3 ' S_CLOCK
    D VAR portd.2 ' S_DATA
    ADDR VAR BYTE
    ADDR = %01001110 ' dec 78 , hex 4E
    CMD VAR BYTE
    LCD_CMD VAR BYTE
    E VAR LCD_CMD.BIT2
    RS VAR LCD_CMD.BIT0
    E=0:RS=0
    LCD_CMD = 0
    PAUSE 1000
    MAIN:
    I2CWRITE D, C, ADDR, [%00000000] ' bck_lt= off
    PAUSE 200
    I2CWRITE D, C, ADDR, [%00001000] ' bck_lt=on
    PAUSE 200
    GOTO MAIN
    The I2C address is new.
    Now, my LCD has 20 chrs X 4 lines.
    The PCF controls the LCD using the upper four bits of its output port.
    I have to initialize the LCD in four bit mode , four lines at the required PCF port pins.
    How could I do that ?
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Initialise is at the end of the second code which you need to include using this code
    INCLUDE "LCD_PCF8574A.pbp"     ; Init LCD using I2C and PCF8574
    ; File Name   : LCD_PCF8574A.pbp
    ; Author      : Darrel Taylor
    ; Created     : Mon Feb 24 2014
    ;               Sun Mar 03 2014
    ;               Updated bit shift. Data is on Lower side, Cmd lines on Upper
    ; Compiler    : PicBasic Pro 3.0.6.x or higher
    ; Description : Uses PCF8574 Port expander to interface with HD44780 LCD
    LCD_BuffSize    CON 30
    LCD_Buff        VAR BYTE[LCD_BuffSize]
    LCD_BuffAddr    CON EXT : @LCD_BuffAddr = _LCD_Buff
    LCD_BuffLen     VAR WORD        ; Length of data in buffer
    LCD_Data        VAR BYTE        ; Data to Send to LCD
    LCD_Byte        VAR BYTE        ; Nibbles to Send
    LCD_RS          VAR LCD_Byte.0  ; Register Select bit
    LCD_RW          VAR LCD_Byte.1  ; Read/Write bit
    LCD_E           VAR LCD_Byte.2  ; Enable bit
    LCD_BackLight   VAR LCD_Byte.3  ; Backlight 0=ON
    LCD_WriteMode   VAR BYTE        ; 1=LowNibble, 2=HighNibble, 3=Both
    LCD_CommandMode VAR BIT         ; Indicates next byte is a command
    LCD_Byte2       VAR BYTE        ; Same nibble without E bit
    LCD_Idx         VAR BYTE
    testmode        var byte
    GOTO Over_LCDPCF8574
    ;----[Write 1-byte to LCD]--(Input is LCD_Data)---------------------------------
    USERCOMMAND "LCD_WRITE"
    LCD_WRITE_:
       LCD_E = 1
       IF LCD_WriteMode.1 = 1 THEN                             ; Write High Nibble
         LCD_Byte = (LCD_Byte & $0F) | (LCD_Data  & $F0)
         LCD_Byte2 = LCD_Byte & $FB
         I2CWRITE SDA,SCL, LCD_Addr,[LCD_Byte, LCD_Byte2]
       IF LCD_WriteMode.0 = 1 THEN                             ; Write Low Nibble
         LCD_Byte = (LCD_Byte & $0F) | ((LCD_Data << 4 )& $F0)
    LCD_WRITE?  macro
        L?CALL _LCD_WRITE_
    ;----[Write contents of buffer to LCD]------------------------------------------
    USERCOMMAND "LCD_WRITEBUFF"
    LCD_WRITEBUFF_:
    ' The purpose of this routine is to increment through LCD_Buff and
    ' pass each character to LCD_Data so that it can be written.
    ' This will loop for LCD_BuffLen which is calculated by
    '    subtracting the starting address of the buffer from the
    '    ending address of the buffer.
