2 LEDs used Bi-directionally
Results 1 to 15 of 15
    Default Re: 2 LEDs used Bi-directionally
    I feel like a retard. So...
    PIN --- DUAL LEDs --- RESISTOR --- 5VDC
    PIN defined as output:
    HIGH will source, turn on outgoing LED (like we always do)
    LOW will sink, turn on incoming LED
    I don't get how I'm to set ports/TRIS at both ends so neither LED will turn on. I've gone through that thread and a few others all evening but I can't see the forest through the trees apparently.
    TRISx = 1 is used to read an analog input, ex: A/D input. ...
    Even if my ports are defined as digital?
    Oct 2009
    Utah, USA
    Robert,
    In your schematic at the top of the thread... the highlighted (green) LED's will be dark when GP 1&2 are BOTH High OR LOW. But the trick is to keep track of that interaction with the other LED's that are also tied to either of those two pins.
    If GP1 is high and GP2 is low then the Yellow LED will be lit, and vice/versa for the Red one.
    Seems like to me it's time to draw up a good ol'e fashioned truth table.
    With 5 bits (pins) in use it will have 2 exp 5 = 32 possibilities. The truth table will also help you develop your code.
    Is this what they call Charlieplexing?? I've never done one of those, but that is how it seems to my feeble mind.
    good luck
    Dwight
    Hi Robert,
    This is what Microchip did on their PICKIT1 demo board.
    Miami, Florida USA
    Yes, it seems like you are going to have more lit LEDs that what you want at any given time. More than one LED is going to light up for any given combination.
    Anonymous
    Miami, Florida USA
    TRISx = 1 'Sets the port as analog
    TRISx = 0 'Sets the port as digital
    When TRISx = 1 the port is set to a high impedance input mode, meaning no current in or out for the LEDs. In other word it turns the port off for the LEDs.
    Anonymous
    It seems I'm getting denser every year.
    "high impedance input mode" means nothing to me.
    "meaning no current in or out for the LEDs" <--- this I understand
    You only have to explain things once to me, but repeat yourself 12 times, post 3 sample programs, add 6 pictures, include 4 schematics, and I'm good to go.
    I really appreciate the patience you guys have.
  1. 32 LEDs with less than 20mA
    By Demon in forum Off Topic
    Last Post: - 23rd January 2014, 04:28
  2. Leds on/off
    By Leonardo in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2009, 22:36
  3. Two LEDs on one Pin
    By modifyit in forum mel PIC BASIC Pro
    Last Post: - 6th June 2006, 14:32
  4. 8 Leds
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 24th June 2005, 23:15
  5. Want some help with LEDs
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2004, 21:46
