I2C lcd ( arduino ) with PICBASIC, help
Results 1 to 40 of 93
    Jun 2008
    Varese , Italy
    Default Re: I2C lcd ( arduino ) with PICBASIC, help
    Steve,
    I did run the program:
    P0, P5 and P6 do not toggle: they are always at 0vdc as seen by the scope.
    I did check the tracks : there is good continuity between each pin of the PCF and the display pins.
    I assume the pcf is gone or the module has been sent with a broken pcf.
    As you have seen in the photos, I have changed the contrast pot because it was shorting the 5 vdc to ground , I fit a new one with a "crossed" pins.
    Will order a new board from a reliable seller ... I am searching for it here.
    Thanks for all.
    Ambrogio
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by iw2fvo View Post
    Steve,
    Thanks for all.
    Ambrogio
    Well done it is the PCF!
    I am surprised I thought the PCF was the least likely cause the PCB track or soldering fault was the most likely cause.
    Jun 2009
    Sc*nthorpe, UK
  1. Interfacing with Arduino I2C LCD
    By norohs in forum Documentation
    Last Post: - 30th May 2017, 19:53
  2. I2c ext eeprom picbasic
    Last Post: - 16th July 2011, 23:00
  3. How do I operate an Arduino I2C LCD
    By menta in forum General
    Last Post: - 13th July 2011, 03:28
  4. Still new to PicBasic - i2c questions
    By cometboy in forum mel PIC BASIC
    Last Post: - 13th November 2006, 19:27
  5. A little help with I2C and PICBASIC Pro
    By Qacer in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 17:13