        LCD_BuffLen = R5 - LCD_BuffAddr -1
        LCD_WriteMode = 3          ; Both Nibbles
        LCD_CommandMode = 0
        FOR LCD_Idx = 0 TO LCD_BuffLen
            IF LCD_Buff(LCD_Idx) = $FE THEN LCD_CommandMode = 1 : GOTO LCD_ByteDone
            IF LCD_CommandMode THEN
                LCD_RS = 0   ' this is a command
                LCD_CommandMode = 0 ' false, next byte will be data
                LCD_RS = 1   ' this is data
            LCD_Data = LCD_Buff(LCD_Idx)
            LCD_Write
                PAUSE 2
                PAUSEUS 50
          LCD_ByteDone:
        NEXT LCD_Idx
        LCD_CommandMode = 0
    LCD_WRITEBUFF?  macro
        L?CALL _LCD_WRITEBUFF_
    USERCOMMAND "LED_WRITE"
    LED_Write_:
        ; Write to the LEDs (this is a test routine)
        LCD_E = 1
           i2cwrite SDA,SCL, LCD_Addr2,[LCD_Byte]
           i2cwrite SDA,SCL, LCD_Addr2,[LCD_Byte2]
    LED_WRITE?  macro
        L?CALL _LED_WRITE_
    Over_LCDPCF8574:
    ;----[Initialize the LCD]-------------------------------------------------------
    PAUSE 250             ; LCD Power-on delay
    LCD_Backlight = 1     ; Backlight OFF
    LCD_RW = 0            ; Write to LCD
    LCD_RS = 0            ; Command Register
    LCD_WriteMode = 1     ;-- Low Nibbles only
    LCD_Data = 3          ; Reset 3 times
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = 2          ; Start 4-bit mode
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_WriteMode = 3     ;-- Both Nibbles
    LCD_Data = $28
    gosub LCD_Write_      ; Function Set, 4-bit, 2-line, 5x7
    LCD_Data = $0C
    gosub LCD_Write_      ; Display ON
    LCD_Data = $01
    gosub LCD_Write_      ; Clear Screen
    PAUSE 2
    LCD_Data = $06
    gosub LCD_Write_      ; Entry Mode
    PAUSE 2               ; Let command finish
    The files you need are here
    Jun 2009
    Sc*nthorpe, UK
    Ambrogio are you making any progress?
    Jun 2008
    Varese , Italy
    Steve,
    I am not able to go on. I am not a software guy...
    I do need something very simple just to start from the beginning...
    It is hard to me .
    I understand that I will never have the I2C lcd as simple as the LCDOUT that I usually use.
    Thanks to be patient !
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Steve,
    It is hard to me .
    Ambrogio
    I will work on something very simple like print "Test" on the LCD as a start.
    Unfortunately my problem is everything looks easy to me and I assume everyone sees what I see and understands what I understand and obviously they do not. I can take the lead if you want me to. I just assumed you wanted the fun of solving the problem. Give me a bit of time to write a test program.
    Jun 2008
    Varese , Italy
    Thanks Steve.
    your assistance is great.
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    This is the code to initialise the LCD and send Test. It does not use the LCD_Buff features. Obviously you need to check the OSC and DEFINEs as usual. I do expect this not to work first time!
    DEFINE I2C_SLOW 1
    SDA         VAR PORTD.2       ; I2C Data pin
    SCL         VAR PORTD.3       ; I2C Clock Pin
    LCD_Addr CON 78
    'LCD_BuffSize    CON 30
    'LCD_Buff        VAR BYTE[LCD_BuffSize]
    'LCD_BuffAddr    CON EXT : @LCD_BuffAddr = _LCD_Buff
    'LCD_BuffLen     VAR WORD        ; Length of data in buffer
    LCD_Idx         VAR BYTE
    testmode        var byte
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = $28
    LCD_Data = $0C
    LCD_Data = $01
    PAUSE 2
    LCD_Data = $06
    LCD_WRITE_:
       LCD_E = 1
    LCD_Data = "T"
    gosub LCD_Write_
    LCD_Data = "e"
    gosub LCD_Write_
    LCD_Data = "s"
    gosub LCD_Write_
    LCD_Data = "t"
    gosub LCD_Write_
    Jun 2008
    Varese , Italy
    Steve,
    Thanks a lot for the intersest.
    It does not work. I added the bck_lt flashing in the main loop just to see if the communication is good > the bck_lt comes ond goes correctly.
    I am attaching the whole program
    Ambrogio
    '* Name : RKPK40 board pic18F452 40 MHz *
    '* Notice : Copyright (c) 2014 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 23/06/2014 *
    '* Version : 1.0 *
    '* Notes : *
    ';Program Configuration Register 1H
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
    ';Program Configuration Register 2L
    @ __CONFIG _CONFIG2L, _BOR_OFF_2L & _BORV_20_2L & _PWRT_ON_2L
    ';Program Configuration Register 2H
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    ';Program Configuration Register 3H
    @ __CONFIG _CONFIG3H, _CCP2MX_OFF_3H
    ';Program Configuration Register 4L
    @ __CONFIG _CONFIG4L, _STVR_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    ';Program Configuration Register 5L
    @ __CONFIG _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    ';Program Configuration Register 5H
    @ __CONFIG _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    ';Program Configuration Register 6L
    @ __CONFIG _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    ';Program Configuration Register 6H
    @ __CONFIG _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    ';Program Configuration Register 7L
    @ __CONFIG _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    ';Program Configuration Register 7H
    @ __CONFIG _CONFIG7H, _EBTRB_OFF_7H
    DEFINE I2C_SLOW 1
    LCD_Addr CON 78
    LCD_Idx VAR BYTE
    testmode var byte
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = $28
    LCD_Data = $0C
    LCD_Data = $01
    PAUSE 2
    LCD_Data = $06
    LCD_WRITE_:
    LCD_E = 1
    LCD_Data = "T"
    gosub LCD_Write_
    LCD_Data = "e"
    gosub LCD_Write_
    LCD_Data = "s"
    gosub LCD_Write_
    LCD_Data = "t"
    gosub LCD_Write_
    pause 5000
    i2cwrite sda, scl, LCD_addr, [0] ' back_lt blinking
    i2cwrite sda, scl, LCD_Addr,[%00010000]
    Jun 2008
    Varese , Italy
    Steve,
    I have checked the PCF to LCD connection :
    bit0 = RS
    bit1 =RW
    bit2 =EN
    bit3 =bck_lt
    bit4 =D4
    bit5 =D5
    bit6 =D6
    bit7 =D7
    D0 to D3 of the LCD : there is no connection at all.
    Ambrogio
    Jun 2008
    Varese , Italy
    Steve,
    the display has 20 chrs X 4 lines.
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Steve,
    Ambrogio
    DEFINE I2C_SLOW 1
    LCD_Addr CON 78
    LCD_Idx         VAR BYTE
    testmode        var byte
    gosub LCD_Write_
    PAUSEUS 6000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    gosub LCD_Write_
    PAUSEUS 1000
    LCD_Data = $28
    LCD_Data = $0C
    LCD_Data = $01
    PAUSE 2
    LCD_Data = $06
    LCD_WRITE_:
       LCD_E = 1
    LCD_Data = "T"
    gosub LCD_Write_
    LCD_Data = "e"
    gosub LCD_Write_
    LCD_Data = "s"
    gosub LCD_Write_
    LCD_Data = "t"
    gosub LCD_Write_
    I over simplified the program!
    need to add this line
    LCD_RS = 1 ' this is data highlighted in red above. This switches from command mode to data. It was in command mode that is why your back_lt instructions worked. An excellent clue for me.
    I am not sure about these lines
    LCD_Data = $28
    and what the location addresses are to position the cursor at the beginning of each line.
    Have you a datasheet for this LCD?
    When this simple example is working we can add Command/Data switching which we will obviously need to have. I will follow Darrel's method as close as possible, he uses $FE to indicate the next byte is a command and switches to command mode for one byte then back to data.
    Plenty for me to think about.
    Jun 2009
    Sc*nthorpe, UK
    Assuming $80 is line 1/0 then we can add
    LCD_Data = $80
    gosub LCD_Write_
    to position the cursor. As this is a command it goes before we switch to data mode like this
    LCD_Data = $80
    gosub LCD_Write_
    Jun 2008
    Varese , Italy
    Dear Steve,
    I am not able to findout the detailed spec for the QC2004A display. I can tell it is working well using the standard PBP connection diagram.
    I am posting a general spec for LCD addressing ( attached ).
    I did a very bad experience with the PCF expander board that was attached to the LCD: the trim pot that should adjust the contrast of the display has the cursor connected to ground and one side connected to 5VDC. I did turn it just to be sure of the contrast setting and I got a short circuit of the 5Vdc to ground when turned fully clockwise. The result is that my ICD2 programmer smoked and it is no longer working. I have attached the photo of the PCF expander to warn about this item: there is a very very gross design error on it.
    I am looking to find a new pic programmer to buy: what do you recommand to me ? Is the pickit3 really good ?
    I have a pic16f877 to replace on the ICD2 programmer but I do not have any possibiliity to program it with the required bootloader... I will ask someone tomorrow !
    I really hope to test your programs soon. I will let you know.
    I want to thank you once again for the help you are giving to me .
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Ambrogio
    I am looking to find a new pic programmer to buy: what do you recommend to me ? Is the pickit3 really good ?
    I have no experience of programmers as I inherited all of my hardware from my son, he took an electronics course before going to university. I have a Picstart Plus that I have never used.
    Please do as you have sparked my interest now and all sorts of bright ideas are formulating in my mind to the point that I am loosing sleep.
    I have a pickit3 and a pickit2 programmer the pk3 only ever gets used if its the only choice (and it very seldom is) . the gui for the pk2 is just so much better to use . serial debugging is just so easy with the pk2 and its built in comms package . by far the pk2 is my tool of choice for icsp.
    I have never bothered to use either of them in command line mode for programming directly from micro code studio although it is fairly easy to do .
    I must admit that I have not looked to see if microchip have made a better/upgraded gui for the pk3 for at least a year now , my info may be out of date .
    I also wonder if any body has tried the cheap pk2 clones that are on ebay , are they compatible with the microchip pk2 gui ? are they any good?
    Jun 2008
    Varese , Italy
    Is there a lista of PICs programmable by PICKIT2 ?
    Ambrogio
    not that I can find ,but there is not many that aren't on the supported device list.
    you can download the pickit2 program(its free) from microchip site and check out the supported device list if you have specific devices to check
    http://www.microchip.com/Development...tDocumentation
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 19:53
  2. I2c ext eeprom picbasic
    Last Post: - 16th July 2011, 23:00
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 03:28
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
  5. A little help with I2C and PICBASIC Pro
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 17:13
Members who have read this thread : 4
